Vtech 5.8GHz Cordless Phone with Digital Answering System & 4 Handsets
Problem for Vtech 5.8GHz Cordless Phone with Digital Answering System...
Problems with C110 & A110 Vtech Mirage Dect Home phones
By haggis1 on Jun 21, 2008
C110 Mirage Vtech Phone (office phone), the problem is it flashes "base 1" continually...Tried re-registering (no success there). I have even change the re-chargeable batteries (again no change). also my A110 extension phone (Lounge area) which is working fine but does occasionally bleep, which is annoying.
What do you recommend, or should I cut my loses at this point and purchase a new set of phones?
Glad of your help or advice please
Comments:
Jun 27, 2008
- Thank you, I think you have helped immensely and the phones C110 & A110 appear to be behaving themselves at the minute, long may they continue. Unfortunately I have gone out and bought iDECT Q1i x 3phones and was in the process of setting these up, loading the phonebook ec, when my Vtech readjusted themselves. Anyhow, my thanks agiain for taking the time to help,,It's appreciated.
Same Problem
Jul 05, 2008
-   I have vtech Mirage C110 and it starts given two beeps then the two tone sounds.
It does this every 10 or 15 minutes.
I have taken the batteries out to stop the noise, and to make sure it was the handset and not the base unit.
I have put the batteries into a separate charger to recharge.
Is the noise because the batteries are too weak?
Other reports suggest that I should re-register the hand set to the base station, or another (fictious?) base station.
Any help appreciated?-   mtwebster
Best Solution
posted on Jun 26, 2008
Very Helpful)
Ropey
Rank: Apprentice
Rating: 100%, 1 votes
Have strangely got the same problem - about the same time you posted this, but intermitently. I have isolated that the problem is in fact the handset itself, not the base unit. I eliminated a problem with the base unit by a) registering a different DECT phone to it. - The base still works fine. b) Leaving the handset switched off for an hour or so (press and hold the "OK" botton to switch off / on); then whislt it was working, registering the handset to a different base (Base 2). And guess what, after 30 mins the "BASE 2" message started flashing on the faulty handset.
So, if you already have an A110 extension handset, make sure it's also registered to base 1 and maybe try to get just the handset repaired via VTECH. (or just buy a new handset if they are available).
Was this helpful?
Yes
No
Popular Solutions for Vtech 5.8GHz Cordless Phone
Questions and Unsolved Problems for Vtech 5.8GHz Cordless Phone
Do you recommend Vtech 5.8GHz Cordless Phone with Digital Answering System & 4 Handsets?
Answer
Answer
We have vtech 5.8GHz w/digital answering machine. I have changed the battery. Nothing on the base... (More)
Answer
this problem just started recently. no messages were recorded because you will hear the echo while... (More)
Answer
answering system will not pick up when someone calls. keeps ringing until caller hangs up. will... (More)
Answer
purchased new batteries for these two phones with no luck. they already been charging for almost... (More)
Answer
Cordless says parallel set on? Only sound is static/buzz, same with the land line?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Phone Experts
Top Telephone Repairmen
in , CA
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
