Question about QDI Group QDI Advance 10F Motherboard
Booting The computer loads and hangs on loading dmi pool
  • tony10156 Apr 13, 2009
    MY QDI BOARD HANGS EVEN BEFORE THE DMI POOL SEQUENCE. IT HANGS ON THE QDI LOGO JUST SECONDS AFTER BOOTING. THE CPU IS GOOD AS IT WORKS ON DIFF BOARD. ANYONE HAVE ANY IDEAS??
    Problem Solver:
  • 17 Answers
A computer hanging when it has boot could possibly be associated with: -
1. Processor Overheating
2. Corrupt Operating System.
3. Corrupt RAM
Recommendation.
On the first instance, when the computer is booting, if you can switch to the BIOS setup and check the system health, you could find that the temperature could be more than 60 degrees celcius.
To solv this, ensure that the cooling fan is sitted properly on the processor.
Ensure there is no dust on the fan as this could slow down the rpm(revolutions per minute) or try changing another fan.
As for the operating system, you can trying loading or repairing the existing operating system using the right source.
In some cases where RAM is corrupt, trying using another chip to be sure if the problem is being caused by this.
Good luck.
Posted on Jun 21, 2008
Acer AM1100 hanging up on DMI update
Restart.
Enter BIOS SETUP.
Use "Load Factory Default Settings".
Reset the boot-order to floppy/CD/Disk0.
Save/Exit.
This will force a "full" DMI update.
Watch for the computer to spin the floppy,
and then spin the CD, looking for "boot" records.
If it does, then the DMI update has _COMPLETED_ and the "boot" process is starting.
Feb 03, 2010 | Acer Aspire M1100-B1300A Refurbished AMD...
This Acer AST 160 I'm working on crashed...
Computer stops at verifying dmi pool data. Issue: Computer stops at verifying dmi pool data.
Cause: This issue can be caused by any of the below reasons.
  1. Corrupt boot files on the computer.
  2. Settings for hard disk drive are not correct.
  3. Floppy diskette or CD in computer causing issue.
  4. Boot devices not set properly.
  5. BIOS corrupt or misc. setting not set properly.
  6. Connections loose or disconnected.
  7. Bad Hard disk drive or other bad hardware.
Solution: Corrupt boot files on the computer
If the computer has no bootable files on the drive it is attempting to boot from it is possible that the computer may halt at " verifying dmi pool data..."
To resolve this issue:
  • Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
  • Once at the A:> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
If the computer continues to not boot attempt to re-create the master boot record by booting from the bootable floppy diskette again. Once at the A:> prompt type "fdisk /mbr" and press enter. This should return you to the prompt without giving you any message. Once at the prompt remove the diskette and reboot the computer.
Additional information about the "fdisk /mbr" command can be found on document CH000175.
Note: The above information only applies to Microsoft Windows users. If you are running a Linux / Unix variant or other operating system such as OS/2 and the computer is freezing at this DMI message ensure that Linux / Unix has been properly installed first and/or your boot manger is not corrupt.
The computer freezing at "Verifying dmi pool data..." may be caused when the hard disk drive settings within CMOS are not set properly. Enter CMOS and verify that the hard disk drive settings are set properly and/or that it is set to Auto Detect. Additional information about entering CMOS setup is found on document CH000192.
Verify no floppy diskette or CD is in the computer. In some cases the computer may be trying to boot from either of these drives causing issues with the boot sequence.
The computer stopping at " verifying dmi pool data..." can be caused when the boot devices on your computer are not set properly in CMOS. First, verify that no CD or diskette is in your computer. If a CD or diskette is in the computer attempt to remove this first to determine if it was attempting to boot from it.
If No CD or diskette is in the computer and your computer still halts at the DMI message enter CMOS setup (steps found on document CH000192) and verify that the boot options are set properly. We commonly recommend that the floppy be set the first boot device, hard drive as the second boot device and the CD-ROM as the third boot device.
