SOURCE: can't detect my scandisk cruzer micro
You may want to reinstall the Cruzer driver then reconnect your flashdrive
that may help
keep me posted
Evan
SOURCE: Anytime inert my sanDisk 2GB Cruzer USB the led blinks once
If you using any Windows OS version older than 2000, you will have to install the drivers before you can use the flash drive. Honestly, you can hardly get a flash drive with drivers cd now, so you consider an upgrade ok. It is possible also that the USB resource controller has been disabled from either the CMOS Setup environment or Device Manager. Some times too, when the USB connectors have been used for other peripherals like printers, scanners, etc, unplugging them for a flash drive may issue an error message and the drive will not work. Finally, try same on another pc know to be working with flash drive to know whether the drive itself has gone bad. Good luck
SOURCE: I have a Scandisk Cruzer Micro 2.0 GB that when
sorry but you have suffer a electric surge that resulted for your drive to not to work, and im sorry it's busted... try formatting it but if this doesn't work the it is already gone south....
SOURCE: how to rescue the deleted file in scandisk cruzer 2GB?
hi,
you can use any of the available recovery soft-wares
i am giving you links to some of the commonly used ones....
note that these softwares only work, if you haven't used your pen drive after loosing the needed data...
http://www.softpedia.com/progDownload/PC-Inspector-File-Recovery-Download-20771.html
http://www.softpedia.com/progDownload/DiskDigger-Download-121447.html
if it helps please give a vote....
