Question about ASUS A7V8X Motherboard
Sound problem theirs no sound and no mixer
  • 90 Answers
Hi buddy!
check if the driver is already install
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on Jun 22, 2008
I am hooking up a Behringer xenyx 1002B Mic/Line Mixer to my Toshiba Satellite c885-S5194 laptop to broadcast online via meridix. I'm using Audio technica BPHS1 Headset Microphones with XLS plugs and 1/4...
IF your Laptop has a stereo LINE 1/8" INPUT jack, you can take the Stereo ( Left & Right ) LINE outputs on your mixer and feed into this jack on your PC. You will need a 1/4" dual plug for the mixer end to a single 1/8" stereo plug on the PC end. I suspect the problem you are having is either related to your PC only have a MIC input jack or you have something set wrong in your PC's sound config. file. More information is needed to properly solve the problem.
Oct 18, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I have a TRV98 Hi8. Trying to convert Video 8 tapes to digital. Sound comes from the camcorder, but no sound coming through the converter to the computer. Using the s-video cord?
An S-VHS cable only carries video signals. You must connect a separate audio cable from the camera to the sound input on your computer. On a Windows computer this would be the Mic input, usually marked in pink. You may also have to make sure that the computer has the mic input turned on, which in Windows would involve the sound Mixer. The standard Windows mixer is accessed by double-clicking the little speaker symbol in the "tray" at the bottom right, but many sound cards have their own mixer utilities.
Nov 17, 2010 | Sony Handycam CCD-TRV68 Camcorder
I want to install a mixer device
Sound options are disabled for Windows server 2003. You have to enable sound and audio services using the "Services" panel. You can install that and then Enable the services. After installing click on Start - > Run -> Type in services.msc and hit enter key. Then scroll the list and find the related Service. Right click on it and go to Properties. Then select "Enable". Set the Startup mode to "Automatic".
Jul 08, 2010 | Microsoft Windows Server 2003 Standard...
Oil leaking from hobart d300 mixer
DEFINITELY contact the manufacturer (Hobart) on that one. Sounds like you're having some sort of an internal problem with it (something might be cracked), and in this situation, the best way to go is to contact the manufacturer rather than try to repair it yourself. If you're still under warranty, and you try to open the machine up to fix it yourself, you could wind up VOIDING the warranty, and if you're out of warranty, most repair places won't touch a machine that you've messed with already--too much of a liability.
Just give Hobart a call, and they should be able to help you (if you're in warranty, sometimes even for free!). Their phone number (according to their website, www.hobartcorp.com ) is 1-888-4HOBART (1-888-446-2278)
Good luck! :)
Aug 27, 2009 | Hobart D300 Stand Mixer
Mixer doesnt send sound to my computer
If you are using recording software you will have to look for Preferences and make sure that the software is detecting your soundcard. You also have to make sure that your PlayControl settings match the input on your soundcard to the ones your mixer are plugged into. You also have to match the RecordingControl which is under Options and then Properties. That is all under Sounds and Audio Devices in your Control Panel under the Volume tab then Advanced. If you have latency problems which makes the sound delayed from the input on your mixer to what you hear from your computer try downloading Asio4all although your mixer should have come with a disk with the proper drivers. If it didn't Behringer has a great support section at their site that has downloads for everything.
Aug 07, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Theres a loud squeaking noise when the mixer turned on
Hi. These mixers normaly make a lot of noise when in operation. Go to the shop that sold it to you, or any place that has these units on display and ask them to turn on the mixer for a demonstration. If their mixer does not make the same noise, then contact Kitchenaid Customer Service and ask for a replacement under warranty. If this solution assists you, please rate it. Good luck! ricardok45
Mar 05, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid pro 600
It sounds like you may have broken the gear in the head of the mixer. I would call this a Advanced fix since you need to press the pin out of the shaft to put the new gear on. The parts are available from online parts stores, and the manuals and part lists are available from KitchenAid HERE.
Oct 25, 2008 | KitchenAid KP2671 Professional 6 Series...
No active mixer's
Hello annointed,
The mixer should have installed during the install of your audio software.
If you have your Acer CD you can load your CD & look for the driver folder & open it. Find Audio or Sound folder.
Re-install your driver software.
You can open the link below that will open Acer's PDF file that contains your audio software. Depending on which sound device you have in your notebook.
Acer sucks at maintaining the correct drivers for their model no#.
Though you can find the Aspire 5570-2609 notebook, Acer does not list their driver's as 5570-269. They only list Aspire 5500-5570. For the 5570 click here & goto pg. 2
Audio driver v.5.10.0.5273
Windows XP AS3680_Audio.zip
http://www.acerpanam.com/synapse/forms/AcerDrivers/Aspire%205570.pdf?CFID=40052&CFTOKEN=54644383
For the Aspire 5500 goto this link:
http://www.acerpanam.com/synapse/forms/AcerDrivers/Aspire%205500.pdf?CFID=40052&CFTOKEN=54644383
Page 2.
5500Z - Realtek Audio Driver v5.10.0.5820
Windows XP
AS5500Z_Audio.zip
Mar 14, 2008 | Acer Aspire 5500 5570-2609 Laptop
Kitchen aide mixer
was the bowl snapped in to place.....push down on the back lip of the bowel until you hear it snap
Dec 30, 2007 | KitchenAid KSM5PS Heavy Duty Stand Mixer
ASUS A7V8X Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
