1997 Ford Explorer AWD Logo
Posted on Nov 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i open the hood. - 1997 Ford Explorer AWD
Anonymous
Level 2:
New Friend:
  • Expert 65 Answers
  • Posted on Nov 20, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
65
Questions
0
Helped
23759
Points
203
There should be a lever that is on the bottom edge of dash that is under the steering wheel along the trim. if the handle is broken you can use pliers to grab the cable and pull it to get the hood to realse. if you found all that and i seems to work ok then when pulling the release lever have a friend hit or shake the hood to get it to pop up a little so that you can open it all the way.
Anonymous
Level 3:
  • Master 869 Answers
  • Posted on Dec 20, 2010
Anonymous
Master
Level 3:
Answers
869
Questions
Helped
785433
Points
1021
Ford explorer
Hood Release
  • The hood release lever is inside the passenger compartment. The lever connects through a cable to the hood release. When the lever is pulled, the hood catch releases and allows the hood to unlatch, but still remain trapped by the auxiliary latch as a safety catch. When unlatched, the hood is no longer flush with the body panels around it and can be lifted a few inches. Should the hood become unlatched while the car is underway, the auxiliary latch keeps the hood from flying up and blocking the driver's view. This allows the driver to navigate safely off the roadway in order to firmly close the hood.
  • Auxiliary Latch
  • The auxiliary latch is located under the front edge of the hood in the center. Once the hood release lever is pulled, lift the hood a few inches and slide your hand under the front edge of the hood to find the lever for the auxiliary latch. Push the level to the left to release the hood. Once the auxiliary latch is released, the hood can be raised to allow access to the engine compartment.
  • Opening the Hood
  • Locate the hood release lever under the instrument panel on the driver's side of the passenger compartment to the lower left of the brake pedal. Pull the bottom of the hood release lever toward you until the hood releases.
    Locate the auxiliary latch on the center front of the vehicle under the front edge of the hood. Insert your hand under the front edge of the hood, then push the latch handle to the left to release the auxiliary latch. Lift the hood until it is fully raised.
  • Ad
    2012 Nissan Murano hood won't open after pulling hood release to open it!
    Normally, the cable snaps off from behind the cabin release lever. In that case you can pull the cable end with Locking Grips. If it has broken at the hood end, and they have a history of it, there are videos in the link to get in through the grill.
    https://www.google.com/search?q=2012+Nissan+Murano+hood+won%27t+open+after+pulling+hood+release
    2002 escape hood latch access
    Sounds like your hood latch is worn out. When this happens the hood cable gets stretched out and will prevent the hood from opening. The best thing to do is where you pull the leaver to open the hood , disconnect the cable from the latch you pull and use a pair of pliers to pull it and it should pop right open.
    Hood Release is broken, can not open hood even when I pull on cable,how do I open the hood?
    Since you do not say model, try this
    http://www.bing.com/videos/search?q=open+hood+with+broken+release&qpvt=open+hood+with+broken+release&FORM=VDRE
    open hood with broken release Bing Videos
    Open the hood of a 2009 nissan ultima without power
    There is no need for power to open the hood. Your cable may be streached, or in need of adjustment. Have someone push down and up on hood itself while pulling the hood release lever.
    1helpful
    2answers
    How do I open the hood of a Mitsubishi L300 ?
    1. Locate the interior hood-release lever under the dashboard on the driver's side of the interior of the car.
    2. 2
      Lift up and toward you on the hood release lever. The lever is connected to a cable that releases the hood. The hood will pop up about 1/2 inch when you pull the lever.
    3. 3
      Move to the front of the car and locate the exterior hood-release lever under the front of the hood. It is located near the middle of the vehicle, just beyond where the front edge of the hood meets the body. Lift up on the inner lever.
    4. 4
      Lift up on the edge of the hood while holding the inner lever in place. When the hood is up, find the hood prop and raise it, setting its tip in the hood-prop mount on the hood, to hold the hood up while you work in the engine bay.
    Read more: How to Open the Hood on a Mitsubishi Endeavor ' eHow.com http://www.ehow.com/how_6301122_open-hood-mitsubishi-endeavor.html#ixzz16Ou5FhQF
    3helpful
    2answers
    The hood latch cable broke under the hood how can i open it
    Saturn Vue hood release can be opened (if the cable is not broken) by disconnecting the cable from the back of the release lever, grabbing the ball on the end of the cable with some large pliers ("channel locks") and pulling hard. A metal "wire keeper" bracket clamped to the cable end under the hood to serve as a spacer and the release lever works.
    The purpose of this bulletin is to provide a procedure for opening the hood on the Saturn VUE and ION vehicles should the hood latch release cable mechanism become inoperative.
    VUE Hood Opening Procedure Modify the Saturn radio antenna by bending the antenna mast 1 in. (2.54 cm) above the antenna base to a 25 degree angle
    Open hood of similar vehicle to locate hood latch release cable to hood latch attachment point.
    Using modified antenna, note approximate location that antenna will have to enter in between fascia and hood to access the hood latch cable attachment point. This should be toward the left edge of the Saturn emblem. Also note position of the modified antenna base. It should be angled downward.
    Note: Use protective tape on the hood and fascia where the antenna will be inserted to protect the surfaces from scratches
    On vehicle with inoperative latch, insert antenna between hood and fascia and depress the hood latch cable until the hood is opened.
    Good luck and thank you for using fixya
    1helpful
    2answers
    I can't get the hood of my 96 maixma open. The
    Try this have someone assist you take and pull the hood latch and have someone tap the middle of the hood with there hand while you pull the latch all the way out and as they are tapping on the hood let go of the latch if it still doesnt open try this a few more times.If you get the hood open where the locking mechanism is under the hood spray a little WD-40 or PB blaster something like that to help it work better the next time.
    3answers
    Hood wont open on 1999 dodge durango
    The cable to the hood is most likely broken. The hood can be opened from underneath by pulling the cable and replacement is not terribly difficult once the hood is open.
    Top Ford Experts
    ZJ Limited
    ZJ Limited
    Thomas Perkins
    Thomas Perkins
    xxxxxx xxx
    Are you a Ford Expert? Answer questions, earn points and help others
