Desk top pc
My pc is running on xp. when i try to burn a music cd the system shuts down.
  • 12 more comments
  • Maria Banner
    Maria Banner Jun 21, 2008
    ive tried to burn cds on windows media and also nero but the same happens. ive havn't added any thing new to my pc at all. the problem started about a week ago. when using windows media a says some thing like windows media as a problem and needs to shut down. when using nero a balloon comes up at the bottom of the screen but it shuts down to quickly for me to read it, the only bits i can remember are a file is currupt and run some thing called chkdsk/f i think thats what it said, thanks
  • Maria Banner
    ive done that but the problem is still the same, i tried to burn a disk and half way through a baloon popped up saying the file or directory and settings c:/Document and setting\maria.mercia\cookies is corrupt and unreadable. then a box came up saying dwwin-exe-Entry point SHAutocompyoyo could not be located in the dynamic library SHLWAPIdll. thankyou for your help. maria
  • Maria Banner
    i've already tried system restore but it doesn't make any diffrence.
  • Maria Banner
    yeah i have both on my pc but they've been ok. do you think if i turn them all off and try to burn a cd it might make a diffrence?
  • Maria Banner
    i can't find the AeDedug tab
  • Maria Banner
    i found AeDebug but can't see export registry file, all i can see is...default reg_sz (value not set)
    Auto reg_sz 1
    Debugger reg_sz drwtsn32-p%ld_e%ld_g
    user debugger ho....reg_Dword oxoooooooo(o)
  • Maria Banner
    done that but still can't burn a cd!
  • Maria Banner
    Maria Banner Jun 22, 2008
    thankyou for your help. now i'm afraid i can't always log on because i keep getting a blue screen with loads of writing on it and a couple of error messages!
  • Maria Banner
    there's two error messages, the first is stop:0oxoooooo7E(oxoooooo,oxF4B4-5Ao3,oxF7B1D,oxF7B1D6C8) and the next is Sysaudio.sys-address F4B45A03 base at F4B3foo,datastamp 41107F1a thanks
  • Maria Banner
    Maria Banner Jun 23, 2008
    this seems to have done the trick thankyou. do you work on pcs for a living? only asking cos ive got a lap top that needs some stuff doing on it. thanks again maria
  • Maria Banner
    first of all when you log on it's started in the last two weeks to comes up with with a box that says RUNDLLerror loading c:PROGRA~1\mywebs~1\bar\1.bin\M3PLUGIN.DLL The specified module could not be found Then RUNDLL Error loading C:\PROGRA~1\MYWEBS~1\bar\1.bin\MWSBAR.DLL The specified module could not be found Thats just the start, shame you don't live near me because i would pay you to come and sort both of them out. I really do thankyou for helping me. i know nothing about pcs at all. thanks again.
  • Maria Banner
    there is no mywebsearch in add or remove programs?
  • Maria Banner
    ive got to winlogon but the only files i can see are......credentials,gpextentions,notify,sclogon,specialaccounts
  • Simon Vann
    Simon Vann May 11, 2010
    Im going to need more info to assist you,
    What software are you using to burn cd's?
    How long has this been happening, and has anything changed since it started, ie new apps installed?
    Do you get any error messages before this happens, or a Blue screen with white writing on it?
    Has any of the hardware been changed before this strated happening?
  • 85 Answers
Ok, basically nero is asking you to run chkdsk to see if there is any corruption in your system files and is generally a good fix for things like this.
If you don't know how to run chkdsk, follow the steps below.
Click Start -> Run
In the box type cmd, then press enter
At the commad prompt type cd \, then press enter
Then type chkdsk /f
If you are prompted to schedule CHKDSK to run the next time the computer restarts (because CHKDSK may be unable to gain exclusive access to the drive under Windows), type Y then enter
Type exit
If you have had to schedule the chkdsk ro run, restart your PC and chkdsk will run whilst your PC is starting up.
Please let me know if this fixes the issue.
Posted on Jun 21, 2008
  • 10 more comments
  • Simon Vann
    Simon Vann Jun 21, 2008
    Wow, thatnks for the details, im currently looking int that error, and i'll will get back to you shortly
  • Simon Vann
    Ok, another possible soloution would be to use System Restore to return the system to how it was before this error occured.
    Whilst you will not lose any new e-mails, documents etc, any new applications that you have installed would be removed.
    So to do this :
    Click Start -> Programmes -> Accesories -> System Tools -> System Restore
    Select the 'Restore my computer to an earlier time' option.
    Select a date (only those in bold are selecatble) from before this error occured.
    Select next and follow the remaining instructions.
    Youir PC will restart after the restore and you will see a box that will tell you the outcome of the restore.
    After all this, please try burning again anbd let me know how you get on!
  • Simon Vann
    Do you have any anti-virus or anti-spyware software running ao this machnie, if so has it flagged anything recently?
  • Simon Vann
    well I just wondered because the files refered to in the error can be related to anti-spyware. However in your case I dont think they are.
    The only other thing that the error relates to is Doctor Watson. This is the error reporting tool that has been present in windows since it was first released, way back in 1985. This is a know error and it has been removed in Vista.
    However, you can disable this in XP, which disabels the file dwwin-exe from being used, and hopefully cure this fault.
    Click Start, click Run, type regedit.exe in the Open box, and then click OK.
    Locate and click the following registry key:
    HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\AeDebugNOTE: Steps three and four are optional, but they necessary if you want to restore the default use of Dr. Watson.
    Click the AeDebug key, and then click Export Registry File on the Registry menu.
    Enter a name and location for the saved registry file, and then click Save.
    Delete the AeDebug key.
    This information can be found at
  • Simon Vann
    Ok that part isnt so important as the first 2 steps.
    Have you treid burning again?
    Let me know as I have one more trick up my sleeves!