If none of the above recommendations have resolved your issue
Sep 10, 2009 | Acer Aspire T160 (AST160UA3400) PC Desktop
My Zenith PC displays Verifying DMI pool data . Update Success
Sometimes this can be even simpler. Put in your Windows CD and boot to safe mode command prompt and type fixmbr. This will repair your master boot record for your primary boot harddisk. Eject the windows CD and reboot and see if it fixes your problem.
Sep 02, 2009 | Computers & Internet
Windows 7 stuck at verifying DMI Pool Data
1. This means that Windows does not recognize the device.
Unplug the DMI unit and shut down Windows 7 then restart.
2. Check the connection to the PC.
3. Your cable may not be sending the right signals to the PC
4. Check the Compatibility of the unit you are trying to connect to the PC with the Windows7 Compatibility troubleshooting tools built into Windows 7 .
Aug 29, 2009 | Abit AX8 Motherboard
Hangs during boot. Last entry on screen is "Verifying DMI Pool Data........" Then blinking cursor at bottom of screen
restart the machine in Safe Mode. And restore to a back date. Alternatively, at boot time press F8 and select When OS booted correctly or some such option, meaning that when your PC booted correctly the last time.
Aug 07, 2009 | Northgate (STAX2517C2) PC Desktop
Bios update failed *flash*
Did you make copy of your original bios before flashing...if yes then reflash with your original.
If No then trying reflashing again making sure no power cuts, dont touch computer until flashing is complete.
Are you using the correct bios for your MoBo?
Jul 04, 2009 | Acer Computers & Internet
Acer Aspire AM3100-U3202A ''hard drive'' will not boot up
That could be a hardware failure of some sort, or because you added a new hardware device. The "DMI pool" code has nothing to do with Windows, but is part of Plug and Play. Windows has not even loaded yet. It is the System Board BIOS startup code checking the hardware configuration, and setting system board resources for Plug and Play to use. Go in to the system board BIOS (normally DEL key when first powering on) Look in the PnP or PCI Configuration section, for an entry "Reset Configuration Data. It will show Disabled. Change it to Enabled, and save the new configuration and reboot. BIOS will set it back to Disable after it clears the DMI data and rebuilds it. The first time through, it will take a long time, but after that it should not hang. Unless there is a hardware problem with one of the adapters on the system board or PCI bus.
I have seen CD-Rom drives cause this hang, if there is a CD in the drive. So make sure there are no CD's in the drives when you start up.
Apr 01, 2009 | Acer Computers & Internet
Frezes at verifying DMI settings. Already changed MB and Power supply. Lan connection only flashes green once in a while should be constant. Tried on a working terminal and does the same.
The Desktop Management Interface (DMI) is a new
method of managing computers in an enterprise. The
main component of DMI is the Management Information
Format Database, or MIFD (the DMI Pool Data). This
database contains all the information about the
computing system and its components.
At times, some systems may experience hang
conditions after partitioning, formatting and initial
bootup of a hard drive. The message, "Verifying DMI
Pool Data" appears and the system hangs. This
condition may continue after the drive has been
removed.
! WARNING ! ALL SUGGESTIONS LISTED IN THIS
INFORMATION BULLETIN ARE BIOS RELATED. FOR
A PERMANENT SOLUTION, MAXTOR RECOMMENDS
THAT USERS CONSULT THEIR SYSTEM OR
MOTHERBOARD MANUFACTURER FOR BIOS
UPGRADES.
Suggestions to Resolve the Condition:
1.Apply power to the computer.
2.Access the system BIOS.
Set the drive type as None or Not Installed.
Load BIOS Defaults
Load SETUP Defaults
3.Save the BIOS changes and reboot the PC to a
System Boot Diskette.
4.Shut down the PC after the memory count is
displayed.
5.Reconnect the power and interface cables to the
hard drive.
6.Access the System BIOS.
7.Auto-Detect the hard drive. Ensure that the LBA
Mode option is enabled.
8.Save the BIOS changes and boot the PC with a
System Diskette.
