Question about AEG Lavamat 74640 Front Load Washer
Rubber gasket Hello Benimur, Any suggestions on removing and replacing the rubber gasket? Thanks so far! Hans Peter
  • gryh Jul 16, 2008
    I have a AEG Lavamat 1230, and I also need to replace the rubber gasket, because the original one is chipped and is leaking. I have the new part, but am having a hard time to remove the old, and put in a new. Is there anything that has to be removed from the machine to loosen it?
    Brigadier General:
  • 6,966 Answers
Hi again,
Rubber gasket due to their function would be tight fitting, you may need to force it out. Often it would have a lip or locking protrusion to keep it in places. The hard part is being able to remove a portion of it off the framework and the rest will follow.
Posted on Jun 21, 2008
  • Louie  Role
    Louie Role Jun 21, 2008
    A flat screwdriver may help but you must be careful not to cut or "wound" the rubber gasket. Force the screw driver between the rubber gasket and the metal part until a space is seen, thereafter manually pull out the gasket. Pls check if the gasket has a notch somewhere. Some models have gaskets with notch r marking to indicate which end/side/part goes where.
Replaced water filter but water won't come out unless I physically push the filter in it seems like the filter is not all the way in but it is any suggestions thanks
Hello Dean;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is on a label on the inside wall of your fresh food (Refrigerator) section near the top.
There is a check in the water filter housing.
1.) Bad Check Valve?:
a.) Remove the water filter.
b.) Place a towel under the water filter housing.
c.) With the door open, hold the refrigerator light switch in and have someone use the water dispenser.
d.) Observe for leakage.
2.) Water Filter:
a.) Inspect to ensure there is a rubber O-ring on the stem of the water filter.
b.) Check the length to the stem on the water filer to see if it matches the old filter. Sometimes water filter substitutions do not fit.
Once again, I do not have your model number and these are things that I have experienced in the field.
May 13, 2015 | Refrigerators
How do I replace gasket in toilet tank that leaks ? Thanks
the water closet is attached to base with a couple bolts that have rubber washers, take them out and remove the closet from the base, you will then see a rubber gasket that fits between the pieces. After replacing the gasket reassemble the pieces and be careful not to over tighten the two bolts that secure the top and bottom.
Jan 26, 2015 | Home
Samsung SLR550DW - replace the freezer door gasket
Hello Kev;
The number that you have provided is your general manual number, which is common to several different models.
Your model number is on the upper inside wall, on a label in your fresh food section.
I have replace many a gasket. Post your model number and I will be glad to help you.
Dec 23, 2014 | Samsung Refrigerators
The door liner is cracked and broken the the fridge works great i would like to replace it where do i get a new one
Door rubber gasket is available with any fridge dealer retail shop. And also easy to replace.Below the gasket there are screws. Unscrew and fix new rubber gasket after removing existing one. If you can't call repairman. Matter of 2 to 3 hrs job. Thanks.
Jan 23, 2011 | Refrigerators
Replace boot gasket
Hello, Remove the door hinges and plastic covers on the unused hinge screw holes on the opposite side of the door opening (door is reversible, so there are places to mount hinges left and right). Front panel will now snap out at top and lift off lower spring clips. One screw on each side will now release top panel and it will hinge up. Prop up with broom handle or something. Now you can get at everything. Rubber gasket is held onto drum with a cable loop and very strong spring. It rolls off the lip easily to disassemble but is VERY difficult to get back on without special tools or at least two people. Door side of rubber gasket is easy in comparison with rubber tabs inserted into slots and working the gasket into a groove. Hose clamp at bottom of rubber gasket to connect drain hose.
Thanks
Jun 10, 2010 | GE WSXH208A Front Load Washer
Exahust manifold gasket, how to replace?
Hello;
The difficult part in changing manifold gaskets is getting to the bolts. It is not difficult. I jack up the vehicle and place on jack stands so I can work above, below and through the fender well. The drivers side will pull out far enough to replace the gasket without haveing to remove the manifold. You should inspect the surface for straightness. Tools needed are socket wrenches, box end wrenches and a pry bar.
Good luck and rate me highly.
Thanks;
Rich
RPM Northwest
May 05, 2009 | 1999 Chevrolet Blazer
Repaired!
congratulations, it may help you if you use a bit of water with a bit of detergent as lubricant when snapping back the rubber gasket in place.
Jun 21, 2008 | AEG Lavamat 74640 Front Load Washer
AEG Washing Machine: Door won't close
Hi again,
Any updates/development with your project?
Replacing the rubber gasket on Kenmore elite HE 3t
probably some rubberize installation are screw to the case or body/ you only need pollout are screw driver philips or flat .
Jan 01, 2008 | Kenmore Elite 45986 Front Load Washer
AEG Lavamat 74640 Front Load Washer Logo
188 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
