Question about Saeco Vienna De Luxe Espresso Machine
SEACO Vienna breakdown
The axis of the motor moved 1/2 round (crenellated axis)
It's not possible to put the mechanism into the machine.
How to move the axis on the right position ?
My email : yvisteon@libertysurf.fr
Thanks for your quick response.
Regards
  • soli123 Aug 24, 2008
    i already tried this solution.
    but the rotor go move for the cycle but with 1/2 round in a bad position.
  • 74 Answers
If nothing is broken then this might be a easy fix.
first take out the dregdraw and the driptray.
Put one screwdriver on the sensor for the driptray/dregdraw at the botom left and one for the door up i the right corner .
This must be done when the machine is on.
It will then think the brewing unit is in position and move to the starting location.
Posted on Jul 11, 2008
Motor that moves brewing group started moving very slowly. it can make it on time to make coffee. Anyone know what could the problem be? Mashine worked great just untill today.
Hi, I had the same problem. The motor ran too slow because it did not receive the adequate amount of power. The power is handled by a small part on the circuit board. I replaced it by a part I bought on ebay called Transistor BD245C (or TIP 33C). Now it's working perfect again :-) Details can be found on ebay by typing '262197092158' in the search box. Although the page is in German, it has several pictures that make clear which part is meant. Good luck!
Feb 06, 2016 | Saeco Vienna SuperAutomatica Coffee...
I cant get my needle position to move to the left or the right
The long arm is attached to the needle arm.
1. Move the needle arm right and left with your finger. Is there any resistance? There should be. If not, a spring that is supposed to be attached to the long gray rod has came loose.
2. The spring will be attached so it pulls towards the round cogs (bumpy things).
3. Mechanical sewing machines are very similar. There is a possibility that your adjustment lever has screws came loose.
4. By moving the needle arm back and forth you can monitor what is going on to get a clue of what may be wrong.
Mar 06, 2015 | Sewing Machines
I always find coffee liquid under my coffee maker seaco Vienna superautomatica
are you putting too much water in it ? try a little less next time
Feb 21, 2015 | Coffee Makers & Espresso Machines
I have a Babylock BMP8 that i have an x-axis home position error. How can I fix it without spending hundreds to take it to a technician that is hours away! Please help!
Turn off and unplug machine. Manually move hoop frame front to back and left to right.
Plug in and turn on. Motors driving hoop x and y axis should initialize. If not you must see a tech, If the frame will not move see the tech
Dec 08, 2014 | Sewing Machines
Only hot water comes out of the steam wand
Hi
Sounds like you might need a new steam boiler, or you may have a fuse that is blown for the steam boiler.
Oct 06, 2009 | Saeco Vienna Digital Coffee Maker,...
AEG LAVAMAT 74620 shows "CE" error
I fixed it, but I still don't know for sure what the "CE" error code is. I guess it is for the water distributor. I opened it up. There are some gears in there that move a mechanical arm that distributes the water into different containers. The mechanical arm moves around an axis -- it was very difficult to move, so the gears kept slipping. I opened it, and put some greaze inside. Closing it up was a real pain. But it works, and I didn't have to wait around to receive a new distributor.
Dec 27, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Saeco vienna "machine ready" light (second light) blinking--not allowing to dispense coffee.
Try to open the steam knob and make a cup of water(Tea).
Best regards
/Mirran
Oct 21, 2008 | Saeco Vienna SuperAutomatica Coffee...
Seaco vienna deluxe
Do you hear any noise when it should go back, if so then the gear wheel has to be replaced
Jul 07, 2008 | Saeco Vienna Espresso Machine
Seaco Vienna Superautomatica
I think the fuse is gone, if you take off the top then you will see the fuse on a cable.
Jan 02, 2008 | Saeco Coffee Makers & Espresso Machines
The machine won't wash or spin... Motor pulley?
take a look at the transmission if it has a whie tag or label bad transmision
Aug 12, 2006 | GE WVSR1060A Top Load Washer
Saeco Vienna De Luxe Espresso Machine Logo
87 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
Mike Cairns
Mike Cairns
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
