Question about Zanussi Washing Machines
I have FLS 1183W Zanussi washing machine. The drum no longer rotates and does not spin. Rgds
    President:
  • 1,462 Answers
Check motor brushes for continuity (you will need a multi-meter for that) or instead, take the brushes out and examine them. this is the usual cause
Posted on Jun 21, 2008
Zanussi turbodry wdt 1075 washing machine fills & drains but does not perform wash cycles or spin cycles drum does not rotate
Quite probably the motor brushes. Disconnect from mains. Tilt machine backwards as far as possible. On motor, disconnect wires to brushes. With a multimeter, check continuity between brush and any segment if the commutator. If open circuit, replacing the brushes should do the trick. Also visually examine the commutator for damage
Aug 17, 2014 | Zanussi Washing Machines
Washing Machine leak underneath the machine - Zanussi FLS-579C
have checked the door seal
send the 91------------- no this is on a label in the door
Feb 05, 2014 | Zanussi Washing Machines
My Zanussi fls 1183 is not washing the clothes, they are not completely wet and are not clean
This usually means that the drum is not rotating during wash or spin.
If this is the case the most common causes are a broken drive belt or the motor brushes worn out
Always remove the plug before investigating
Jan 22, 2011 | Zanussi Washing Machines
How do you remove back panel on zanussi fls-1183w so i can replace belt
you only need to remove the top of the machine but be carefull when fitting new belt
Oct 05, 2010 | Zanussi Washing Machines
I think the bearings have gone on my zanussi aquacycle fls 1183w. can i do this myself, or do i need a new machine.
I have just done this myself and to be honest it was quite easy.
you will need bearings l replaced both front and rear as the cost of each was nothing, a new bearing seal and a drum gasket as the drum has to come apart.
Tools are a digital camera ,socket set, torx key set, set of spanners a cold chisel and a hammer. And you need the old bearings to put the new ones in
Jun 06, 2009 | Zanussi ZWF1420W Front Load Washer
My door handle on my zanussi fls 1183w washing machine has broken and ive bought a new handle but dont know how to get old one out can you help please
normally on zanussi doors they have 5 or 6 screws around the edge on the inside of the door if you try to undo them and take apart the door the handle should come out be carefull not to drop the glass
Nov 11, 2008 | Zanussi Washing Machines
Door
it probabbly broke somewhere.
if it is possible to take the handle out, I would investigate the problem further.
not worth fixing the handle, you may have to get a replacement.
Mar 16, 2008 | Washing Machines
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Apr 26, 2007 | Zanussi F1045W Front Load Washer
Washing Machines Logo
218 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
