posted by Annie70 on Jun 21, 2008
- the hole on the skycaddie that you plug into for charging is to one side.should i push it over to one side or will that break it?
Solution #1
posted on Aug 22, 2008
Had problems charging mine, bought replacement battery and it wouldn't charge either. Looked inside charging port and noticed a slightly bent pin, straightened it and works perfectly. Bought battery from batterybob.com $26 vs $49 from skygolf.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 27, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Your connection port is broken and will need to be sent in for repair. Sure enough, you could wiggle the port to where it may work for you for a while, but eventually, this will only worsen. Contact SkyGolf and send the unit in.
Suggest a new solution for this problem
Post a New problem for SkyGolf SkyCaddie Handheld GPS Unit
Email this problem
Email this problem
Can you Help with these GPS Devices problems?
Repair Service
Find GPS Device Repairman Near You:
