Question about Bosch Dishwashers
Bosch classixx dishwasher when we switch on the machine is continously draining and even when we open door it does not switch off . it seems to be float valve but how do you fix this thanks julie
    President:
  • 1,462 Answers
There is a float switch in the base so that if water gets in then only thge drain pump operates. if you tilt back at 45deg, then water will come out and the machine will operate(swiotch off elec when you do this)
if it reoccurs then you have a leak
Posted on Jun 21, 2008
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch washing machine does not do the complete cycle
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx 1400 Express does not start at all, does not fill.
fit new door interlock switch ..Take note of wiring 1st//
Oct 04, 2009 | Washing Machines
Bosch dishwasher with these numbers inside door
i solved the problem by going to bosch uk website and one of the numbers came up when i went to download instruction manual
so that solved problem. thanks for your help.
Sep 17, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch Clasixx dishwasher sticks at point when it drains water
you have a clog remove the float clean and replacs,sould work now.
Jul 15, 2009 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not draining after a power cut
I would run the heated dry cycle a few times to try and get rid of that residual water, then restart the cycle and see if it work now. If it still is a problem try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Water leaking from dishwasher
check the hose in the back to see if it split could be dry rotted
Jan 09, 2009 | Bosch 24 in. SGS43C12 Classixx...
Pump continues to run
make sure you dont have water sitting under dishwasher in tray. it can cause pump only to run. If there is water in bottom, look under water valve, there is a float-is it surrounded with water?
Jan 01, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwashers Logo
186 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
