Strato LCD TV DVB1901 Does not switch on Red power light instead of being on constantly on standby is flashing perhaps x2 per second Light goes out when power switched off at mains or main power switch Jamie
  • jamie rae13 Jun 21, 2008
    Unplugging for 1/2 hour does not help
    ...Jamie
    how do I check smps ?
  • 3,037 Answers
Most likely a power supply problem although it could be something else. Is there anything that happened that may suggest why you are experiencing this problem. When you try to turn it on, does anything internal try to run? Do you have any audio? If nothing happens at all, the first thing to check and possibly replace is the power supply. You can test it with a meter. Let me know of any further questions that you may have with this and I would be happy to help
good luck
Posted on Jun 21, 2008
  • Benjamin Patri
    Benjamin Patri Jun 21, 2008
    Also, a hard reset for a projection tv is generally 8 hours or overnight in order for the capacitors to fully discharge. I don't believe it will help, but it is worth a try.
  • Benjamin Patri
    Benjamin Patri Jun 28, 2008
    If you are satisfied with your experience here, then feel
    free to provide me with some feedback by rating my solution. If you need any
    more help, I would be glad to assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • 75 Answers
Contact strato customer care.i think it's just a minor problem with the circuit of led lights.technicians should be able to fix it in minutes.
    Genius:
  • 2,035 Answers
There is fault in the tv circuit , LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself. In some cases, you may be able to repair the television set yourself -- or in the worst case you may need to order parts, call a local repair shop to the have a repairman sent out, or even purchase a new television set.
When it shuts off. Try doing what's called a self-diagnostic test.
As soon as the television shuts try these steps.
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
? The flashing then pauses for approximately 1/2 second.
? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
? The Error Code is repeated a total of 5 times.
Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
Self Diagnosic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
  • Anand Kumar
    Anand Kumar Jul 03, 2008
    If you would like to attempt a DIY, you will need a service manual to guide you to trouble shoot SMPS. You can find one here:
    http://servicemanuals.vstore.ca/
  • 4,889 Answers
You will need technical help to identify the circuits in trouble and the correct remedy. The Strato blinking code gives key diagnostic indicators, but still, it will require a tech to dig into that section identified by the diagnostic code in order to find the specific default. If you have experience in electronics then i can get you a schematic and service manual so that you can try fixing it yourself..
Regards,
Sai.
  • eagle338
    eagle338 Jun 25, 2008
    I dont think its an SMPS problem.. SMPS problems wont let the set to power up at all.. Take my word and try Strato technical support..
    Master:
  • 848 Answers
There may be a problem with the smps ....just check whether it is working properly
    Sergeant:
    Champion:
  • 230 Answers
Try hard reset method by unplugging all the cables and wait for half an hour and after that replug all the cables and try .....hope this will help you
    Brigadier General:
  • 3,614 Answers
Did you hear any sounds from the tv..?or any some like problem occur before the tv does not switch on.?
  • micromaster
    micromaster Jun 21, 2008
    the
    double-side board (the one lying flat/horizontal just to the right of
    the vertical power supply board which has the fuses) has a burnt
    transistor (the one with the sizable heat sink on it, at the back left
    corner when looking at the board from the rear of the TV). It is
    blowing the (non-power supply) fuse.
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
Panasonic TX-32LXD60 won't switch on. Red standby light flashes quickly and then becomes constant. TV Clicks and slight flicker then nothing. Can anyone help please ?
U have sound at all?Yes,than ur LCD INVERTER backlight board it dead.If power LED light keep flashing nothing on,sound or picture.Than the power supply board is dead.Must replaced the power supply board.Tries Websites Shopjimmy.com,Ebay.com to buy these refurbish boards.
Feb 26, 2010 | Panasonic TX32LXD60 32 in. LCD TV
The red standby light flashes constantly, we are unable to use set. We have been told to unplug all connection to the set, leave for one hour then restart, we have done this, ITS JUST THE...
You have tried the first thing I would suggest. Next count the number of times the light flashes. It should flash in a pattern approximately one sec apart, then pause 3 seconds and start the same sequence over. The number of blinks will help narrow down the area of the problem. I suspect it is either in the HV section or the power supply. Have you had a power bump recently? Lightning strike? Anyone else in the neighborhood have trouble? Find out the additional information and get back to me and I will try to help you out.
hardrocko
Feb 01, 2010 | Philips 32PFL5403D/27 32 in. LCD TV
My Daewoo LCD TV (DLT-32C3FTB) will not come off standby.
Common problem on power supply board, replace dried out electrolytic capacitors
Apr 22, 2009 | Daewoo DLP3212 32 in. LCD Television
Standby Indicator flashes red 6 times between 2 second intervals
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) five (5) times then there is a two seconds break followed by another six flashes then two seconds break etc. What might have caaused this and what should i do?
Apr 13, 2009 | Sony Televison & Video
TV wont turn on
my TV does the same thing except it is a Sony
KDF-50WE655
Jan 16, 2009 | Polaroid FLM-3225 32 in. LCD Television
Standby Indicator flashing SONY KD-32NX100UWhen I turn the TV on the TV goes straight into standby red light, I press the on button on the remote and the TV comes on for about twenty seconds then it...
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Nov 19, 2008 | Sony KV-35S42 35" TV
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
Electro Med Services...
