Question about Video Game Consoles & Games
IT IS AN XBOX 360 AND HAS ONE RED LIGHT FLASHING IT SAYS THE PROBLEM IS E74
    Problem Solver:
Well your 360 is broken. you need to send to microsoft. to send it to microsoft you need to call 1800-4my-xbox, then u tell them about your problem. they'll send you a box which it is going to arrive in about a week. then u send it and then it will arrive in another week
Posted on Jun 21, 2008
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
E74 error and flashing light on xbox 360
Your console has a general hardware failure, if your console is less than 3 years old, and has not been tampered with in any way, ie: the console has not been opened, microsoft will repair this FREE of charge,
visit www.xbox.com/support to book a repair.
Mar 09, 2010 | Microsoft Xbox 360 Console
My xbox 360 is showing one red light flashing and the message E74
sorry man ur xbox 360 i done for its ur video chip that has gone. u can try this but if it dont work than thats it for ur xbox 360. disconect the xbox 360 fans. let it heat up a little than if u see two red lights disconnected for 20 minutes than try it if it dont work ur xbox is done for.
Jul 09, 2009 | Microsoft Xbox 360 Console
The flashing red light comes on with message E74 . What can i do?
It is because The hard drive is spoil if u remove the Hard drive and blow to the hard drive the red light will not come
May 17, 2009 | Microsoft Halo 3 for Xbox 360
you are seeing one red light on the powerbutton and E74 on the screen?
E74 can only be caused by either the HDD or the console itself,so you might wanna try using a different HDD with your console, if the issue still persists, then most probably, the console is having a hardware failure,there is a possibility that the HDD PORT is not properly woking w/c is causing the e74 error.
if thats the case, try calling xbox support hotline(1-800-4-MYXBOX) to process a repair for the console,it will be free,because Microsoft is extending the warranty of the consoles for 3yrs from the date of purchase for e74 and 3red light issues.
or you can also process a repair online,that is available at service.xbox.com,just click on "repair my console"
hope i'll help you..:-)
1 red light
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jan 04, 2009 | Microsoft Xbox 360 Console
1 red light flashing
The cause of E-74 with one red light Flashing problem might be overheating of your console and for avoiding such error in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling of console such as cooling the machine through a pedestal fan.
But as your Xbox already have E74 Error with one red light Problem which can be solved by only repairing it, no other alternative.
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red lightError) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 Error with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours.
Nov 10, 2008 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Xbox 360 e74
You have to have it repaired.
May 19, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
24 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
