Need an ac adaptor for laptop in paducah ky - Computers & Internet
  • naroz Jun 21, 2008
    Thank you for your help! We found an adaptor at BestBuy................great service!!!!
  • 3,940 Answers
To give you a specific answer as to a specific model system, you'll need to post the brand and model of your computer.
Here are a couple of web sites you can check out:,AC-Adapters.aspx
You can also buy AC adapters locally at BestBuy and other electronics retailers.
Posted on Jun 21, 2008
Lenovo laptop(8932) will go into a sleep like mode (you can still see the screen, very dim) when plugged into ac adaptor. Doesn't do it with battery power. Changed system board, power adaptor - no...
Good Day Psmith!
It looks like the AC adaptor is not making the right supply voltage needed for your laptop.
If you have a multi tester, you can test your ac adaptor to see if it has stable 20V voltage output supply needed for the laptop to make it work.
Set your tester to DC range. Plug the ac adaptor to your wall socket. Hold the other end of the ac adaptor (the one you connect to your laptop. Insert the red (positive) lead into the center of the adapter pin, then touch the black (negative) lead to the outside metal part of the pin.
Read the display in your tester. If the adapter is working properly, the meter should read between 19 to 20 volts of the rating. If the adapter is faulty, the meter will read below 18volts.
If that would be the case, I'm afraid you will need to replace your ac adaptor.
You can purchase online a replacement ac adaptor for lenovo 8932.
1. From this site, it costs $34.99 + $8
2. From this site, it costs $39.95
Please accept my answer if this is the information you need.
Don't forget to give a four thumbs up rating!
Thank you for asking Fixya.
Jun 23, 2011 | Computers & Internet
When i push the power butten, the indicator light flickers, then nothinghappens
Firstly remove the battery and disconnect the A.C adaptor. Press and hold the power button for 30sec and then reconnect them back and check.
Check the port where u connect the A.C adaptor pin if the light is glowing then need to reseat the RAM and the Hard drive of the laptop (Compartments located at the bottom of the laptop)
If still not comming on then Hardware issue take it to local store.
But if the port where u connect the A.C adaptor doesnt have light then
1. check with different wall outlet
2. check if the adaptor is getting warm or not if not then replace it.
3. If yes then better check with different ac adaptor
Mar 31, 2010 | Acer Aspire 5100 Notebook
I have a HP dv7 laptop it does not work with the ac adapter but worked with the battery, whenever it is working with the battery and the ac adapter is connected it shuts down.
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
Need a new window kit adaptor for 9000ah
you should be able to find that through a heating and air condition company they should with all the model and searial numbers be able to order it for you
Aug 23, 2009 | Soleus KY-34 Portable Air Conditioner
Keeps powering on and off.
Keep in mind since you cleaned it out, only have the AC adaptor hooked up to rule the battery out. If the laptop stays on with only the ac adaptor hooked up and doesn't shut off then you know that the battery is faulty. If it still shuts off even with just the ac adaptor hooked up then it could be the ac adaptor.
Also check one more thing, with only the ac adaptor hooked up, wiggle the cord where it plugs into the laptop and see if the laptop shuts off, if it does then the dc jack on the motherboard is loose and needs to be resoldered back into place so it stays put.
May 13, 2009 | Dell Computers & Internet
I have a Dell D600 (PP05L), its not powering up no lights. I noticed on the power adapter the green light goes out when plugged into ac power. What could be wrong here? please help
Hook up your power adaptor to ac power without it being hooked up to the laptop and see if the green light stays on. If it does then you know your adaptor is okay. if your adaptor is only hooked up to ac power and the green light still turns off then you know your ac adaptor is bad.
Take out the battery from your laptop. Now hook up the ac adaptor to the laptop and if it stays green then you know your battery is bad but you also want to make sure you can get your laptop to turn on. Hopefully it will turn on with only the ac adaptor hooked up to it.
May 04, 2009 | Dell Latitude D600 Notebook
Ac Adaptor not working??
as u said that when u plugged in the ac adaptor into the laptop it recognises that the ac adaptor is connected but it does not charge the laptop in this case what u can do is that if have the same charger extra then u can try with the another charger and if the other charger also does the same thing then in this case u need to replace the mmotherboard and if the other charger is working fine in this laptop then definately chage ur aac adaptor.....good luck...
Jan 25, 2009 | HP Pavilion dv6000z Notebook
I can't find a color bj cartridge bc-05 anywhere ?
I found here that Office Depot has carried them in your area before, but when I checked availability in your zip code it showed out of stock for now. You may want to either order them online from that link or use the "Check local store availability" link to check availability in your area.
Here is a link to contact information for your printer if you need it. They should be able to give you information on the stores that carry your particular cartridges in your area.
Hope this helps. Please remember to rate this information.
Jan 04, 2009 | Canon BJC 250 InkJet Printer
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
