Question about IBM ThinkPad T30 2366 Notebook
Matrix Style Lines
I Tried to connect an external monitor, on boot, matrix like grid lines appeared still, (on the external monitor). This means it must be something inside the laptop?
Any ideas?
This is my only real source of work.
Right now i'm using my home made server to communicate with the the world which isn't the best solution.
    Guru:
  • 859 Answers
Yes, this could be a property value set in your display. Go to Control Panel, Display and hunt through your display adapter's advanced settings and see if there is a check box for display grid and turn that off.
Regards,
Worldvet
Posted on Jun 21, 2008
I tried to clean the dell vostro 1014 fan, after i assembled the fan and turned on the laptop it appear black screen with dim image on my laptop screen, When I plug in external monitor it shows boot s
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Mar 20, 2014 | Dell Vostro 1014 Laptop Computer
MONITOR HD2200. I TURN IT ON AND THE SCREEN GOES WHITE THEN A FEW VERTICAL COLOR LINES APPEARS AND AFTER A FEW SECONDS IT GOES BLACK.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out in solving the problem....
May 21, 2011 | Gateway HD2200 LCD Monitor
BLACK LINE on screen and see-through Pink Bar!
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 12, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Ive got green lines running down the centre of laptop
Just want to know if the lines only appear in windows? try booting in bios setup check if the lines still appears. if not then uninstall the video driver then install latest version. if the lines appeared in all occasion then test laptop using an external monitor toggling the display Fn + F8 if no lines in external monitor replace you laptop lcd panel and lcd cable + inverter. if the line appeared in external monitor replace the mobo or video card.
Mar 22, 2010 | Dell Inspiron 1501 Notebook
Toshiba Satellite P105-S6124 Screen lines
Are these lines on the screen during the whole boot process? If so then the screen cpu and/or the video cpu has gone bad. Connect an external monitor. If the picture is clear, no lines, then the problem is the LCD screen. If the lines appear on the external monitor during the boot process then the mother board will need replacement.
Good Luck
Mar 22, 2009 | Toshiba Satellite P105-S6124 Notebook
Colored lines on screen
This may be caused by the death of a display driver circuit and these might be integrated with the display itself.
The pixels on the screen are controlled by an X-Y matrix and the matrix may have signal lines that are somewhat shared for different screen positions.
I doubt that this is DIY project and the failure can only be located by an equipped and trained tech.
Feb 02, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Screen
Problem with motherboard display unit.you need to repair the unit.
May 28, 2008 | Computers & Internet
Screen prolem
try to lose the screen then make some clleaning n couple it back if it doesnt work, then suspect the connector
May 28, 2008 | IBM ThinkPad T30 2366 Notebook
Laptop Toshiba M50-MX2 - Celeron M - Grid lines at the bottom of the screen
how do i restore my computer back to its factorey settings and deleat everything else
Apr 19, 2008 | Toshiba Satellite M50 Notebook
1 vertical line going down the notebook LCD
Some of the many connections to the TFT screen panel matrix itself have have either been damaged or have decayed. These tiny connections are bonded along the edges of panel and are not viably serviceable. The most common causes are impact, stress (twisting) and condensation/moisture ingress. A replacement screen panel is needed.
Dec 16, 2007 | Compaq Presario 2100T Notebook
IBM ThinkPad T30 2366 Notebook Logo
63 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
