Question about Philips Vacuums
Equaliser settings for general tv viewing for a philips 32pf5521d
    President:
  • 1,673 Answers
Hi, sorry but you posted this in the vacuum cleaner repair section, please repost it in the correct repair section.
Posted on Jun 21, 2008
DC 17 parts view?
General 'putting it together or checking for blockage' user manual is here: (
https://www.dyson.com/medialibrary/Files/Dyson/Support/downloads/US/Floorcare/manuals/dc17_opmanual_usa%20pdf.pdf ) If you want a full exploded part cloud, one set of examples can be found here
PartsWarehouse com which also is one of several spots to find replacement parts (can't suggest a specific one since it's not clear what you need the parts view for)
Good Luck!
Jul 07, 2014 | Dyson Vacuums
Need 1-800 number for philips breadmaker to order parts
You're going to want to call the number below: Good luck! William
General Support
1-888-744-5477 Monday - Saturday 9:00 AM - 9:00 PM EST Sunday 9:00 AM - 6:00 PM EST Excluding Major Holidays
Feb 28, 2011 | Vacuums
Bought a Philips Voice Tracer LFH0646 and require access to the user manual.
You can download and print the manuals in PDF format by clicking these links.:
User manual
Quick start guide
Adobe PDF Reader is required to view the manuals. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manuals.
Thanks for using FixYa.
Feb 12, 2011 | Philips Vacuums
How do I switch from blowing to sucking
Just took a look at the exploded view for this vacuum and I think there is no way to set it up to "blow" air out of the unit via a hose. On a lot of the vacuums of old there was an input hose port and an output (blower) hose port. Many of them these days, such as yours, exhaust the air in a general manner as opposed to a port that a hose can be connected to in order to act as a blower. Looks like you can only use it as a vacuum.
Oct 02, 2010 | Black & Decker UV200 Wet/Dry Vacuum
General assembly for bissell proheat shampooer
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
6wywe
Jul 23, 2010 | Bissell 8910 ProHeat Clear View Upright...
The lights which tell you if you are going at the right speed on my Bissell PROHeat Pro-Tech have stopped working. Just wondering if this could be as simple as a bulb or more serious. Also, how do you...
I have this same model and never noticed the lights telling me the "correct speed" learn something new everyday....
the clear plastic hood removes with a few screws connected to the base at the bottom. the top part snaps out. :)
Mar 26, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
I would like to see how to change the belts on the bissell 8910 pro heat I have looked for hours now. I saw the book but it mentions and shows nothing on how to replace them. Help please.
turn the vacuum over so that the bottom side is facing you, remove the 4 screws on each side using a Philips screw drive set the screws and the brush cover aside.
- pull brush straight out and you will see the gray rubber band.
-replace the new drive belt over the motor pulley and the floor brush.
-replace the floor brush by lining up with the slots and rotate untill centered , install the cover and screws . done your back in action.
Hope this helps.
Sep 05, 2009 | Bissell 8910 ProHeat Clear View Upright...
I need general instruction for my bissell carpet cleaner
Here's a link to the manual on Bissel's site:
http://www.bissell.com/images/UserGuides/7901_1008.pdf
Dec 11, 2008 | Bissell 1699 ProHeat Clear View Upright...
I am trying to take my philips vision 8731 vacuum cleaner apart because a heap of c*** got sucked into the motor when the bag was not put in correctly. I have removed all visible screws but cannot for the...
Generic problem for all Vacuums
I am trying to take
I am trying to take my Philips vision 8731 vacuum cleaner apart because a heap of c*** got sucked into the motor when the bag was not put in correctly. I have removed all visible screws but cannot for the life of me find how the wheel end comes apart. Any tips?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I believe the part you are taking about is the fan and the fans generally are installed by a reverse thread and screws off counter clock wise. Once you removed the fan or the wheel you can use a blower and blow the motor clean, remove the carbon brushes and use a pipe cleaner to clean out the carbon brush holders and then re-install. Also free to contact your local vacuum cleaner dealer in your area or in the yellow pages under vacuums.
Apr 22, 2008 | Vacuums
Need page 18 overhead view of base
Here is a link you can try, http://partner.bissell.com/images/partnerimages/PowerSteamer%20wiring.pdf
This a general over view of their power steamers. If this is for Model 1699, then this picture should work for you. Bissel doesn't have very much in the way of past repair guides. If this is for a different model let me know and I will see what I can find.
Jan 03, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
Top Philips Vacuums Experts
Mack Baxter
Are you a Philips Vacuum Expert? Answer questions, earn points and help others
