Question about Marantz SR-5200 Receiver
Volume control problem
Volume goes down when the control knob turned up.to turn volume up i have to turn knob very slowly.
I had this problem and needed to remove and dis-assemble the volume control and clean it with tuner cleaner. After that it worked fine.
Posted on Sep 02, 2008
  • 682 Answers
Bring good contact luricat cleaner from near radio shack and apply it over volume and move it forward and backward many times.
Posted on Jul 05, 2008
When I turn the knob to increase the volume, it goes up to three and drops back down to zero. It does this everytime I move the knob at a normal pace or faster. However, if I push the knob slightly in and...
It could be a safety protection meaning you could have a shorted speaker check all speakers and wiring, or it could be a defective volume control, try cleaning the volume with a contact cleaner spray you can find at any good electronic store (you normally have to open the radio to reach the POTENTIOMETER/VOLUME) to be able to spray inside it, than alternate (high/low) the control repetively to move/clean the volume's circuitry
Feb 09, 2011 | Car Audio & Video
Volume problem with VSX-D409
Had the same problem. I had to replace the volume contol. It was inside the receiver behind the knob. It has a part# on it. Mine was part# AWX7386 (control assembly) from Pioneer.com. If you can figure out how to open the case than you can change this piece. Good luck
Dec 23, 2008 | Pioneer VSX-D409
Car radio volume control knob is erratic
When I turn on my radio, the volume is on and o.k. but when I try to turn it higher or lower the volume is lost completely. Any comments?
Jul 06, 2008 | 2001 Pontiac Aztek
VOLUME CONTROL PROBLEM.
If the volume control can be turned continuously in either direction (no stopping), then the control is what is called an encoder and the behavior you are describing is an internal logic failure. If the control has an upper and lower limit (only turns so far), then it is a standard volume control and is physically broken and needs to be replaced. In either case, the unit should be under warranty. Return it to Best Buy for repair. Given that it just came out of the box, talk to a manager and request an exchange.
Dan
Mar 16, 2008 | JVC HX-D77 Shelf System
Volume
the volume control needs to be cleaned. this control is a step switch basicly. and the switch contacts are not making proper contact. cleaning this requires dis-assembly and desoldering so if you are inclined to do this work happy fixing if not it shouldn't cost much to fix.
Jan 19, 2008 | Aiwa NSX-A115 Shelf System
It has lost partially the mechanical connection between the volume control knob and the volume control pot.
The knob could be "stripped". A drop of a slightly resilient glue should do the trick. Do not use rigid adhesives, as this will prevent future service to this area of your receiver....accordianman
Oct 31, 2007 | Yamaha RX-V630 Receiver
Volume
This sounds like a case of a dirty/defective rotary encoder. The volume control used here is not the conventional potentiometer type , but a rotary set of switches that tell the sytem if the knob is being turned left ot right.
Do you think you'd be able to open the unit and spray some contact cleaner into the rotary encoder? It might involve dis-assembling it down to front bezel removal.
jango.
Aug 18, 2007 | RCA RS2044 Shelf System
Volume knob
Normal Aiwa compact shelf units use what is called a jog switch for the volume. Usually you can tell the difference if when you you turn the volume up or down. It goes a short distance and seems to spring back. In this case there are two momentary contact switches. One for up one for down. With a plastic lever on the back of the knob that bumps the approriate switch whether turning down or up. If the lever is broken it will bump up against one but not the other. If it is broken plastic you know how good gluing plastic goes it never seems to hold.
Aug 02, 2006 | Aiwa NSX-A777 Shelf System
Marantz SR-5200 Receiver Logo
965 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
