Question about Microwave Ovens
Panasonic microwave NNA554W combi
The door wpn't close. The catches seem to be very loose, therefore I am unable to use it. I have a Whatever Happens agreement which expires 18/08/11. I have tried ringing, after endless buttons to press and listening to the ringing tone for several minutes, I am told there is a fault. What can I do?
thistledo@live.com
  • Microwave Ovens Master
  • 9,085 Answers
The door latch heads (the hooklike devices sticking out of the door) should resist you when you press gently up on them.
They have a spring attached inside which keeps downward pressure.
If you can flip the latch heads up easily, then the spring mount inside the door may be broken.
I'm afraid you'll have to keep trying the number for Whatever Happens or call Currys and see if they have a new number for them.
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 29, 2008
Am having some "slack" when opening the latch. Can't see any debris around it. What now?
I have a very old Kenmore microwave. It's latches are plastic, probably Teflon due to temperature. They slide up to catch on
a metal "ramped anchor". I would check for problems with the recessed catches "ramped anchor" or the movement of the catches. There is also a micro switch lever that if bent or out of place might prevent the catch going in far enough. Or something in the door or the anchor have come loose so that it does not completely close.
Mar 21, 2015 | Panasonic NNSN797S Microwave Oven
Panasonic nna554w not microwaving but all other functions working fine
The problem is in the magnetron, or the inverter board if unit is 7 years old or less.
May 23, 2012 | Panasonic NNA554 Convection/Microwave Oven
Panasonic invertor slimline combi
The main fuse in the microwave oven has blown, usually caused by one or two defective door switches.
Mar 30, 2012 | Panasonic Microwave Ovens
DOOR CATCH NOT CLOSING, FEELS LOOSE. ELECTRONICS STILL WORKING - JUST SHOWS 'PLEASE CLOSE DOOR'. NOT SURE IF WORTH A REPAIR OR BUY NEW.
Most likely it is a mechanical problem with door safety switch. Unplug the unit from power! If you take the cover off, you will be able to determine if switch is defective by using ohm meter. You may be lucky and find a broken door latch or loose switch holder - look for lose plastic parts. !!! Do not attempt to bypass safety switch.
Feb 09, 2011 | Panasonic NNA554 Convection/Microwave Oven
Microwave will not stop running when door is opened
The door switch need to be changed. It is probably stucked close. These switches are available at most electronic parts supply.
Jun 30, 2009 | Panasonic Microwave Ovens
Microwave door spring broken
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Jun 05, 2009 | Microwave Ovens
Panasonic NNA554W blows 10a fuse when microwave comes on
Possibly the interlock monitor switch is bad or out of adjustment. This switch is designed to create a short circuit across the power line (and then blow the fuse) if you attempt to defeat the door interlock and operate the oven with the door open. A shorted capacitor or diode could also cause the fuse to blow. Because of lethal voltages inside and the possibility of microwave leakage if repairs aren't done correctly, you are best off leaving microwave service to professionals.
May 15, 2009 | Panasonic NN-SN657SMicrowave Oven
Cracked door on Panasonic S753 combi microwave oven
Hi I have a Panasonic combi oven in between the glass door is misting up should I be worried
Jan 07, 2009 | Panasonic NN-S753 Microwave Oven
Panasonic Micro-combi
You mean it doesn't heat?
Any other symptoms or problems?
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
To order Panasonic parts see http://www.pasc.panasonic.com/epartr ; To download a Panasonic manual see
http://service.us.panasonic.com/operman ; to find an authorized Panasonic servicer, see
http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 ; For FAQs, see http://service.us.panasonic.com/faq/faq.aspx
Aug 28, 2007 | Microwave Ovens
Microwave Ovens Logo
102 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
