FixYa.com
Tags:
Raritan MasterConsole II 8-port KVM Switch
No keyboard after reboot on ML 370 G3
By Chandler - usenet poster
I've just install WIndows 2000 Server
on a ML 370 G3 server.
When I "restart" Windows,
all keys on the keyboard do not works, even Ctrl+Alt+Del!
However, when I "Shut down" Windows
and then start it (by pressing the power button),
the keyboard works!
I changed the keyboard to another model, but it didn't help.
What should I try to make the keyboard work
after reboot, no only after shutdown?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 15, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have been haveing the same problems when I boot my computer my keyboard and mouse are not working or work for only a few seconds. After a hard restart it works fine. I'm running windows xp and my mouse and keyboard are connected directly to the system.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 11, 2005
Not Rated (0)
Beresford
Beresford - usenet poster
Rating: 0%, 0 votes
this sounds like a flakey hardware component to me. Contact HP and have them
send you a new systemboard.
- LC
Solution #3
Not Rated (0)
Green1
Green1 - usenet poster
Rating: 0%, 0 votes
Belkin might be ok if your network is at home. I have replaced more belkin
KVM switches in production environments that I can remember.
Solution #4
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rating: 0%, 0 votes
Why say that??? We use a Belkin 8-port with no problems at all...
Regards,
Hank Arnold
Solution #5
Not Rated (0)
Pasty
Pasty - usenet poster
Rating: 0%, 0 votes
What make and model of the KVM? Digital, Serial, USB ?
please please please dont say ' belkin ' ...
Did you try other ports in the switch?
- NuTs
Solution #6
Not Rated (0)
Luisa_K
Luisa_K - usenet poster
Rating: 0%, 0 votes
Arrrgh!!
Now I think it's a KVM-switch-related problem!
It occures only when I use my KVM Switch (AESP Signamax 098-8080).
When I connect the keyboard directly - no problems!
Solution #7
Not Rated (0)
Joey2
Joey2 - usenet poster
Rating: 0%, 0 votes
I've checked - the cables are correct.
Recently I booted from a Windows XP PE CD, mouse and keyboard worked OK.
I did "Start"->Studown->Restart.
The ML370 rebooted, and - keyboard doesn't work again,
for example Pause and Num Lock don't work during the boot process.
Than, when Windows PE CD started  - the keyboard also didn't work.
Again, only after power off and power on  the keyboard began to work.
Also I tried to boot from FreeBSD 5.2 CD - the same behavior!
So, this strange bug it is not OS-dependant.
I have no ideas...
Solution #8
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
  Check to make sure you do not have the keyboard and mouse cable swapped.
Aidan Grey
Can you Help with these KVM Switches problems?
KVM Switches
DSS-16+ switch
We just purchased the above... Answer This...
KVM Switches
Adapter cord AP - 12
Where can I purchase a adapter... Answer This...
KVM Switches
keyboard loss with trendnet...
I am using a trendnet TK-207K... Answer This...
KVM Switches
timer
replace timer in minimax dryer Answer This...
KVM Switches
Denpa mp38
When I turn it on, I only get a... Answer This...
Repair Service
Find KVM Switch Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