9.Partition and format the hard drive via the
operating system.
10.Reboot the system. On bootup, the screen should
read:
Update Successful
The system should continue booting normally.
Other Possible Solutions:
2.Access the System BIOS.
3.Disable both the Internal and External CPU Cache.
These features are located in either the "BIOS
Features" or "Advanced Settings" options of the
BIOS Setup.
NOTE: Consult the System or Motherboard User's
Manual for exact location of the Internal and
External CPU Cache settings.
4.Save the BIOS changes and reboot the PC to a
System Boot Diskette. On bootup, the screen
should read:
Update Successful
5.After the system successfully boots, re-start the
PC and access the system BIOS.
6.Enable the External CPU Cache. This feature is
located in the "BIOS Features" or "Advanced
Settings".
Manual for exact location of the External CPU
Cache setting.
! WARNING ! User's MUST re-enable this feature
for optimal system performance.
7.Save the BIOS changes and reboot the PC to a
should read:
Update Successful
NOTE: If the aforementioned suggestions fail to
resolve the issue, contact the system or motherboard
manufacturer to:
Remove the "Clear CMOS" Jumper and reset the
system BIOS
Obtain a Flash BIOS Upgrade
from pc help;
SYSTEM HANGS AT MESSAGE: "VERIFYING DMA POOL DATA":
You did not say what operating system you are running but I assume Windows 95 or 98. It is possible some Windows
system files are corrupted or perhaps the system doesn't like your ram (if you added or installed ram recently). There
is also a possibility that there is something wrong with your BIOS and you *may* have to update it, but I would avoid
doing that if at all possible.
A quick fix - if the problem is software related - is to:
1. boot to a Windows startup disk (one that matches your operating system). this step assumes that your PC is setup
to boot to the A: drive before the C: drive (via the BIOS SETUP program). If you don't have a Windows startup disk,
you will have to make one on another person's computer that has the same version of Windows. You make one via:
my_computer/control_panel/add_remove_programs/startup_disk
2. run "scandisk c:" to make sure that any file corruption is fixed before going to next step
3. do a "sys c:" from the "a:" prompt to transfer a good copy of Windows system files to c: drive
4. remove the boot floppy, reboot the system and see if all is well.
If that does not solve the problem you may have to reinstall Windows 95/98. Ouch!
I recently had someone bring me a computer that had this DMI error message problem and I tried the "sys c:" method
(with the startup disk) without success and had to entirely reinstall windows 95 (and almost all applications except for
some programs that did not need to be placed in any Program Files directory or other special location) to cure the
problem. However nasty a job that is, it did cure the problem.
Jun 23, 2008 | Computers & Internet
System unable to load oprating system
the operating system files have got corrupted if you have the option on the screen when you first turn it on to go to recovery ,usualy F11 it will recover the software ,if not you will need to install the o/s again
good luck
Terry
Mar 12, 2008 | Intel Motherboard
Acer descktop t-180 stuck on "verifying DMI pool DATA"
Remove and clean the memory with soft material and then fixed it back and then start the system.
If not solve then;
Remove the Hard drive and fixed back then boot the system,
If not solve then;
When booting press "F2 or Delete" to enter the bios setup.
In there find the "Load BIOS Default setting" and select and then enter.
Press "F10" to save and exit setting.
If not solve then;
REmove and replace the CMOS Battery and then do this Again
""When booting press "F2 or Delete" to enter the bios setup.
Press "F10" to save and exit setting."
If same problems Occur;
Try examine the motherboard maybe some portion on it overheat. in this case"Mother board damage" However if found nothing on the board "
do not hesitate to notify me for further instruction.
Jan 06, 2008 | Acer Aspire T310 PC Desktop
QDI Group QDI Advance 10F Motherboard Logo
151 people viewed this question
Top QDI Group Computers & Internet Experts
Tom Chichester
Bill Boyd
Are you a QDI Group Computer and Internet Expert? Answer questions, earn points and help others
