I have a Roland HP2e digital piano and one of the keys has lost its touch sensitivity. It works initially but when it passes a certain threshold of loudness when played it goes to full volume on that key until the piano is switched off and on again. I do not think it is a thermal fault as it can be replicated by playing the key immediately after the piano has been switched back on without time to cool.
  • rml7 Apr 12, 2009
    I have the same problem with an HP-2E. The G sharp key above middle C has lost its sensitivity. Interestingly, if I hold down the G key next door to it before I strike the G sharp key the effect does not occur.
Just managed to fix key loudness problem on my sister's HP-2E after talking to the local Roland Service Center. Basically I had to remove all the rubbery strips under the keyboard, clean them and clean all the contacts on the keyboard PCBs with CO contact cleaner. Not a trivial procedure - 80 or so screws to remove and replace and a lot of parts.
It has completely solved the problem (apparently its not unusual on any keyboards). I have posted more details and a couple of pictures on my blog ( not sure if that is a permalink - if it doesn't work go to and search for HP-2e).
A roland service center can fix this as well however it is pretty time consuming so they will charge you. They can also sell you replacement keyboard contact strips if cleaning them doesn't work. Hope this helps
Posted on Apr 20, 2009
  • iain8989 Apr 20, 2009
    The link didn't paste properly in the post - try this:
Do they still make the Yamaha CP-300`s
NO - try the
  • Yamaha CP4 Digital Stage Piano which replaced it.
  • A Roland Digital Piano
  • NORD
Apr 30, 2014 | Yamaha Cp300 Cp 300 88 Key Keyboard Piano...
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
My gf has a roland hp1500 digital piano but the pedals arnt working. Im trying to fix it while she is away. I am a security engineer and have access to and can use a test meter amd am confident about...
I you mean the sustain type pedals, FIRST check the connector(s) as they often come loose or unseated. Next check for a broken pin in the connectors. It is UNLIKELY you could troubleshoot anything inside with just a meter. It appears that some of the Roland pedals receive 5 volts in the connector, and upon contact closure the voltage is sent back to the piano where it drives C4570 buffers with 680K to ground and an RF bypass cap and series 330 ohm to the + of the C4570's. The circuit I have is for a different piano but if yours uses the 8 pin connector it is likely the same.
The contact is actually optical interrupter modules with a driver transistor. There are threshold setting pots in the pedal assembly as well. The farthest I would suggest you go is to make sure the optical interrupter modules are free of dust if this is the type you have,.
May 28, 2011 | Music
Hi, I am undecided about which digital piano to buy: Yamaha Arius 141 or Roland F110? help appreciated, thanks, karol.
I have two Yamaha's and I will say they are maintainable. Almost ALL the weighted piano key models use a keyboard made by one company as I understand it. I can easily get service manuals for the Yamaha, not quite as easy for the Roland... same goes for repair parts. Your decision... listen to each and decide. Hint: Use a set of headphones to do the compparision rather than internal speakers as the orientation in a music store can drastically change the sound.
May 01, 2011 | Roland F110 Compact Digital Piano 4867
Need help in choosing the best digital piano you can recommend for me for A budget of 2500-3000 usd
The Korg SV188 has stunning realism in the Grand Piano arena. It uses a 12AX7 tube in the preamp output for that classic analog warmth lacking in so many garden market digital stage pianos these days. It has weighted hammer action and carries a price tag of $1,699.00 at American Musical They even throw in a extra years coverage at no cost. The Yamaha MOXF6 88 key (same price) is another fine grand piano that wont disappointed but be prepared for a large learning curve learning all the rest of it functions, there are plenty to chose from. Roland wins hands down with its RD300nx, $1,799.00 and the RD700NX $2,699.00 simply the best digital stage pianos money can buy . Look up the specs at AMS
Jul 28, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
I have a Roland HP 101 digital piano however certain dont sound
White spirit is NOT what you should use. Mineral spirit leaves a residue film.
Use 99% isoprophyl alcohol.
ALSO inspect the contactboard for cracks by candeling with bright light behind it.
Oct 31, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
I have a Roland HP 2e digital piano - Foot pedal problem
The ROLAND pianos USUALLY require that you use a normally closed sustain pedal.
MANY pedals are the opposite and close when pressed. SOMETIMES you can open the pedal and reverse the way the switch works.
Oct 05, 2009 | Roland Music
Roland 3000 Digital Piano 88-Key Full-size weighted keyboard
It's not really for the faint of heart, but generally this is caused by gunk getting into the key circutry. Underlying the 3000's keyboard is a silicone pad with 2 contacts on it, the measurement between each being hit is the issue usually but yours just sounds like there's something in there causing a physical or contact obstruction.
What you really want to do is to remove the keys and clean everything but this isn't easy... You could try using 99% alcohol (from a pharmacy) to clean inside it which may well help you.
There's a good thread on a similar issue at:
Which may help you work out how to do the disassembly if you are brave, but I would start with pouring some alcohol in and poking it and hoping for the best 1st. It sounds crude, but it works amazingly well with some things.
Dec 29, 2008 | Yamaha NP 30 76 Key Lightweight Digital...
800 people viewed this question
