I installed an additional hard drive in my laptop. The computer will no longer boot up. I've read the the BIOS needs to be changed by I don't know how.
  • 144 Answers
Please tell me which Motherboard your system has???
If you have added an additional drive, check whether you have set the jumpers right for master/slave/cable select configuration.
If you bios setup to boot up from first HDD, then the bootable HDD shall be in master mode. Configure bootable HDD as master & additional one as slave.
If still no luck, Put this additional HDD on other IDE slot.
Tell me if this works...
Posted on Jun 22, 2008
My lenovo got a new harddrive and won't boot at all not even bios what to do? It's a g 560
You have to recover your MBR looks like, but first you need to remove the hard drive and see if it will boot without the HDD installed then get back to me ok. Also sounds like the BIOS may have failed if it wont boot without the HDD installed. But first things first.
Apr 04, 2015 | Lenovo Computers & Internet
I have an HP Pavilion a4000. It just stopped working a couple days ago. Display just rolled up and quit. I've been through everything I know how to deal with. When you push the power button it
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Jan 18, 2013 | Computers & Internet
Need to reboot my toshiba satellite L750D laptop with Windows 7
Dec 05, 2012 | Toshiba Computers & Internet
Motherboard for hp pavilion xt963 is there away to tell if its bad
It's very possible that your hard drive is dead. If you get a prompt when booting it such as F1 then the motherboard is working (so far), therefore it means the BIOS is ok and also that your CPU is ok if not nothing will show on your screen. If pressing F1 gives you boot options then select CD. If it won't boot from your CD force it by actually going into BIOS setup and selecting CD as primary boot drive then press F10 to save. (if BIOS setup options don't show when booting try pressing F10 or F8 and any other function keys after F1.
Make sure you have the installation disk. If the PC still doesn't boot or detect it you should try another CD/DVD drive, yours might be bad or buy or borrow a DVD/USB external drive and select it as boot drive in BIOS. Often I've seen that when booting if either the hard drive is bad or your operating system is corrupted it will prompt F1 because it cannot detect either. If OS is corrupted you will be unable to get to safe mode especially if the hard drive is bad, the recovery partition is on that hard drive and safe mode is a Windows program not BIOS.
After you've tried connecting a different CD drive to install your OS you should be able to at least see the Windows installation or whatever operating system you use asking to begin installing. If the installation fails then we move on to the hard drive; take it out and put a new one then try again.
If none of these help then there might be a circuit shorted out on the motherboard which can cause some things to work but not others although this is rare. Lastly I don't know what you meant by USB in your question because unless you have a bootable USB drive the system isn't going to do anything with it anyway.
By the way someone here mentioned RAM memory. BIOS should still show even if your memory is gone but some systems are quirky so this needs to be tested as well. I could go further if you had posted your system's specifications such as how many sticks of RAM you're using. Try dusting off your the inside of your computer with compressed air. Dust acumulation tends to cause weird behavior on a computer.
May 14, 2012 | Intel Motherboard
My hp pavilion dv7-4285dx has lost everything, os and all. How can I get it to read the recovery disc I ordered from HP?
What makes you think you've lost everything? Unless you specifically instructed your computer to Format the hard drive, I would doubt very seriously that you have lost everything. Everything might still be there, but a virus has hidden it to make you think you've lost everything. Oh, one more way to lose everything is to interrupt a System Recovery before it completes, or interrupt an Fresh Install of Windows before it completes.
A lot of times the System will think you've lost everything because somehow a setting the bios was changed either by you or some virus and it has set the hard drive where it is not detectable. Turn your computer off then watch the screen to see which key you have to hit to get into the BIOS or SETUP or System Setup.
Once you are in the BIOS scroll through it looking for AHCI that will be associated with disk drives or disk controllers. If it is Enabled, Disable it and Boot your machine. If it is Disabled, Enable it and Boot your machine. In other words just change the settings for AHCI.
Do that and report back.
Mar 22, 2012 | Computers & Internet
PXE-61: Media Test failure, check cable
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 11, 2012 | Toshiba Satellite M45-S269 Notebook
Install english Windows XP on Japanese Panasonic CF-Y7. Simply insert OS CD and reboot does not help. Computer does not read CD.
The BIOS is probably configured to look for a bootable operating system on the hard drive before it looks at the CD drive. When you first turn on the computer, you have to hit a particular key to enter the BIOS setup (I don't know what it is for your model, but for most of the Japanese models I've seen it's the delete key. The startup splash screen should tell you what key it is. You have to hit the key before the splash screen goes away, otherwise it's already booting up from the hard drive.
Once you get into the BIOS, you can select the boot option page and move the CD drive up above the hard drive in boot priority. If the OS is in the Japanese language, the BIOS text may also be in Japanese. You can probably download an English-language BIOS firmware update to change that.
Oct 22, 2011 | Panasonic Toughbook y7 Notebook
I brought a new hard drive for my laptop .....my computer is not reading it ....I know the hard drive is blank. but how do I load information on it?
Try this.
Plug in the Hard Drive to the computer, then put your Windows disk into the disk drive. You'll also need to enter the BIOS when your computer boots up and set it to boot from your disk. There should be an option that says "Press X to enter Setup" when you turn on your computer. (X being F1, F2, DEL, Etc.)
Once the BIOS's Boot Sequence has been set to boot from your disk drive, reboot the computer. It will eventually tell you to press any key to boot from the DVD. When it boots from the Windows disk, you want to set it to do a Custom Install. There should be an option in there to perform a clean install of Windows. Format the Hard Drive first, then create a new partition and install Windows on that drive. If you have more than one HDD, make sure you don't format the wrong one or you will lose all your data.
If you need additional information, return to this page and I'll be happy to assist you further.
Regards,
Aaron Busch Senior Technician of LiveFix Support Services (LiveFix.net)
May 02, 2011 | Gateway 7330GZ (890552601318) PC Notebook
HARD DRIVE DOESN'T READ ON WINDOWS 98
Two possible reasons:
1. Since the Win98 PC hasn't been used for some time, it can be assumed that somehow the CMOS/BIOS has reverted to default values including its recognition of what HD is installed (or in this case failure to recognize the HD). What needs to be done is the let the PC detect what HD is installed. To do this, on most PCs you need to press "Del" key on boot up (when prompted by a bottom screen display of "Press Del to change BIOS values".... or something like that. Somewhere, there should be an option to manually detect the HD, save setting exit, reboot.
2. If the above does not detect the HD and boot, it may be that the HD has suffered physical/hardware fault such as stuck spindle motor or something else. In some instances, it maybe the IDE cable or even the 4-wire power connector.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 31, 2008 | Computers & Internet
Hard drive stops booting
Hi, If your computer stops booting from the hard drive and is asking for a boot disk, then: 1. The motherboard/PC is no longer recognizing the hard disk; 1.1 Go to your CMOS/BIOS setup and manually detect the hard disk, save & exit. 2. The CMOS/BIOS is set to boot from other devices such as CD, FDD or USB but not from the HD. If after configuring the CMOS/BIOS and the hard disk is not recognized, then it is probably defective and therefore need to be replaced. If the hard disk is recognized but will not boot, then some files of your OS needed to boot are missing, corrupt or overwritten. You would need to re-install your OS and opt for a "repair". Hope this be of some help/idea. Post back how things stand or should you need additional information. good luck and kind regards.
Oct 01, 2007 | Fantom Drives EXT HD 80GB| MTT80 RTL Hard...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
