Question about Garmin nuvi 350 GPS Receiver
Won't acquire sattalite
Although the unit is on it displays that the GPS is off in the unit.
  • nuvi350 Jun 26, 2008
    Turn on the unit it worked all right for 5 minutes all the sudden it show lost satellite and it stay that way for the rest of the trip.it happenned in the last 4 out of 5 time of used .
    Scholar:
  • 174 Answers
Have you checked webupdater and/or reset the gps yet? there is a small button on the bottom or behind the aerial
Posted on Jul 23, 2008
Greetings . . . I turned my Garmin 2720 on in my
Take the GPS out of your van to an area with a clear view of the sky. Power the unit on. If the unit is working correctly, then it will acquire the satellites. You can then put the unit back in your van. You may have to reposition the unit to keep the satellite lock.
If the unit does not acquire satellites outside, then the unit is defective.
Mar 03, 2017 | Garmin StreetPilot 2720 GPS Receiver
My nuvi is fully charged, the touch screen is fine, it has the correct time etc, but it won't acquire satelite signals - why?? help!!
There is a component that is well known for failing in the flip-up antenna/GPS receiver. Please see this link for more info on this problem. We can repair your unit for you.
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Sep 18, 2011 | Garmin Nuvi 660 GPS Receiver
Updated unit and still acquiring satelites is showing, what can i do?
If your unit is still acquiring satellite, then it means the signal strength is weak, try to get it outside where it can be facing the sky directly so it will be able to acquire satellite. Once you just update your gps receiver, it seems like it is brand new and when it wants to first acquire satellite, it might take longer to do so. But if it has access to the sky directly, it should take about 3 to 5 minutes to acquire.
If your unit is indoor, it may not acquire satellite, even if it is close to the window, it will not, but if it is outside, then it will acquire faster.
Check if you have any protective coating on your windshield or electronic devices which interfere with the unit from receiving signal from the satellite. Try to see if your gps receiver can use an antenna, then connect one to it and your gps will acquire satellite.
Try to reset your gps first before trying any other solution for the unit.
Dec 23, 2010 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 says trouble tracking satelites, not acquiring signal. what to do?
If your StreetPilot c300 or c500 series device is no longer acquiring satellites please read the article linked below to ensure that this is not being caused by something in your environment:
Why won't my unit acquire satellites?
If after reading the above article your unit is still having problems, please ensure that your unit's software is up to date. You can do this by using our WebUpdater® program.
If you have tried all of the above suggestions and your unit is still not acquiring satellites, you can perform a master reset by doing the following:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit powered OFF and unplugged from power.
  2. Touch and hold the bottom right corner of the touchscreen.
  3. Power the unit ON and continue pressing the screen until a new message displays, "Do You Really Want To Erase All User Data?".
  4. Touch Yes and go through the set up again.
Take the unit outside and let it set with a clear view of the sky for 3-5 minutes to acquire satellites. If the unit still does not acquire satellites after this, please contact Garmin Product Support.
Nov 17, 2010 | Garmin StreetPilot C330 GPS Receiver
I am having trouble getting location. Even when I get good satelite coverage (many showing on the screen) No location shows. It also seems to be slow in acquiring upon power up. How do a restore the units...
Hi!
i checked out the Garmin owner's manual for your GPS:
http://www8.garmin.com/manuals/eTrexVista_OwnersManual.pdf
On page 6 it explains that from the satellite page there are four options from which you can choose;
1) Use with GPS off
2) New location
3) Restart search
4) Continue acquiring
If the date displayed on your unit is NOT today's date, select "Restart Search"
Since the GPS does NOT lose memory when the batteries are removed, the problem is unlikely to be that the GPS doesn't know where it was used last.
If the displayed time for your area is not correct, use the main menu to access the setup pages and follow the instructions for setting the time found on page 49. This SHOULD get you on your way.
May 02, 2010 | Garmin eTrex Vista GPS Receiver
GPS wont aquire a satellite
    Hello there and happy new year
    If Your Unit Cannot Acquire Satellite Signals
  1. For your Garmin GPS unit to acquire the satellite signals it needs to function properly, the unit must be taken outside, away from mountains, tall buildings and heavy foliage where it can get a clear view of the sky. Keep the unit stationary for several minutes while the GPS unit acquires the necessary satellite signals.It may take several minutes for the unit to locate a good solid signal
  2. OK
  3. Hope this is very helpful please keep me posted on this ok?
    Best regards Michael
Jan 01, 2010 | Garmin MAP76 handheldS GPS Receiver
The unit keeps displaying "acquiring signl" - what does this mean?
Your unit is trying to locate the satellites for location fix. If it cannot acquire the satellites in couple of minutes, you should move to a place where the unit has clear view to the skies.
Dec 26, 2009 | Magellan RoadMate 1340 GPS Receiver
Nuvi350 doesn't locate any satillites. What can I do?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
Jul 11, 2009 | Garmin nuvi 260W GPS Receiver
Garmin 260w won't acquire satellites
Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
Failure to acquire satellite
To reset the unit, pry off the silver faceplate.
Turn the unit on using the power button on the right side.
Press the reset button that was hidden behind the face plate.
The GPS unit should restart, and display its software version.
Make a note of the software version in case you have to call customer service.
To acquire satellites make sure the GPS has a clear view of the sky.
For Garmin customer service, call 800-800-1020.
You can also go to this link for complete customer service info:
Garmin Customer Service
Good luck, please rate this response favorably.
Jan 24, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
