Question about Hoover Washing Machines
The softner does not get picked up all parts cleaned for blockages
  • 66 Answers
Sounds like you need to change the rinse fill valve
Posted on Jun 21, 2008
My LG washer machine will not rinse thru the softer section in the cup, what can I do?
then the solenoid is not actuating to allow water into drawer. take top off, very easy, two screws in back, pull back, lift off. follow hose from softer cup to little round device/solenoid. check wiring. check hose, tho you would know there was a problem with hose, because you would see a water leak. replace solenoid. hope this is the issue. good luck.
Mar 02, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water is coming up in fabric softner cup during rinse time front loader
this is normal
water should go thru the softner and into the drum when the machine rinses to introduce the softner to the drum
Dec 05, 2014 | Kenmore Elite 45986 Front Load Washer
The fabric softner is not draining into the washer from the fabric softner compartment.
Likely a cleaning problem, can you dismantle the drawer (most allow it) and clean it inside and out. Usually some blockage caused by soap scum.
Dec 19, 2010 | Washing Machines
Doesnt take the softner
Remove the soap drawer, and thoroughly clean all parts, including the pieces inside the drawer.
Get a piece of stiff wire and form a right angled bend in one end, then poke it into all the holes in the top of the dispenser housing
This will clear any blockage there.
Hope this helps you.
Dec 14, 2009 | Bosch WFMC 3200 Front Load Washer
Washing power drawer, the fabric softner section
Pull the drawer out as far as it will come and then grasping it firmly, give it a good tug towards you, this will free the drawer to enable you to thoroughly clean every piece of it, particularly the conditioner parts of it.
Get a piece of wire with a bend on the end, and poke it in to all the holes in the top of the dispenser compartment, this will clera any blockages there.
Plz rate my solution, and feel free to leave any comment.
Thanks.
Jan 09, 2009 | Indesit W 123 Front Load Washer
Fabric softner still in draw when wash finished
There is a blockage in the dispenser that is causing the prob.
Remove drawer from dispenser, and thoroughly clean every part of it, taking all the pieces out to do it.
To test it is working, put it back together, and before you put it back in, fill the conditioner compartment with water until it starts to overflow, turn water off, and the remaining water should continue to run out, until it is empty, if it does not , then it is still blocked.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Washing Machines
E10 error and fabric softner
Close your inlet valve at the wall. Unscrew your washer hose to examine any blockage in the small filter screens; clean out thoroughly and refit carefully, check for any water leak on opening the valve fully. If you have 2 inlets for the machine it would be good to get an F or Y adaptor.
Pl rate if helped................
Jan 11, 2008 | Frigidaire GLTF2940ES Front Load Washer
Softner will not dispense
not draining from compartment is usually caused by a blockage it compartmnet, try pooring boiling water into the compartment, this will usually resolve problem
Dec 08, 2007 | Maytag Neptune MAH5500B Front Load Washer
Bosch wlf2260
I had a similar problem and found that the holes above the softner section were blocked by black mold. All I had to do was push a small wire into the holes to clear the blockage
Mar 11, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
