Question about Toshiba Satellite A135-S2276 Notebook
ASROCK i865 chipset mother board problem
after switching on my pc, i can see keyboard lights lit once and gone. But there is no display on monitor and i have checked with other working monitors also, n confirmed there is no problem with the monitor.
Processor fan is also working.. I donnow what has gone wrong,
could you please help me..
Thanks in advance,
Basav
mail me @ basavaraj1985@gmail.com
  • 1 more comment
  • basav1985 Jun 23, 2008
    thanks for the reply..
    What I meant was about monitor was, there is no problem with the monitor. The monitor is in working condition, verified it by connecting to other machines.
    And when I started the machine, I couldnt hear any beeps, and there is no display on the monitor at all.. But only I can see that, the numlock,caps lock.. lights are lit once and gone..
    Thanks,
    Basav
  • Ryan Rogers
    Ryan Rogers May 11, 2010
    I need you to be more clear on what you mean when you say you checked the monitor. How did you check the monitor? Did you plug your machine into an external monitor? Also tell me what came up on the monitor when you tested it, ie... desktop, error codes, or nothing.
  • Simon Vann
    Simon Vann May 11, 2010
    Hello Basav,
    Maybe you colud tell me when you power up the machine, if it makes any beeps.
    Simon
    Genius:
  • 2,028 Answers
This could be a memory chip. Try that, if you don't have any luck, then chances are your problem is with the motherboard. Take it to a shop to have it diagnosed.
Posted on Jun 24, 2008
Not showing normal display to Dell LCD monitor
If you look at the resolution on the monitor and match it with the windows resolution or download a driver for your monitor from Dell
Mar 17, 2014 | Asrock P4I45GV R5 Motherboard
I shipped my gateway to the philippines and had been using it until I had to leave. It has sat idle for 2 1/2 years. When i returned I brought new parts to upgrade, harddrive, memory, and a new windows xp...
Hello sir hi, try cleaning the memory modules of your PC. also review your power supply connection. and check the following sequence of events. 1. power on the PC. 2. fan should be blowing. 3. keyboard light, scroll, numlock and capslock lit and then goes off. (if this does not lit, you have a mother board problem) 4. you should hear a beep. (1 beep is normal, 1 long and 2or3 short beeps, means display problem) 5. the numlock is lit. (no light means problem on the motherboard) 6. the display monitor will now display the CMOS. 7. your drive should turn/spin or HD led lights.
Im not so sure if the motherboard develops errors due to being not used for a long time, and may now have slimes and battery leaks that may be present on the board, a visual inspection is needed here, remove your motherboard out of the case and inspect all area for chemical creeps.
Nov 20, 2010 | Gateway Tabor 3 (4000532) Motherboard
No display in monitor when i switch on my pc, i can see display on monitor after switching on the cpu for 5 or 6 times
Hello sir, hi, check out the following: I'm assuming the things that you may have forgotten.
1. is the 4 pin 12V Molex power connector connected to the mother board? 2. did you use a a good and tested memory module? have this module tested first on another PC. 3. Is your memory slot free of dust and dirt? if not clean it up. 4. is you power supply fan and processor fan spins when power is on? 5. Try powering ONLY the motherboard connected to a video display, no sata/ide cable with a tested memory installed. 6. try another Power Supply box. 7. Is your processor mounted properly? 8. when you apply power look at the keyboard lights, 3 lights initial power on then 1 light the numlock led is on. 9. do you have a plugged in usb device, remove this device as you power on the motherboard. 10. do every thing again and double check.
if all else failed, bad mother board. have this checked by a technician.
Oct 18, 2010 | Gigabyte GA-945GCMX-S2 Motherboard
The screen on my M460E goes blue with two black lines through it. What could it be, video card problems?
Yes this indicates that your video card has gone bad and would need to be replaced. Sadly, the whole mother board would have to be replaced. Hope I helped
Jamiell
Apr 15, 2010 | Gateway M460 Notebook
Hi, I have an HP Pavilion and I am unable to switch it on
Is there a flashing light on the back? This sounds like the PC power supply has gone bad, either test with a similar PS or purchase a new one.
Sep 19, 2009 | HP Pavilion a620n (PC028A) PC Desktop
My acer netbbook wont come on the power light is litt
Mother board or memory module can be the problem. First remove the cmos battery and switch on, if its ok then reinstall the cmos battery and see.check with other memory module or if you have 2 modules one at a time. If problem persists, try heating the motherboard display chipset with a blower, if you are a hardware technician. This should be done by only a professional as u can damage the motherboard and other parts. Last resort is replace mother board.
Sep 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
I am formating my system how to get audio drivers
Hi there
Get the audio drivers here:
http://www.download.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003-/3000-2120_4-10238712.html
Good luck and thanks for using Fixya!!!
Feb 12, 2009 | Lite On NA115 Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
ASROCK i665 chipset mother board problem
You are happy if only the motherboard got error, But i guess also the processors. You can test your motherboard by inserting identical processor that is working and also you can test your processor by inserting it to the identical motherboard. After testing and found either of the two got fault or both then replace. also test the memory by iserting it to other computer which is identical slot to your motherboard.
may this help,
melnavz
PS: pls do nto rate me if the solution won't satisfy but if this help the rate me favorable rating. thank you.
Jun 21, 2008 | Asrock 775VM800 Motherboard
Monitor displays signal cable disconnected
Check if motherboards you connect the monitor into has a video signal frequency range that the monitor supports.
Feb 01, 2008 | Dell UltraScan P1110 21" CRT Monitor
Toshiba Satellite A135-S2276 Notebook Logo
138 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
