Question about Asrock 775VM800 Motherboard
ASROCK i665 chipset mother board problem
When I switch on my pc, only fans work, n there is no display on the monitor. and processor gets heated much.. i wanted to know if i hav to replace my motherboard..
thanks in advance,
Basav
please mail me @ basavaraj1985@gmail.com
  • basav1985 Jun 24, 2008
    Hi melnavz,
    I gotta try whatever you have suggested..
    May be there is problem in motherboard. But for processor, i dont think, it ll have a problem, anyway, I will try once.
    Thanks,
    Basav
  • lenialmeida Sep 24, 2008
    Ola:
    Eu venho por este meio pedir ajuda tenho um pc que quando nós ligavamos e se mexexemos no teclado e no rato ele bloqueava...
    Fomos comprar uma memoria maior e agora não liga nem dá sinal...
    Será que dá para me ajudares...
    Isto é urgente o pc é de uma empresa...
    Obrigado
Just check your video card!!
Posted on Jun 24, 2008
    Genius:
  • 1,226 Answers
You are happy if only the motherboard got error, But i guess also the processors. You can test your motherboard by inserting identical processor that is working and also you can test your processor by inserting it to the identical motherboard. After testing and found either of the two got fault or both then replace. also test the memory by iserting it to other computer which is identical slot to your motherboard.
may this help,
melnavz
PS: pls do nto rate me if the solution won't satisfy but if this help the rate me favorable rating. thank you.
Posted on Jun 23, 2008
  • Emelio Navaja
    Emelio Navaja Jun 25, 2008
    Thank you for using fixya.
No display in monitor when i switch on my pc, i can see display on monitor after switching on the cpu for 5 or 6 times
Hello sir, hi, check out the following: I'm assuming the things that you may have forgotten.
1. is the 4 pin 12V Molex power connector connected to the mother board? 2. did you use a a good and tested memory module? have this module tested first on another PC. 3. Is your memory slot free of dust and dirt? if not clean it up. 4. is you power supply fan and processor fan spins when power is on? 5. Try powering ONLY the motherboard connected to a video display, no sata/ide cable with a tested memory installed. 6. try another Power Supply box. 7. Is your processor mounted properly? 8. when you apply power look at the keyboard lights, 3 lights initial power on then 1 light the numlock led is on. 9. do you have a plugged in usb device, remove this device as you power on the motherboard. 10. do every thing again and double check.
if all else failed, bad mother board. have this checked by a technician.
Oct 18, 2010 | Gigabyte GA-945GCMX-S2 Motherboard
May be this is the right place to post my query. Monitor is not responding but CPU fan is working fine. No problem with the Monitor and Power Supply as the same one is used with TV Tuner card and it's...
Colored screen = image corruption, caused by a failing video chip. Since this chip is part of the chipset that means that the chipset has failed.
Get a new motherboard.
Sep 17, 2010 | Asrock P4I45GV R5 Motherboard
Is the asrock k7vm2 motherboard easily replace by the k7vm4 asrock. my k7vm2 is dead and replacements are not easy to come by. I'm just looking for a new mother board to hook up to my hard drive and not...
You may be able to just swap out the motherboard for a K7VM4 motherboard but some of the specs are different like the chipset and graphics etc.
K7VM4 specs as follows >>>>
  1. Socket A(462) for AMD processor
  2. VIA® KM400 Chipset
  • ASRock U-COP
  • Hybrid Booster - a safe overclocking feature
  • FSB 333/266/200, DDR 333/266/200
  • Integrated UniChrome 3D Graphic.
  • 1 slot for AGP 8X/4X 1.5V
  • ASROCK I/O - default 4 ready-to-use USB2.0 ports on rear panel, default Game/MIDI port.
  • ATA 133 supported
  • On board default 10/100 LAN and 5.1-Ch Audio.
K7VM2 specs as follows >>>>>>>
  2. VIA® KM266 Chipset
  • ASRock U-COP
  • DDR 266/200
  • Integrated ProSavarage8 3DGraphic.
  • 1 slot for AGP 4X/2X universal.
  • Supports both DDR and SDRAM memory modules to provide you best flexibility and save your cost.
  • ATA 133 supported
  • On board default 10/100LAN and Audio.
As you can see the graphics and chipsets are different although the processor sockets are the same.
This could cause problems if you are going to plug the hard drive to another board but saying that is is possibe and has been done before.
This is a chance you take when you swap out a board for a different motherboard although i suspect that the transition should go smoothly.
A fairly old motherboard like K7VM4 or K7VM2 will not cost that much these days. You will find both motherboards for sale on eBay.
Regards.
May 27, 2010 | Asrock K7VM2 Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Sep 27, 2008 | Asrock 775VM800 Motherboard
Mpga478b
have u check ur memory?... ur videocard and powersupply...thats the main problem of pc if it has no display....just try it one by one...hope it can help u
Sep 10, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Display chip in mother board is not functioning
sorry but i dont know where are we going to put another fan in your cabinet......
Jul 19, 2008 | Intel Motherboard
ASROCK i865 chipset mother board problem
This could be a memory chip. Try that, if you don't have any luck, then chances are your problem is with the motherboard. Take it to a shop to have it diagnosed.
Jun 21, 2008 | Toshiba Satellite A135-S2276 Notebook
Monitor displays signal cable disconnected
Check if motherboards you connect the monitor into has a video signal frequency range that the monitor supports.
Feb 01, 2008 | Dell UltraScan P1110 21" CRT Monitor
Asrock 775VM800 Motherboard Logo
98 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
