Question about Microsoft Windows Vista Ultimate Edition
USB port problem in VISTA
My laptop reads selected pendrives only why
  • yatheesh_kc Jun 24, 2008
    Thanks for the message. Actually my one of USB controller port is corrupted. Hence I did not install the SP1. I think I will get it repaired and install the SP1.
    Thanks once again
    Recently I installed one Axtivex controll from one of the internet site openscreensaver.com. Then LAN stoped working. Immediately I uninstalled it and rebooted. Now the thinks are normal. I have nortons internet scurity antivirus with vista primium in my laptop. Tell me is it really risky to allow some sites to install activex.
  • 67 Answers
IN VISTA ITS COMMON PROBLEM BECAUSE ALL DRIVERS LIKE XP IS NO AVAILABLE IN VISTA SO FOR THIS PROBLEM YOU NEED TO INSTALL VISTA SERVICE PACK I
ITS AVAILABLE IN WWW.MICROSOFT.COM
Posted on Jun 21, 2008
Toshiba external 3.0 drive is not read on my laptop
First Check the USB Port with the pendrive if pendrive is detecting then check the cable that connects the HDD. If cable is OK then Your HDD will have some problem.
Oct 08, 2013 | Toshiba Computers & Internet
Where to connect my pen drive in my sony bravia lcd klv32s400a?
Hi Radhika,
Your TV has USB port on back side. Just plug your pendrive there. Then go menu on TV ( use your remote commander) and go to this input. Your TV will read the file on pendrive accordingly.
Regards
Oct 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Pendrive can detect but cannot read
Pendrive was problem.
When you click properties for pendrive then you will find capacity for your pendrive is zero.
However you can try to use other usb port. sometimes, usb port have problem. If you check properties it have capacity. mean not zero, then try check disk tool to fix error.
May 25, 2011 | Computers & Internet
My pendrive is not reading in my computer
Try another USB port on your computer.
If that fails, try to read the pendrive on another computer to see if the pendrive itself has died.
Mar 06, 2011 | Transcend (589307) Media
Pendrive more than 2gb dont detect
usually 2.0 USB driver donot detect bigger capacity pendrives. so you need to install the driver for suitable capacity
Jan 15, 2010 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Hi, myself chetna i am having compaq laptop,and the problem is this: whenever i connect my pendrive, my system get hung-up, it stops working, then i abruptly turn off it, and then again start it, somebody...
HP Pavilion dv6000z Notebook
well what can that be , many things
pendrive (a usb port memory stick, and not real DRIVE?)
test it on other pc yet. why not? its failing test it.
many USB mem stick fail due to corrupted files on it.
(removing it incorrectly cause that)
what OS? , you posted with NO OS Stated, at all. XP?
all ports fail on this Laptop?
do other USB sticks fail....>? or USB keyboards, or mice?
the HP OS restore features started about year 2006
called the F11 recovery mode. (that?)
you said.
"but window formatting does not make it work,"
what does that mean, by what means? who done?
using what media or F11 magic key.?
I say the PC is XP? and we all know XP has Horrible
USB support, and NOW worse MS shut down XP servers
for the USB devices, (and more) so will hang when
doing PnP "plug and Pray" driver from there.
XP is DEAD, you do know that right? XP and VISTA are
now DEAD.
recap:
1: the Stick fails on all USB ports.
2: the stick fails in othe PCs
3: running XP and expecting things to work. HAHAHAHAAHAHAAHAHAH (the endless dream?)
my XP works on one PC, but I had to make sure I had all drivers perfect , from each chip maker,
MS and HP dont have them so takes hard work
4: is the Device manager in control panel clear of al errors"
this PC is 10 years old
HP retired it, official
XP is retired at HP and MS.
that PC came new with F11 magic recover key.
the HP manual (covers XP and VISTA )
is still there, will be deleted soon... hint hint..
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
here is DM running and me clicking power tabs
on usb hubs
Sep 13, 2017 | HP Pavilion dv6000z Notebook
Pendrive not showing in vista explorer
Hi!!
Right click on my Computer
Select Properties
Hardware devices
Device Manager :
Check your USB port.. whether everything is connected.
If its shows yellow mark means re-installing the device driver or to update it.(install by ur motherboard cd)..
bye...:)
Mar 06, 2009 | Microsoft Windows XP Professional With...
Pen Drive 16GB not working on laptop but working on other PCs...
It sounds as though the problem is with your notebook, rather than the flash drive. Specifically, with the USB port you are plugging it into. If you have another USB on the notebook, try switching between the two, and see if it behaves any differently. Another thing that can cause a problem is if the USB port on your notebook is not USB 2.0. The older ports (as in, an older computer) didn't have nearly the transfer speeds of the newer standard.
Also, are you trying to run multiple USB devices on your notebook at once? That could cause problems as well.
Cheers
Nick
Dec 28, 2008 | Televison & Video
Usb port not working
If you have Vista check M/soft site for bulletin 940199
Vista has a habit of losing USB ports and there is a fix for it
Aug 20, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Pendrive
Try another pendrive and see if the same is working.
PLease make sure if your pendrive is USB 2.0 compliant.
If it came with an installation CD/CVD, install the same and try.
Cheers,
Jul 11, 2008 | HP Compaq Presario V6000T Notebook
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
