Question about Zanussi FJS1225W Front Load Washer
Zannussi item caught between inner and outer drum .how do i release the two drums from each other
    President:
  • 1,462 Answers
This is not easy
disconnect water and elec
remove the top (2 screws at rear) then remove hoses. remove rear cabinet half - 2-3 screws at top, 1 screw each side at bottom behind plastic covers and 2 screws at bottom rear. back half of cabinet then slides off.
take wires off heater and remove heater - it is held by 1 10mm nut in centre.
you can then see into gap between tub and drum and locate foreign object and remove.
assembly is the reverse
Posted on Jun 21, 2008
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
Defy laundromaid electrologic 920 drum wont turn
Something caught between inner & outer bowl. Nail or screw caught in inner bowl. Main bearing seized, replace seal & bearing(s).
Dec 18, 2013 | Washing Machines
Trying to diagnose a problem and have back panel off. Belt was off AND I think the cause is that the drum pulley and inner drum will not spin without a lot of pressure. I figure the motor (which appea
Either something is caught between inner & outer bowl or drum bearings need replacing. Also check outlet hose going to pump sometimes object caught there causing the bowl to be tight to turn.
Dec 11, 2013 | Maytag MAH2400A Compact Front Load Washer
My hotpoint wt940 inner drum doesnt seem to come out of the outer plastic drum
If you have both drums out then it is best to rest the outer drum edges on something so the inner drum is free to release. The drum bearings will be holding the inner drum in place and can take a bit of persuasion with a block of wood on the end of the shaft and a good hammer to get it to release. Make sure you use a block of wood to protect the end of the shaft otherwise you can damage the end and then you will have to get a new spider with shaft for it.
Dec 29, 2012 | Washing Machines
There sems to be something scraping and catching between the outer and inner drum,how do i access this area to check the problem out?aquarius wml520
remove agitator on centre shaft there is a nut that has to bee removed if spin tub wobbles that may be the problem
Jun 16, 2011 | Washing Machines
Hotpoint aquaries wf321 is making a loud clicking/knocking noise when its in the spin cycle, to me sounds like a poss bearing gone or maybe something is caught up?
From the front of the washer, spin the drum by hand, if it feels rough or is noisy or rumbling, then the drum bearings have failed.
It is possible that there is something caught between the inner and outer drum.
Nov 30, 2010 | Hotpoint Washing Machines
Why has my front loading washing machine started to rattle, knock and squeak during the spin cycle
If the drum is loose and you can feel loose play when you lift the lip of the inner drum, you probably have bearing problems and/or a broken arm on the rear of the inner drum. However a coin caught between the inner and outer drums isn't good news either. Find a tech to diagnose and explain...Good luck.....Nomess
Apr 20, 2010 | Whirlpool Washing Machines
Drum is stiff to turn
clothes caught between inner and outer Drum, you have to get it out !good luck eire.
Nov 18, 2007 | Zanussi FLE1416W Front Load Washer
Drum
u need to put something like a wooden hammer handle into the hole in the spider at the back when u have put it in spin the inner drum clock wise fast so it undos the spider or pulley wheel to some people once the spider is all the way off u need to put the nut back on just so it is level with the spindle with a rubber mallet strike it fast and hard and it will move the inner drum to come out once it comes so far out u need to undo the nut and remove the inner drum totally
Sep 01, 2007 | Hotpoint Ultima WF865 Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
111 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
