Repair of samsung (karisma ) washing machine
Water is getting drained in samsung (karisma ) washing machine
    Brigadier General:
  • 6,966 Answers
Water draining is indicative that the drain valve is left open allowing water to escape even during regular/wash cycle and not only on drain/wash cycle completion. this could be brought about by:
1. laundry material, debris, safety pin, clips or some other foreign material has lodged itself prohibiting the drain valve in closing properly; or
2. the mechanism (solenoid) closing the valve is jammed in the open position.
Corrective measure calls for inspection and possibly cleaning or solenoid/control mechanism repair or replacement. Often these can be found at the bottom or near bottom of the machine below the tub.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 21, 2008
E2 Code - Samsung SW50ASP Washing machine
Water drainage issue. Water is not draining from appliance.
·Check drainage pump filter for blockages (e.g. lint, coins hair, clips)
·Check drain hose and waste connection for kinks and blockages.
Then select a spin cycle to drain
the remaining water in the appliance.
·If problem persists please call CustomerCareline. *
Helpline Contact Samsung UK
Dec 08, 2016 | Samsung Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers
    • 7 POSTS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ...
    • 9 MIN
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Samsung SW60ASP washing machine won't spin or drain
    5E is a Drain Error Code.
    This can be caused by a clogged filter in the washing machine or a blocked drain line in your house. There can be a few other reasons, but these are the most likely.
    If you would like to try to repair it yourself, then follow these instructions:
    UNPLUG the washing machine. Repeat, UNPLUG the washing machine!!!
    Check the filter in the back of the washing machine on the bottom right-hand corner. Place a shallow dish under the filter. Loosen the filter to drain out the water. Remove the filter and clean it out. Look at where you removed the filter and you will see the water pump impeller. Make sure it can move and isn't locked up. Remove any debris from the impeller.
    Replace the filter, and plug in the machine. Try a short wash cycle.
    Check for leaks around the filter.
    Mar 11, 2013 | Washing Machines
    Make sure that
    A. the drain hose is above the hight of the water level.
    B. there is an "air gap" between the drain hose and the stand pipe as the water can "syphon"out.
    May 04, 2012 | Samsung Washing Machines
    Why does all the water remain in the machine and doesnt drain out after wash ,spin & rinse ?
    Thank you for contacting
    The possible causes are a blockage somewhere in the drain hose, a pump failure, or an electrical fault that can stop the pump from running.
    Please check this link to troubleshoot your problem:-
    Please get back to us if you have further query else please accept the suggestion.
    Jun 01, 2011 | Samsung Washing Machines
    I have samsung karisma semi automatic washing machine. sometime it drains sometime not.
    I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
    Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
    If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
    It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
    Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
    At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
    If this has assisted you please consider a 4 thumbs up for the rating.
    Thanks and good luck!
    John C
    Apr 30, 2011 | Washing Machines
    I can't get the water to drain
    There are various reasons when a washing machine wont drain.Please check the bellow links to read the article to get an indepth knowledge related to your issue:-
    Apr 02, 2011 | Samsung Washing Machines
    While moving my samsung top washing machine, I think my drain hose pipe has moved down the water level. Now machine is not able to retain the water while washing/soaking. I need to pull the drain hose pipe...
    Although a few modern washing machines can operate with the drain pipe at any height, most machines will drain the water as soon as the drain pipe is placed below the machine water level.
    The simplest solution for your problem would be to ask somebody with some handy man skills or hire a plumber to add a 2 inch PVC pipe to your drainage pipe which extends to a point behind your washing machine & then points upwards, making sure it is long enough to be at a higher point than your machines fullest water level.
    This should be a relatively inexpensive alteration & will ensure that water does not drain unless the machine is on its drain cycle.
    Please let me know if you need any further assistance.
    Best wishes,
    Mar 10, 2011 | Samsung SW62ASP Top Load Washer
    My samsung front load washing machine wont unlock what should i do
    Just turn the power of from the socket & it should just unlock.
    Jun 23, 2009 | Samsung WF203ANW Front Load Washer
    Washing Machines Logo
    376 people viewed this question
    Top Washing Machines Experts
