Trying to burn semantec system image that came with ghost 14 but each time i run nero it gets to the end and then has an error reading and fails .help?
  • soxie72000 Jun 22, 2008
    Surprised that ghost 14 used 40 gig on the backup, any comments.B
  • Simon Vann
    Simon Vann May 11, 2010
    Please provide the exact error and I may be able to assist more.
I stoped using nero, which always seems to have problems, and used deep burner an excellent little freebe. Thanks for asking.
b
Posted on Jun 22, 2008
I am using DVDFab 5 to copy dvd, but I can not burn it. please log below. 14:14:08: Analyzing of DVD started 14:14:08: Analyzing of DVD completed successfully 14:14:08: Copy process started 14:28:57:...
looks like its making the image fine
try to use a different program like imgburn to make and image of what yoiu wanna burn then use that image to write to a new disc
http://www.imgburn.com/
May 06, 2011 | Computers & Internet
Recording Error E 6 28030200 how can I get the information off the DVD or how can I finalize the DVD for our church use
I was able to get data off a disc with a similar problem using Nero Burning Rom's Save Tracks feature. If I save it as an .ISO file I was able to rename the file to have the .VOB extension instead and play it using windows media player. I did run into a problem that Nero would run into a read error near the end of the track, report an error and DELETE THE FILE IT WAS WRITING. In order to get around this, when nero was almost done reading the track, I killed the nero.exe process using the Windows Task Manager (Ctrl-Alt-Del). Now I can at least view most of the video.
Aug 19, 2010 | Computers & Internet
Dvd writing failing.
Your machine has more than enough specs to to the job
DVD's speeds are preset by the dvd itself under normal circumstances so trying to change speed may well cause it to fail.
If your dvd says 16x then the burning program will sense that and adjust accordingly.
If you try to burn faster the speed listed on your dvd then it is almost certain to fail.
Nero has tools that help to set it up for the drive that it is going to burn with nero speed and the info tool that usually ships with nero will run diagnostics on the drive and save these setting to use with the burning side of the programs.
I would suggest you re-set anything you might have changed in nero then run the tools and try again.
If you still have any issues post any further information back to this post so that we can assist you easier.
Aug 22, 2009 | Sony Computers & Internet
UN-Install Nero Burning rom 5.5 FREE Version (now out of date)
If you are running XP or Vista, I would run a system restore. Go into start all programs, accessories, system tools, system restore and choose a date prior to the day you installed nero.
Armymason
Mar 02, 2009 | Ahead Software Nero 5.5 (NERO5.5) for PC
Pioneer DVD-RW DVR-106D VI.07 isn't working propperly
use winrar or download DVD REGION and use trial should work
Feb 03, 2009 | Pioneer Computers & Internet
My Sony DVD writer reads CD and DVDs but does'nt write.
Could be a faulty burner.
Could be software.
Possible solutions
1. If your not using Nero to burn, install that and try.
(Im sure you can download a demo to test it)
2. I'd also uninstall any dvd ripping software...eg DVD43, etc as I have seen problems where that software has stuffed up filters, meaning the burns always fail immediately. Other times it has caused the burner to no show up in a burning program.
3. Id also click start, run and type MSCONFIG and press enter, then disable any items in the startup panel that are not related to your burning program. also do this for the services tag. (Click hide Microsoft services first)then reboot and retest. If the burner now works then some software is definately causing the problem
To restore normal boot, run msconfig again and choose normal startup.
4. You could also try booting from a dos boot disk and try burning something with that... eg use a ghost boot disk to make a system image. if that works then its definately software.
If that doesnt work then I'd say your up for a new burner.
5. If you have a test burner, try it with that, you may need to do one reboot after first install. It wont need any software, as support for cd/dvds is built into windows. If the test burner works your old burner is faulty.
If that doesnt, You have a software problem.
Before replacing it I'd clean the lens...but its not likely to fix anything if it still reads ok, but has been known to help.
You could also try flashing the burners firmware...not for the fainthearted but what have you got to lose.
IF IT IS SOFTWARE
Then isolating it can be hard.
1. use nero.
2. try checking your filters....http://www.kalytta.com/tools.php has a freeware tool on that page that claims "This tool is able to detect and deactivate or remove broken (unloaded) Filter Drivers.". I havent tried it though
3. last option - run a repair install over windows... this will keep all your programs and files intact but replace all system files and redetect hardware. Google windows repair installation for more info.
Sorry I cant be more specific..but there are sooo many causes of software corruption
HT JoshAU
Jan 26, 2009 | Computers & Internet
Trying to reinstall norton ghost v14
you need to remove Norton with Nortons own removal tools. Add/remove program not the same thing as it leaves stuff in the registry. Go to norton.com and get removal tool..Run it, then try the re-install.
Dec 27, 2008 | Symantec Norton Ghost 14.0: Windows
Nero 7 write error
i think you have tried to write a cpoyrighted disc .
Jun 05, 2008 | Computers & Internet
Factory default disc on acer 4520G
If you have Nero of Power ISO installed you can right click the .iso file and there should be a command in the shortcut menu that states "burn with Nero" or burn iso with Power ISO, etc. this should apply to other disc burning software you have installed.
As you may know, .iso files are a compressed disc image file that contains the data layout for a complete CD or DVD. Most of the time, burning an iso image from first opening your disc burning software is more difficult but can be done by hunting through your software's menu commands.
Hope this has fixed ya!
Worldvet
May 16, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
