Monitor PE1231 has started to blow fuses, replace the fuse and its fine for 10mins then blows again replace the fuse same thing happens , when monitor on its perfect.
  • kennethpoul Dec 22, 2008
    Monitor hp 17" PE1231 loose conetion - could be fuse. How do I disasamble it the monitor.
  • 349 Answers
SOURCE: Dell Monitor keeps blowing fuses
well a fuse is a safety feature of all electrical devices ,the only suggestion i can give is to try a different power cable, if it is a detachable one,if that don't work,
you need to take it to an electrical repairer,as it has an obvious fault ,
it is not wise to play around with monitors ((CRT)Cathode Ray Tube) type, as they can retain 10,000 volts in some parts, too dangerous to suggest you enter the case.
if it is an old CRT monitor, it will not be worth the cost of repair.as a second hand one will only cost about AU$20.
good luck
Terry
Posted on Apr 04, 2008
mewms_14904
  • 1027 Answers
SOURCE: I HAVE RELISYS TL766
Generally inside there is a fuse on the power board. This fuse is soldered in on the board. Before taking this apart and testing the fuse or replacing power board or inverter, test the power supply to make sure it is producing the correct voltage and amperage.
If the fields of the "Brick" are breaking down this could also prevent the unit from operating.
Posted on Apr 18, 2008
  • 8 Answers
SOURCE: Viewsonic PF790 19" CRT Monitor
It's about shot! Replace it.
Posted on Dec 12, 2008
  • 58 Answers
SOURCE: ECM BATT fuse keeps blowing
That fuse provides power for the fuel pump. Either your fuel pump is blowing the fuse or there is a shorted wire.
Posted on Dec 21, 2008
Matampong
  • 153 Answers
SOURCE: monitor fuse keeps blowing
There is definately a shorted component that causes the fuse to blow. Nomaly the ceremic capacitors are the cause of the problem. Check to see if there is visiual dark or burnt ceremic caps with label sameting like this "SCK 083" near the fuse area and change it. Hope it helps,cheers.
Posted on Jan 22, 2009
WHAT CAUSES FUSE TO BLOW WHEN DOOR OPENS. I CHANGED IT AND SAME THING HAPPENS OVER AND OVER.
The monitor switch is likely causing the fuse to blow because one of the other switches is stuck in the closed position. If this is the case, replace both the monitor switch and the defective switch.
Apr 24, 2016 | Oster Microwave Ovens
Terrano vg30e electrical issue...
first thing to do is to have the alternator checked out as the fuse blowing may indicate an internal short and therefore the battery is not being charged ( 3 starts and needs a jump)
Dec 05, 2013 | Cars & Trucks
I have a 2004 Lincoln LS 3.0. I recently had the AC compressor replaced. I would drive for about 100 miles then a fuse would blow. I took it back in to the dealer and they replaced the DCCV and various...
sounds like you have a wire rubbing against metal and blowing the fuse. look in owner's manual and see if the a/c fuse only powers the a/c compressor. if it does the bypass the wire with one ran from the compressor to the a/c fuse and drive vehicle to see if it blows again. if it has other things powered by the fuse then check all the wires for rubbed or broken areas.
Jul 20, 2011 | Lincoln LS Cars & Trucks
1999 Chevy Venture 40 amp fuse keeps blowing when I try to start the van. This happened on three seperate days. I drove 150 miles and stopped the van. The could not start the van again. When I try to...
make sure of two things one is any wires touching at the starter to ground or melted and or is the starter drawing too much amperage causing the fuse to blow.starter may have a dead short in it.
Aug 16, 2009 | 1999 Chevrolet Venture
2o amp starter fuse blows
This is a iindication of Hi resistance in your starter, thus starter May be on its way out
Jan 09, 2009 | 2001 Dodge Stratus
Fuse
The Interlock Monitor Switch is an added
safety check on the Primary and
Secondary Interlock Switches. If the
Primary and Secondary Interlock Switches
allow the oven to operate with the door
open, the Monitor Switch will blow the
fuse.
You can get more information about adjuting the interlock switch from this link
http://136.166.4.200/contents/Microwave/LMVM1935xx/LMVM1935xx_Service_Manual.pdf
sections 7-11 thru 7-12 discuss the door interlock adjustment that will cause the 20A fuse to blow if it isn't set up right. I hope this helps you...
Aug 03, 2008 | LG LMVM1935 Convection/Microwave Oven
Computers & Internet Logo
254 people viewed this question
David Payne
David Payne
