Question about Car Audio & Video
Demo Mode JVC KD-G333 head unit
When ever I turn off the ignition and back on the unit is back in demo mode
although I turn this off each time. The radio presets remain but all other setting don't.
I have it fitted in a 1993 fiesta and it is wired as follows
Yellow Battery
Black Gnd
Red Red(pemanent live ?)
Any thoughts please
Thanks John
  • 1 more comment
  • 126dodger Feb 14, 2009
    I have same with KD G322
  • Anonymous Feb 25, 2009
    I have the same problem, the cd player is fitted with an ISO connector, everytime I turn off the ignition, the demo mode reappears.
  • Anonymous Apr 01, 2009
    Exactly the same here... I suspect that either the harness adaptor or the Steering Wheel remote adaptor (purcheased from Halfords) does not have the "unswitched"power supply connected properly.
    ie. when the ignition is switched on, all works OK, but when the ignition is switched off, all setting are lost as there is no longer a power feed...
    If only I could get hold of the wiring diagram for the KD-G333 rear connectors...
Hi guys, I had this problem and i just found a solution.
I was on FM mode when i tried this:
Hold down "sel" until the display says "demo"
Turn the volume knob and the display will toggle between "demo on" and "demo off"
I went back to CD mode and the blasted demos no longer appear!
Posted on Jun 16, 2009
Most of the JVC head unit you have to enter the menu to turn the demo mode off. I have the HD50R model, and the way I had to do it was, hold down the menu button (will take you menu mode), first option was the demo, selected the demo by pressing the volume button, then using the volume button again, scrolled it to off and press the volume button to accept changes. To exit out of the menu mode press the menu button and will take you back to play mode....
I can't say this method will work with your deck as you didn't list the model of your HU. But give it a try???
Apr 05, 2011 | JVC Car Audio & Video
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
How do you turn off the demo mode on a JVC KD-G230, Car battery died and now it shows the time, pop, jazz, etc., as it is in demo mode and it is driving my crazy.
I held down the sel button until demo showed on the screen. Released the sel button. Turned the volume control to left or right until it said Demo Off then hit the select button again.
Dec 09, 2009 | JVC KD-G230 CD Player
How do you set the clock on a jvc kd-g230 car radio
There is a misprint on manual concerning setting the clock. This is the case for similar JVC mobile head units.
The proper way to set the clock for this unit is:
1.)Hold down 'SEL' button count to 3 seconds
2.)Immediately after release of 'SEL' button hit the '>>|' button
This will allow you to enter 'PSM' menu. Every time you press '>>|' it will cycle between, 'CLOCK HOUR','CLOCK MINUTE', and 'Demo' Mode.
3.)Adjust settings by using the 'turn knob' and make sure 'Demo' mode is set to 'Demo Off' for the clock to stay set.
Nov 17, 2009 | JVC KD-G230 CD Player
Stuck in demo mode. how do i change it?
Hello jayme84,
To cancel "DEMO" mode on the JVC:
Enter the PSM (personal settings mode) and turn DEMO off.
1) Press and hold "SEL" until the display changes.
2) Use the left/right rocker switch until "DEMO ON" is displayed.
3) Turn the volume knob to select "DEMO OFF".
4) Press "SEL" to exit.
Hope this helps.
Apr 28, 2009 | Car Audio & Video
Stero stuck on demo mode, cant remember how to turn it off. it is a jvc kd-g240
You will find the demo mode in the settings menu. It's options will be on and off and are reset to default each time power is disconnected from the unit.
1st, hold the "SEL" button
2nd, use the left/right arrows to select option "Demo"
3rd, turn the volume knob until "OFF" is displayed
Then, lastly, press the "SEL" key once more.
Here is a link to the pdf document for the instruction manual off the JVC website:
Aug 10, 2008 | JVC Car Audio & Video
My cd player in demo mode how i change it
Press the Selection button about 3 seconds
When the Demo On mode appears
Turn the VOLUME dial until Demo Off appears
Press the Selection button again to get out of this mode.
Jul 26, 2008 | JVC KD-G120 CD Player
JVC KD-G322 Demo mode
Hold down the "SEL" button, and use the CD track skip button to scroll to where the display says "DEMO," and use the volume knob to change the setting to "OFF." Push SEL again and you're good to go.
Apr 03, 2008 | Kenwood KVT-617DVD Car DVD Player
Displaying time ALL the time
It sounds like its stuck in "demo mode" Look for a user menu for making clock changes,illumination etc...and turn off the scrolling demo mode...
Mar 21, 2008 | JVC KD-G110 CD Player
Car Audio & Video Logo
2,506 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
