Question about NEC PlasmaSync 42MP1 42 in. Television
Problem with NEC PlasmaSync 42MP1 42 inch - goes to standby w/no picture
Hi. My NEC 42MP1 plasma will power on, but I hear a high-pitched whine, hear a couple relays switch off/on and then goes into standby (red light) with no picture. I have read similar problems here, but no answers as of yet.. Any help is greatly apprciated. I tried holding down "INPUT" while powering up, as someone suggested, but no effect. Thanks for any help!
Regards,
Tom
  • thomas_h01 Jun 21, 2008
    One thing I did notice - if I hold down "INPUT" and turn it on, nothing changes. But if I hold down "INPUT" and "PROCEED" and turn it on, I get a Yellow light instead of green or red. Not sure what that means... but still no picture. :(
    If anyone can help, please do!
    Regards,
    Tom
    thomas_h01@yahoo.com
  • brokentv123 Jun 29, 2008
    I am also having the same problem. I heard it was a power supply capacitor, but I am afraid to do anything and make it worse. Do any of you guys have a solution, or maybe how much this repair should cost at a shop?
    Thanks!
Has anyone figured this issue out? Im really hurting without a tv,
Posted on Nov 18, 2008
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
My 42 inch plasma has a loud squeel in it
Hi
If you can hear any buzzing from more than a few feet then the TV is defective and needs to be replaced. Buzzing is a common defect among plasma TVs regardless of brand. It has nothing to do with the plasma cells working; usually it's a defective board or a power supply problem or something like that.
Also check this related article in the given link to get a detailed idea:-
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?AT_ID=14966&PROD_ID=
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 23, 2012 | Panasonic TH-42PX75U 42 in. Plasma...
My nec plasma tv seems to turn on for a few secconds then returns to standby,I took the back of it and tested fuses. 2 hi temp ceramic fuses were blown 4Amp any ideas?
Have you tried pressing the "Input select/Exit" button? Right after pressing the power button and the light turns green, press this button until you get to the right input that you are connected to, and hopefully you should see your picture. I had this same issue when I first got this T.V., Hopefully this helps!
Jan 25, 2010 | NEC PlasmaSync 42MP2 42 in. Television
Will not turn on
Its a faulty power board. The board will need to be replaced.
May 07, 2009 | NEC PlasmaSync 42MP2 42 in. Television
NEC PLASMA SYNC 42MP2 STANDY BY MODE?
According to the manual for "POWER/STANDBY indicator is blinking in red":
  • "The temperature inside the main unit has become too high and has activated the protector."
  • "Promptly switch off the power of the main unit ans wait until the internal temperature drops."
  • "If the monitor becomes too hot, the overheat protector will be activated and the monitor will be turned off. If this happens, turn off the power to the monitor and unplug the power cord. If the room where the monitor is installed is particularly hot, move the monitor to a cooler location and wait for the monitor to cool for 60 minutes."
Feb 04, 2008 | NEC PlasmaSync 42MP3 42 in. Television
NEC 42mpi plasma tv not working
Check the +170 volt  test point on the power board (not the power filter board, the one that the plug comes into) but the one to the right of that board. It has a 5v test point (TP +5v) , a +170 and a +70. I've found that the +170 transformer goes bad, and won't allow you to adjust the voltage using the pot screw.
Dec 29, 2007 | NEC PlasmaSync 42MP1 42 in. Television
Help
Same problem here. PX-42VM2A (NEC PlasmaSync 42MP2) Turns on (status light green) then goes to standby mode (status light red) after what sounds like some electrical relays clicking over. Opened it up and no glaringly obvious problem, but i'm no components technician so... Any ideas? Anyone want to buy it for parts or need a specific part? email me: 318noire<at>gmail<dot>com
Oct 13, 2007 | NEC PlasmaSync PX-42VM2A Television
NEC Plasma
thats bs, stop calling nec, there are plenty of repibuble repair shops who have or can get aftermarket part
Oct 12, 2007 | NEC PlasmaSync PX-61XM3A 61 in. HDTV-Ready...
Blank Screen
Hi Gemma - have a look at this forum - it may be similar to what you are experiencing. http://forum.eserviceinfo.com/viewtopic.php?t=5411&postdays=0&postorder=asc&start=0 Things don't look good for NEC owners I must say! Good luck Saty.
Dec 28, 2006 | NEC PlasmaSync 42MP3 42 in. Television
NEC PlasmaSync 42MP1 42 in. Television Logo
396 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
