Question about Samsung SyncMaster 17 in. LCD Television
SAMSUNG 170 MP LOCEKD-UP
I just got a used Samsung 170 MP with out the remote, and all the menu options are locked. I can not even change the channels or adjust the contrast. Is there a way to reset or un-lock everything without the remote ??.
  • smrj Jul 28, 2008
    Thank you, that did the job. it looks like it did not work while it was on the tuner option, but when i switched it to VIDEO, i was able to change stuff, then switched to tuner and BINGO. Thank you again, even my TV repair man could not fix it.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
On the front panel press the Menu button for about 5 seconds. Once you press it the OSD will pop up. Keep holding the button until the OSD disappears. The setup should be unlocked now.
Posted on Jul 26, 2008
Where can i get the living solutions jumbo universal remote code for the samsung syncmaster 1701 mp tv
You should use the search remote code feature:
  1. Hold the device button you want to program for 3 seconds & release.
  2. Push & release the power button & the red light will remain lit.
  3. Push the CHANNEL UP button over & over slowly until the device turns off.
  4. When device turns off press OK button.
Hopefully that works for you.
Jan 07, 2015 | Samsung Televison & Video
Samsung hl-s6767w timer reset. Can I reset using the menu option located on the tv. I have no factory remote
Yes, you just have to toggle manually using the plus and minus key as well as the channel up and down keys to navigate the menu
Nov 17, 2013 | Samsung HL-S6767W DLP TV
Remote for samsung 172 locekd on screen
my remote for samsung 172 miss and othre remote
Feb 02, 2011 | Samsung SyncMaster 172MP 17 in. LCD...
I have a Samsung LN55B650, and cannot use the remote to change channels, hav eto use cable remote. I change to TV mode, and program in channels, but that option is not available once I switch to HDMI2,...
OK the cable box remote is the only one that can change channels in this case. because you are using the tuner in the cable box not the TV.
all you need the TV remote for is to turn the TV on and off and turn the sound up and down. if you used the cable input on the TV then the tv remote would be used to change the channels.
Dec 25, 2010 | Samsung LN55B650 55 in. LCD HDTV
Cant access the digital menu since the digital change over. Still recieve analogue channels 1 to 5 samsung lcd tv model LE32N73BDX
Hello Gregor_69
Lets see if we can get you sorted out. Please follow my steps and you will be back up and running in no time.
with you samsung remote make sure you press the TV button so that we are on a TV channel and not one of the other inputs.
Then press MENU
down to CHANNEL
go to AUTO STORE
you should find two option on there 1. air 2. cable
You want to highlight the air and START.
it will now give you 3 option
Digital & Analgue
Digital
Analogue
highlight the Digital option and START.
This will auto tune just your Digital channels. Once this progress bar has finished. You should find that all your Digital channel have returned to normal.
I hope that this has helped you out. If so then please leave a thumbs up
Cheers
Little Dish Fitter.
Oct 11, 2009 | Televison & Video
Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Oct 03, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Samsung LE26R Digital Frozen
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jun 04, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Samsung SyncMaster 17 in. LCD Television Logo
413 people viewed this question
Jerry Greenberg
Jerry Greenberg