  • Simon Vann
    If export isnt there when you right click on AeDebug then highlight it and select export from the file menu.
  • Simon Vann
    Ok, I have just about ran out of options now im afraid. Sorry I couldn't help!
  • Simon Vann
    Simon Vann Jun 22, 2008
    Im sorry i couldnt help more, but if you let me know what the error saya i may be able to help a little more with that.
  • Simon Vann
    a STOP 0oxoooooo7E error is related to a corrupt driver, and in your case sysaudio.sys tells us that it is your sound card.
    When re-booting your system, keep tapping the F8 Key, to start up in safe mode. You should be able log on here ok, but logon with an account that had administrator privlages
    Select YES from the pop-up box tbhat appears.
    Right click on My Computer and select properties.
    Select the device manager tab
    Locate and expand the Sound, Video and Game Controllers section.
    There will be several listings here but you need to select your sound card. Right click on this and select Uninstall
    Reboot your PC in normal mode to re-install the drivers.
    Let me know if this helps
  • Simon Vann
    Simon Vann Jun 23, 2008
    yes i do, what things do you require??
  • Simon Vann
    The problem you describe is related to a programm called mywebsearch, which can be removed in the control panel, add remove programs. this should sort that out.
  • Simon Vann
    If theres no mwebsearch there then im afraid its a virus.
    Ok, do the following step and get rid of it.
    Open Run , type regedit and press enter
    Go to
    HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon
    and check for the key Shell, the value of this must be Explorer.exe .
    if you can see some other after that like Explorer.exe
    C:\PROGRA~1\MYWEBS~1\bar\2.bin... , then remove the second file from
    the value, means it must only Explorer.exe
    Ok, then check for the key Userinit. the value must be
    C:\WINDOWS\system32\userinit.exe, (including the comma) . If after that
    some thing is there , then delete it.
    Ok thats all. restart your system .
On my desk top computer that I bought at yard sale I don't know the administrator password. It has Windows XP professional.
Unless the previous owner had a particular security issue and changed it, the default password is the same. i.e. Administrator or Admin. Try these without the capitals if they don't work. Failing that, there are numerous XP password resetters that you can download. These are usually an ISO file which you burn to a CD. You then boot from this cd which usually runs a Linux based shell that will interrogate the password list. They will allow you to zero or clear all passwords on the system. The other alternative is easy if you have the XP install disk. Just reinstall the whole thing. Just a point though. Does a prompt come up as soon as you start the system probably in a blue box? If so this is a bios prompt and requires a different approach.
Oct 24, 2014 | Computers & Internet
My dell inspiron 5620 wont go further a black error recovery screen
Shut down, unplug, remove battery, plug in, reboot, Try a system restore/recovery. If that fails, place a repair desk in the DVD/CD rom and reboot from DVD/CD rom, try a repair my computer first. Your MBR is missing or your HDD needs replacing. Is the HDD LED blinking at start of machine? Open the machine and reseat the HDD and memory mods. If that fails, remove HDD and test, replace if necessary. You didn't mention your OS? Windows XP? This may help:
Dec 17, 2012 | Dell Inspiron 1200 Notebook
System Recovery Failure
Hp recovery console usually sucks, download an iso of the operating system from a torrent website like and do a fresh install. download the disc image burn the image to a cd, boot from the cd and fresh install, You will notice a world of speed improvment if you dont feel comfortable downloading the imange call hp and tell them you want a OEM disc of the os for your pc
Nov 17, 2009 | HP Pavilion a1000n (PS567AA) PC Desktop
Xp wont turned on it will not boot to the desk top it frezers
This should fix your problem. Even w/o your installation disk. I have used this program to fix Pc's I have picked up off the side of the road. I would hit the power button, it would show the BIOS then it would stop and shutdown. This fixed 99% of them I have picked up.
Go here
using a torrent program ie (utorrent, shareaza, etc) download SPINRITE.exe.
Burn this on a disk, the program is written with freedos included, but this will not work with 100% of laptops.
if the program stops and shows you a red screen with an error, use a program such as PowerISO to burn the disk and make it a bootable image by adding a .bif
after burning the program to disk-
  • insert disk and reboot
  • press any key to boot from cd if asked
  • when you see Prompt, change to your default cd drive.
  • type SPINRITE to start program
  • use recovery option 5
this may take a few hours or a few days depending on the condition of the HDD.
I have used this program to fix computers I've picked up on the side of the road. I would power it on, start to load then go into a loop. after running this program overnight I was able to reboot (after removing disk) and the pc started right up.
Make sure you run a program like Ccleaner (you can get at to clean your registry2.gif and junk files after completion. ^_^
Sep 17, 2009 | Gateway MX6030 Notebook
Not able to burn CD
If you have a desktop PC, try to replace your CD Writer / Burner or return it for replacement if there is still a warranty.
May 27, 2009 | Microsoft Windows XP Home Edition for PC
DEll 2400 - cd-dvd drive stopped working
try to clean the lens using lens cleaner...
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
Cd burner
Try using a CD Cleaner with liquid solution. If it still does'nt burn, maybe it's time to replace your burner.
Aug 24, 2008 | Compaq Presario 5000 PC Desktop
Dell Inspiron 1501 black screen
Post the error codes that are given and I'll be able to tell you what's going on exactly.
Jun 19, 2008 | Computers & Internet
Blank DVD
What are you using to burn cds?
Try using the free burning version at
Jun 10, 2008 | Ahead Software Nero 6.0 (60045) for PC
Computer shuts down
the only thing i can think of there is that you have some kind of fault, or maybe try to do a system restore by clicking on start,all programs, scroll up to accessories then to system tol them follow instructions, restore it back a few weeks try that
Dec 19, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
171 people viewed this question
David Payne
David Payne
