Question about Nikon D200 Digital Camera with 18-200mm Lens
First shot with D200 is dark
I enjoyed my D200 for more than 2 years now.
Recently, it started acting up.
After turning it on, most of the time, the first image I take is completely dark.
The ISO auto is blinking and it says 'Err' on the display and in the viewer.
Any ideas?
Thanks
Jan
  • 797 Answers
Try the following:
Start the camera, go to the menu and look for RESET ALL or a setting similar. What you want to do here is to reset the internal firmware back to the manufacturer settings.
As mentioned, check the battery, however just remember that if the battery is either low or bad, you should get a message to such a problem being detected.
You may want to explore further by going to http://www.nikon.com and look for support and technical support to call. They just may put you in contact with a tech who may be able to help on this problem. It may be possible, if this is a common problem, that Nikon may fix it for free.
Then the final solution would be to send the camera in for repair at Nikon. They may have a flat rate.
Lastly if all fails, and it is too expensive to repair, would be to sell it as is or for parts on a site like Ebay.
Posted on Aug 09, 2008
  • 48 Answers
Its most likely to be the battery.
Posted on Jun 25, 2008
My Nikon D200 keeps blowing out the whites and sometimes everything in the shot. You can reshoot the same subject and everything is fine but sometimes you can get a good shot. Any suggestions?
try not using the full auto settings all the time. the auto system has a tendancy to over expose. the camera can over or under judge the lighting and make an improper exposure
Oct 25, 2010 | Nikon D200 Digital Camera
Nikon SB 800 fires but pictures reamain dark
I have 2 SB-800s. When batteries leaked in one Nikon took forever to fix it, so they eventually sent me a refurb. Then they sent my original back. Which was great, until recently it developed this problem.
Another possibly related side effect is the modeling flash does not burst -- it only fires a single (very bright) flash.
The capacitor argument sounds likely. Coincidentally I also had a problem where the flash would fire sporadically -- but that was due to scuz buildup on the contacts.
Sorry I don't have a real solution for you.
May 27, 2009 | Nikon Speedlight SB-800 TTL Flash
My Nikon d40 is all of a sudden taking dark pictures
Silvanus is correct - I have a D200 and often by accident adjust the exposure bias dial when taking the camera out of my backpack resulting in dark shots. I bet this is your problem.
Dec 28, 2008 | Nikon D200 Digital Camera with 18-200mm...
Sony cyber shot s650
I think it is still under warranty because you told its not a year old. Ask Sony about its warranty cover.
http://esupport.sony.com/US
May 30, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
SB800 Won't Remote
The channel on the flash for remote on the 4a withthe NIKON D70
If you are using the Nikon D200 then the channel is 1a ...
If you have any more questions contact
Berrie Smith Camera Repair
bbmw@bellsouth.net
Feb 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Not functioning d200
Nikon D200 High Speed Performance
© 2006 KenRockwell.com Film vs. Digital About these reviews
enlarge
I bought mine from Ritz here. I bought another D200 from Adorama here. Also try Amazon here. Adorama usually has D200/18-70 kits in stock here. It helps me keep adding to this site when you click these links to get yours.
HIGH SPEED PERFORMANCE
General:
My D200 is fast, smooth and quiet. Unlike my D1H, my D200 makes less noise and vibration. It doesn't feel as macho, and allows me to shoot in more places more discreetly. At five frames per second it just hums along sweetly, compared to my bigger cameras which always felt like something was going to come flying off of them from all the clattering.
Buffers versus Memory Card Memory
The D200 uses two very different kinds of memory for storing images.
We're all familiar with the CF cards used to store hundreds of images. These aren't that fast and card makers rate them for write speed. The D200 uses these for recording your images.
The D200, like all professional digital cameras, has a second very high speed internal cache memory called a buffer. You never touch this. This buffer memory stores 25 frames of JPGs, 21 frames of raw or 19 frames of raw + JPG.
The buffer memory is fast enough to store all these frames at the full 5FPS rate, or faster.
The D200 is never slowed by memory speed card. The D200, like other professional cameras, has a second independent set of processors which handle writing the contents of the fast buffer memory to the slower CF card. Because this writing is done with a second set of processors you never know it's working except for the green CF light on the back. The D200 can be busy for over a minute writing to the CF card and you still have the complete ability to shoot at 5 FPS and play back.
The buffer is so deep that even under the heaviest shooting it's unlikely that you'll ever fill it. Even if you fill the buffer you can still make photos and playback, just that the maximum shooting rate will lower a bit until the buffer write and frees up at least one frame.
It takes it a 100 seconds to write 400 MB of data from 19 uncompressed RAW + Large FINE JPG files to my 40x 1GB Lexar card. As a photographer you don't care how long it takes to write. So long as the buffer isn't full the camera works as fast as ever. Even if it is full you can shoot the next shot as soon as the buffer clears enough room. You don't have to wait for everything to write to make a next shot. Even with my slow 40x lexar 1GB card, a constipated buffer and huge compressed raw + JPG Large Fine files I can make a new shot every 3.2 seconds. With uncompressed raw + JPG Fine Large I can get off a new shot with a full buffer every 3.7 seconds. If you ever get to these limits you're doing something stupid. Just shoot JPG and you'll never be able to fill up the buffer faster than you can shoot. With Large FINE Optimal Quality JPGs the buffer clears at the rate of 1 FPS. With Large Basic Optimal Quality JPGs I can run at 2 FPS even with a full buffer. Use the smaller image sizes or the Size Priority JPG setting and you can shoot as fast with the buffer full as empty!
I've had to do seriously stupid tests to fill it up.
Shot Buffer Readout
A shot buffer is fast memory inside the camera which stores the shots you've just made. Your memory card is written from this buffer. Even with the slowest card on earth you can shoot as fast as you want, since it all sits in the buffer until written. Your card is recorded in the background while you shoot. The green CF light tells you this is happening.
The size of this buffer is how many shots it can hold while allowing you to shoot at 5 FPS. If it gets full the camera slows to only as fast as your card will accept data, which is about one frame per second . These buffers are why you don't need to worry about card speed.
I've never filled up more than 9 shots in a buffer. I don't shoot that fast. With a 25 frame buffer the D200 has far more than I'll ever use.
This is the number you see while the shutter button is pressed halfway. It usually looks like [r25], which means it's empty and can hold 25 more shots. Normally you'll see a big number like [527] or [ 1.3]k, which is how many shots are left on your card. As you shoot fast sequences you can see this number drop. When it drops to [r00] your buffer is full and the camera slows down its shooting until the buffer is recorded to the card. It's fun to look at when you get your camera, but since I never fill it up I don't worry about it. You'd have to be shooting many long high speed sequences continuously with a slow card ever to use much of this.
Jan 27, 2008 | Nikon D200 Digital Camera with 18-200mm...
Zen 1 gig
go into system > player settings check contrast setting.
Dec 24, 2007 | Creative Labs Zen MicroPhoto MP3 Player
I have to hit the shutter a few times before I get a shot..
Great testing details ... go to your local high-end store (or wherever you bought it) and try another lens there, and try another body with your lens, try the same testing. They should have display items there.
Some of the higher end camera stores (the ones that offer free training when you buy a camera from them, all have displays that can test certain things). See if it's the lens or the camera by swapping the two with their equipment to see which it is. Then get with your reseller and have it exchanged (whatever their policy is, or have it repaired under warranty).
Good luck.
Nov 14, 2007 | Nikon D200 Body Only Digital Camera
Nikon D200 Digital Camera with 18-200mm Lens Logo
79 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
