Question about HP : HP1600C Inkjet Printer
51.22 error on my hp1600 color printer
Dear Sir,
I have Hp1600 Color Printer, When I give printing order, it gives 51.22 eroor,
Please give me solution.
Thanks
Alok
Rajdeep Bulidcon Pvt. Ltd.
4 Suggested Answers
down_grunger
  • 47 Answers
SOURCE: When I print from Word
try using a different word program such as open office* or even notepad, if it prints correctly then try reinstalling microsoft word as there maybe some accidental alterations in the printing setup on word.
alternatively try reinstalling your printer.
*open office is a free to use program*
hope this helps
kev
Posted on Dec 01, 2008
  • 81 Answers
SOURCE: I bought a used Color Laser printer, the HP1600,
This could a problem with the laser scanner assembly. It gets contaminated with toner and dust so reduceing the laser intensity which in turn causes the image to be fainter and gives it a washed out appearance. You would need to remove the scanner and clean the lenses and mirrors for each toner cartridge. The laser scanner box is one unit with four mirrors and four lenses in it.
Posted on Oct 13, 2009
  • 175 Answers
SOURCE: HP1600 colour fade on one side
it will most likley be the drum take it into a printer shop and they will clean it befor it gets to damaged as they are hard to replace
Posted on May 28, 2010
Yellow print on back ground
clean the laser unit it opens from the top of u r printer clean it with only a doctor cotton is u r printer is hp1600 if yes then open it from top .
Feb 02, 2013 | HP Color LaserJet 2600n Printer
Am confused,i want to buy a colour laserjet printer and left with only two options which one should i buy btn hp1600 and cp1525
hiii
Its depends on your printing needs.Printing quality almost same these two printers. If u buy hp 1600 u will get more pages than cp 1525.But u should think about the toner cost. Check your local market price for each toners.Here i will give u the toner model numbers for ur required printers.
hp 1600 - q6000- black,q6001,q6002,q6003 each three colours.- Page yield 2500 pages for black ,2000 pages each colours.
hp cp1525- ce-320a(128a),ce321,ce322,ce323- Page yield -2000 pages for black,1300 each colour pages.
So I am sure hp 1600 toner very costly than 1525 toner.If u dont have huge volume printing better i suggest u buy cp 1525 model.Also this model offering wirless printing .
U can refill this toners lowest cost and getting good results.
sooooooo cheeeeeeers up........select your new printer. best wishes..........
Jun 14, 2011 | HP Color LaserJet 2600n Printer
May 28, 2010 | HP LaserJet 1600 Printer
My HP 2600N doesn't print the red and I tried to use 3 new toner but it still don't work. It's not the toner problem and it's the printer. My HP warranted is expire. What should I do? Thanks!
HIgh probablility that the DC Controller has had it. This is an increasingly common fault with the HP1600, 2600, 2605, Canon LBP 5000 and 5100 machines all based on the same engine. The DC Controller puts the charge on the cartridges. When it fails the Magenta cartridge is the first affected and the result is - No Magenta ( reds, oranges, violets etc.) The DC controller must be replaced.
Dec 04, 2009 | HP Color LaserJet 2600n Printer
I bought a used Color Laser printer, the HP1600, and I have just installed three brand new color cartridges. When I attempted to print the color came out washed and very faded and you could see it being...
Oct 07, 2009 | HP Color LaserJet 2600n Printer
How can I print black only color cartridges are empty black is full . this is for HP photosmart C5180 all in one printer
sir when you chose the print option please select the settings button there in the color tab you can find this option that print with only black ink
alternative solution is that before you print please open the flap of the printer where the heads are and remove the color cartridge.. then print it will give you a warning saying that printing in reserve mode but ignore this warnings
Thnx and i hope this solves your problem
Please rate this solution
Jul 16, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printing a two sided brochure on HP Color LaserJet 1600 and brochure is getting spotty. Do rollers need to be cleaned? If so how is this done? Printer is one year old. Thank you.
the hp1600 is a rubbish printer. The fuser is inefficient and the toner doesn't stick correctly to the page, for double sided jobs, print all of side 1 first, allow the pages t cool completely and then print side 2, alternately buy a HP3600d or HP3505d, its chalk and cheese
May 09, 2008 | Office Equipment & Supplies
290 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
