Friend,
There is no such thing as resetting the chip. What you can do is to reinstall the drivers and the printer would be as good as new except the ink used already. Please follow the link below verbatim.
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
Hello
You will need a chip resetter.
You can use chip-resetting devices to reset integrated circuit chips, including printer and copier cartridge chips of various manufacturers. You can use the chip-resetting device to reset printer cartridge chips of various Xerox machine models
Solder four wires to four input ports labeled as "+5 VCC, DATA, CLK and GND" of the "Data In" port of the chip resetting device.
Connect the alligator clips at the ends of four wires to the "+5 VCC, DATA, CLK and GND" ports of the manufacturer's original cartridge chip respectively.
Solder the other four wires to four input ports labeled as "+5 VCC, DATA, CLK and GND" of the "Data Out" port of the chip resetting device.
Connect the alligator clips at the ends of output wires to the "+5 VCC, DATA, CLK and GND" ports of the used cartridge chip from XEROX machine respectively which you wish to reset
Turn on the chip-resetting device and press the "Reset" button on the chip-resetting device to reset the cartridge chip.
I found this website that has chip resetters for, it seems, most of the Xerox printers, except I didn't see the 7500 listed. Contact them to see if their resetter will work on the 7500:
http://www.diytrade.com/china/4/products/3962223/Fuji_Xerox_drum_chip_resetter.html
I couldn't find anything on resetting the chip with the printer's software, so it looks like the only option is to get hold of a chip resetter.
Good luck, and hope this helps.
SOURCE: how to reset chip on toner cartridge for Xerox Phaser 6125?
Just google Xerox 6125 chip and you will find a couple of sources. The ink will need to be added also.
You can often times find them on E-bay.
SOURCE: how to reset the xerox
Try this: Hold down the back ARROW key with the "i" them with your other hand turn on the machine.
If that did not help, kindly contact the manufacturer and see if they have another way of resetting the chip.
Thank you and good luck!
SOURCE: how to reset the xerox phaser 7500 chip?
I ´m searchingfor the same answer. I have been refilling the toners but now it seems thatthey reach the limits, so the printers is asking me for a new toner. I knowthat you can find from alibaba.com the reset chips. If I have any news I'llposted, please do the same.
how to reset chip toner for xerox phaser 7500?
hello
Did YOU tell me the website where I can buy him the reset?
you are 100% sure that will work?
