Stereo CD player/tuner XC-L11 not working at all
Standby light blinks: can't open or close tray, dispay unit dead. All cables correctly connected. What is wrong? How do I fix this?
  • Anonymous Mar 29, 2009
    Just fixed mine - replaced 35v 47uf electrolytic capacitor in awu7837module (inside shield case) - this module connects to display unit. see www.circuitsonline.net/forum/view/14478 for more info and diagramCost - 16 pence from Maplin p/n se47m35 kq68y
    Regards, Dave
    Dave, just fixed mine as you described.
    You saved me money.
    Thankyou
Just fixed mine - replaced 35v 47uf electrolytic capacitor in awu7837 module (inside shield case) - this module connects to display unit. see www.circuitsonline.net/forum/view/14478 for more info and diagram Cost - 16 pence from Maplin p/n se47m35 kq68y
Regards, Dave
Posted on Sep 29, 2008
My CD player will not work on my stereo system and I am looking for a local repair shop where I can take it to be serviced and repaired
Presuming that other sources work okay and the the cables are connected correctly.....Try a CD Lens cleaner.
If that doesn't work then it's time to open up the unit and manually clean the laser lens. If that still doesn't work then the laser might be dead. Replacement parts may be available. Whether or not you can do this as a DIY repair though is questionable. It depends on your skill..
Sep 15, 2014 | Audio Players & Recorders
I need to connect a pioneer amp m-L11 to a pioneer cd player xc L11 - which leads do I need?
It is verry simple to do (Karen) All you need is a (Audio) Patch cord, To connect it up to your amp.
Nov 05, 2012 | Pioneer Audio Players & Recorders
I own an Pioneer CD tuner XC-L11 with a stereo power amplifier M-L11. Recently it won't switch on with the standby button flashing red. After consistent attempts to put it on, it works but when put off and...
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
The service manual is available for free after you register here...
http://www.hifiengine.com/manuals/pioneer/m-l11.shtml
Mar 24, 2011 | Pioneer Audio Players & Recorders
Where do you connect the data cable...on back of the stereo and where else?
The data cable (IP Bus) can connect to several different component designed for your unit, i.e. xm/sirius tuner, HD radio tuner, CD changer, etc.
Sep 17, 2010 | Kenwood KVT-715DVD Car DVD Player
Aux problem
You have to go into the standby menu and turn aux on. Go to standby, push menu button and scroll down to aux and turn on
Aug 05, 2009 | Kenwood KDC-MP235 CD Player
The CD Tray won't open on my Sony MHC-GX250
te same thing happened to me know i juat turn the stereo off to where the red light is blinking then turn it back on after the standby message disappears and then i quickly pree the eject button......tr it! and let me know!
Jun 24, 2009 | Sony MHC-GX450 CD Shelf System
I have a JVC stereo system, cassette, 5 disc cd, tuner, I recently repaired an amplifier problem as one of the output IC's was burnt out. The set works fine if on radio mode. But the cassette and CD player...
I used to fix a lot of these type of units. It wsn't unusual for a wired or ribbon cable to either not get reconnected or not make good contact in it's socket. Also if it was a ribbon cable it good be put in backwards.
Dec 16, 2017 | Audio Players & Recorders
I own an Pioneer CD tuner XC-L11 with a stereo power amplifier M-L11. Recently it won't switch on with the standby button flashing red. Nothing happens after that and the system doesn't work. Could you...
On the first board (where the power enters) there is a tall 3 pronged switch, if you turn the board over and solder a piece of wire to the 2 outside prongs, you will find that the Amp works normally apart from that the display reads Cd closed when in Cd mode.
Aug 28, 2008 | Pioneer Audio Players & Recorders
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Jul 01, 2007 | Kenwood KDC-MP628 CD Player
810 people viewed this question
 Grubhead
Grubhead
