Question about Dell Dimension 3100 PC Desktop
USB Ports The two USB ports on the front of my machine have stopped working? The four on the back are fine. Device Manager tells me that they are all working OK? Do you have any suggestions?
  • Tansy Leigh Jun 21, 2008
    Thanks for your input but I have since discovered that one of the 4 pins in the USB port is bent double and causing a short? (The plastic bit is also missing)
  • 67 Answers
RESTORE MACHINE IN BACK DATE
Posted on Jun 21, 2008
Will not come on was working fine before
If the USB port was fine, the unit would come on regardless if the battery was good or not. This is telling me your USB port is loose. We fix these all the time.
Most issues causing this is a bad charger, dead battery or caused by a loose USB port in the back. If the port is loose, the battery will not be charged and won't even work when connected to an external charger. More info can be found here:
http://www.sharc.net/gps_charger_repair.htm
Sep 27, 2013 | Garmin nuvi 1350 Car GPS Receiver
One of my two USB ports stopped working after four years. Any idea how to get it to work again? I have used Troubleshoot - gone into my Device Manager and right clicked on each of four USB hubs, but they...
The one of your usb ports is already out of service but the other port is still active. This happen because of the long term usage of it, but it is only the port got the problem and it is not on the motherboard usb device that is why your computer still detecting it as fine. If it is the front panel usb port then you can check it manually, the connections and the usb board on the front panel. But if its in the back,which in the motherboard then you will have to do soldering if there is any lose contact of the usb pins that are attach to the motherboard. If you can't do this things then take your computer to a computer repair center and there they will help you with your problem. You can also buy an expansion usb card for your computer.
Nov 04, 2009 | Office Equipment & Supplies
This has happened once before and I think Windows XP fixed itself after some time, but I don't know how. While transferring files onto a 4gig flash drive, I got an error message that one file could not be...
I have seen USB ports fried like this, by USB devices. It can render them usesless.
What you can try, is go to the Device Manager, and uninstall the USB ports there. Then go up to Scan for hardware changes. That should automatically reinstall the drivers, in case they got hosed.
If that still does not work, they may be dead. I have seen it where even a device light works, which means there is power on the USB port, but the communications part does not work.
In a desktop PC, you can get an add in PCI card, and route the ports to the front, that is a possible fix for you.
Apr 11, 2009 | Computers & Internet
Keyboard, mouse, front USBs,DVD recorder not working
It sound like your USB Ports is the problem. Go to the Hardware manager delete the USB Ports and then shutdown and power back up.
The system then should reinstall the USB Ports and associated drivers. If not the USB Ports were probably fried by the power outage.
Mar 30, 2009 | HP TouchSmart IQ770 PC Desktop
2 of 4 USB Ports Not Functioning
Most likely a motherboard problem, though you can try and re-do windows, best bet on getting it all to work is Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Though this might really get on your nerves having to do this multiple times, id get a new motherboard.
Dec 26, 2008 | Gateway 4540GZ Notebook
Dell 4600 usb ports not working
Have you gone to Start>Control Panel>Device Manager to see if there are any yellow exclamation marks in front of the usb devices?
Oct 25, 2008 | Dell Dimension 4600 PC Desktop
Usb port ceases to work when any device connected to second port
As you stated the device works in one slot but not the other , tells you there is problem with that usb port , don't use those ports , best thing to do is purchase a PCI USB card if you need more USB ports .
Jul 29, 2008 | Gigabyte GA-8I845GVM-RZ Motherboard
Aspire 3610 USB ports
I think you might have a loose cononection for the data ports. Try putting a little bit of force on the usb device. Up, down left right. NOT ALOT. If it starts working when force is used, i tihnk you should try to take it apart and resolder the connections. If it dosen't work, uninstalling the driver and installing.
Jun 01, 2008 | Acer Aspire 3680 Laptop
Compaq Presario Desktop USB Problem
Go back in to th device manager
Look for the yellow and re-install them
Let me know
Jaywizz
Nov 19, 2007 | HP Compaq Presario V2000 Notebook
Dell Dimension 3100 PC Desktop Logo
184 people viewed this question
Alun Cox
