Question about Dell Inspiron E1505 Notebook
Laptop not charging
I purchased a new battery and the laptop is still not charging
  • 2 more comments
  • jburks Jun 21, 2008
    My laptop Inspiron E1505. I purchased a new battery and it still is not charging. What can I do now?
    clean metal surface with what solution or method?
  • Rawrness427 Sep 10, 2008
    i bought a brand new battery b/c i got the warning that my battery wont charge to full. never had a problem charging... got this battery, and the light saying its charging wont ever come on, its a surprise if it does. The light on my cord says there's power to it. I tried everything... even cleaning it out. nothing still. the second my cord comes out, computer shuts off.
  • Anonymous Oct 11, 2008
    My Dell 1505 Inspirion laptop battery does not charge. I pull the power cord out and the laptop turns off.
    Master:
  • 848 Answers
Just clean the metal surface before inserting the battery
Posted on Jun 21, 2008
Battery not charging dell inspiron 630m
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new dell inspiron 630m battery to replace the defective one.
Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5
Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.
Apr 05, 2013 | Dell Inspiron 6400 Notebook
Dell d810 battery not charging
Instructions
Determine if the Dell Latitude D810 battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
5
Apr 02, 2013 | Computers & Internet
My m2000 battery is not working
The possible causes are as follows:
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
5
http://www.aurabuy.com/cheap-12-cell-battery-for-hp-compaq-presario-b3300-c300-c500-m2000-paypal.html
Mar 31, 2013 | HP Compaq Presario V2000 Notebook
Dell vostro 3500 shows battery connected but not charging and intermittently shoes no battery detected
Instructions
5
http://www.aurabuy.com/cheap-9-cell-battery-for-dell-vostro-3400-3500-3700-7fj92-04d3c-paypal.html
Mar 28, 2013 | Dell Vostro 3500 Laptop Computer (Intel...
My acer battery is not charging
Laptop battery problems are quite common among owners of all brands of notebooks. On average, laptop batteries last one to three years. Their exact lifespan depends on several factors, such as how much you use the batteries, the number of charge-discharge cycles and the quality of the batteries. Lithium-ion batteries begin to lose the ability to hold a charge over time. Before you replace a laptop battery, consider that there may be other reasons that the laptop is not working properly. You may be able to recharge the battery instead.
1.Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
2. Test the acer power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
3. Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
4. Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5. Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.I hope you find it very helpful. Best regards.
Jan 29, 2013 | Computers & Internet
My dell vostro 3300 laptop battery not charging since i re installed windows 7
2. Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
Dec 09, 2012 | Dell Vostro 3300 Notebook
Laptop won't charge battery
Dec 05, 2012 | Lenovo Computers & Internet
Battery doesnt charge when plugged in
Aug 17, 2011 | Gateway MX7122 Notebook
Hi, I bought Acer4741Z from India on September 2010............now, when i charge the laptop, it shows 52% charging and it wont go till 100 %. Any solution for this............pls help..............
When you first bought the laptop did you fully charge the battery for at least 20-24 hours before use? To ensure the lifespan of your laptop battery is long you will need to follow these easy steps:
1) Charge the battery at least 20 hours before use.
2) Completely drain battery power before you charge it again.
3) Try not to have the laptop battery plugged in if you re going to use AC directly from the wall socket.
You may need to purchase a new battery as this one's lifespan seems to have been reduced as it can only hold 52% charge. When you purchase another follow the above steps.
Feb 26, 2011 | Acer Computers & Internet
How to change the battery
hi
its so simple...
  1. Step 1 Purchase a new battery. Refer to your laptop owner's manual to determine the type of battery you need. Compatible laptop batteries can be purchased from computer parts dealers, the laptop manufacturer, or an online auction.
  2. Step 2 Turn your laptop over and locate the battery compartment. Release the lock/latch and slide out the old battery. Refer to your owner's manual if necessary.
  3. Step 3 Install the new battery by first aligning its receptor pins with the pins in the battery compartment. Push down on the opposite end to snap the battery in place. Secure the lock/latch mechanism by sliding it back to the original position.
  4. Step 4 Plug your laptop into an electrical outlet to charge the new battery. It usually takes about 24 hours to complete the first charge. Subsequent charges will only take a few hours.
please rate me...
thank you
Sep 18, 2009 | HP Compaq Presario V2000 Notebook
Dell Inspiron E1505 Notebook Logo
110 people viewed this question
Alun Cox
