Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Autorun.exe hi,, this is vignesh..... i've a problem in my pc.. that is autorun.exe is appeared... i dono to remove by using dos command
  • 67 Answers
Click Start >Run >type > msconfig >click startup >select disable all > restart machine > problem has solved
Posted on Jun 21, 2008
My pc was infected by virus from website, all my exe file was disable, they asking me to pay them to enable the lock code, what can I do to cure the virus...
download this and add allow it to add it to your registry restart pc and you will be able to open programs again
http://filext.com/WinXP_EXE_Fix.reg
Feb 25, 2011 | Computers & Internet
Tip
How to remove Autorun.inf
Here are some typical malware which can install autorun.inf.exe file to your computer and give your computer a critical strike.
Autorun.inf virus contains three execute files which are kavo.exe, ntdelect.com and autorun.inf. All of them are hidden files. You cannot find the by showing hidden files. The only way to find them is to use DOS command.
Not all user have computer savvy. I was suffered from this virus a lot. Success got rid of it using RegTool and want to share it with you.
To remove Autorun.inf
Tools you need RegTool and AVG anti-virus.
Also here is an easy way to remove Autorun.inf manually!
click Start>Run>enter “CMD” them you will see and command window. In the command prompt, you can search for any exe.files. First we can disable “read only” and “hidden” attributes.
Enter the word in prompt.
Check C drive: key in dir c:\/a/w
2 then
attrib -s -h -r c:\autorun.inf
attrib -s -h -r c:\ ntdelect.com
You can use the same way to disable attributes of other drive such like D, E, etc.
3 OK, everything is done, we can now remove these two files.
For C drive, you can enter
del c:\autorun.inf
del c:\ntdelect.com
The same to D drive
How about kavo.exe? You need to repeat step1 and step 2 to disable attributes.
The delete command is different with them.
attrib -s -h -r c:\windows\system32\kavo.exe
del c:\windows\system32\kavo.exe
last thing you should do:
Open registry editor by entering Regedit.
Go to HKEY_LOCAL-MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
Remove Kavo value.
on Jun 01, 2010 | Computers & Internet
Autorun a .exe automatically off a USB drive.
Open Notepad Type in: [autorun] open=PStart.exe action=Run PStart Program icon=PStart.exe label=My Portable PC Save the file as autorun.inf Put the file in the root of your USB flash drive The next time you insert your removable drive into your PC, the specified program will autorun from the USB drive
Of course you use your own names at the Commands.
Jan 26, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Worm.win32.autorun.blw virus appear in my system i already use kesper sky, but not solved. please advise a solution. thanx
When the executable is run on the victim's machine, the worm copies itself to the following locations:
  • %Application Data%\remove.exe (Copy of itself)
  • %Application Data%\autorun.inf
Where %Application Data% = c:\Documents and Settings\All Users\Application Data
Autorun.inf has following command
Exp: [autorun]
shellExecute=remove.exe
The worm adds a Run entry in registry so that it executes itself at every startup:
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
    "(Default)" = "%Application Data%\remove.exe"
Symptoms -
  • Presence of above mentioned files.
  • Presence of registry entries mentioned above.
Method of Infection Method of Infection - This worm spreads by using autorun.inf on shared drives and removable devices.
Removal - A combination of the latest DATs and the Engine will be able to detect and remove this threat. AVERT recommends users not to trust seemingly familiar or safe file icons, particularly when received via P2P clients, IRC, email or other media where users can share files.
Thanks for using fixya..
Sep 14, 2009 | Computers & Internet
How to remove write protect on my usb flash drive
Maybe you are infected with a virus. Run CMD on rrun command or get to run the Windows Dos Prompt. Goto flash drive drive letter. Then type DIR/AH, this will show you list of hidden files in your flash drive usually if you get an autorun.inf you are infected with a virus. Type TYPE AUTORUN.INF with the space in between.This will show you the script if it will run an exe command usually untrusted one. Usually the autorun.inf and the linked exe is attributed to be hidden, system, and read only.
If the files in your flash drive is not so important you can try to delete the autorun.inf only. But you will gonna do this first. In its drive letter type ATTRIB -H -R -S AUTORUN.INF hit enter. Then type DEL AUTORUN.INF. trying to access the flash drive in windows screen you can get that something is cannot be found. But you could actually delete and load files into it. Or try to access the drive rightclicking it then select EXPLORE.
Hope this help. Post comments if this does not help.
May 31, 2009 | iLO (2 GB) MP3 Player
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
Unable to delete the autorun.inf
hi azhar here form Karachi it is very easy. do, the below steps
reboot ur PC in safe mode with command prompt
when u bring a dos screen just move to ur drive mostly virus stayed in d: drive got d: drive and type
d:dir/ah and press enter
if u see there any auto run.inf file there also should be another file like .exe file or .bat or any kind of unknown , file so for delete the auto run file type attrib -s -h -r autorun.inf and press enter
then type del autorun.inf and hit enter here u go u have done.
do the samr process in all drives because mostly autorun.inf file make copy in all drives
remember autorun inf is just a file which help the virus to run autometicly
Feb 12, 2009 | Microsoft Windows XP Professional With...
Hidden file can't able to see friends
Hi
just delete files in MSDOS!
it will fix your problem! Type HELP for command in DOS.
good luck
Jun 24, 2008 | Microsoft Windows XP Professional With...
Funny UST scandal virus
Hello ppl,
Simply install PCTOOLS ANTI-VIRUS to Scan , Remove and then filter your internet for such threats... It's FREE... includes free updates too....
Easy.. XD
Nov 20, 2007 | Microsoft Windows XP Professional With...
How to edit registry
1) to edit registry go to start / select run and type regedit. from there you are able to edit registry values. BEWARE because editing registry values may make your windows stop working. you should know what you are doing and you are responsible of the cosnequenses 2) a bat file is a batch file. Batch files are files that allow MS-DOS and Microsoft Windows users to create a lists of commands and/or programs to run once the batch file has been executed. 3) create a file called autorun.inf and type inside [autorun] open=file.exe save your file and write it in the cd you want to autorun the file.exe part must be replaced with the executable you want to load when your CD autoruns
Oct 08, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
