Lost PIN code for Conia LCD TV
I have lost the 4 digit PIN code number for a Conia LCD TV.
I am now "locked" out of channel 10.
I can get all other Melbourne TV stations.
Can you help me?
redsfans10
  • 28 Answers
SOURCE: phone lock code is on,forgot 4-8 digit answer
try 123456.or you make new format,but remember to save u data or it will lose.if you not sure i think u sent it to shop..
Posted on Jun 13, 2007
SOURCE: freeview locked
The info>menu>mute>power on takes you to the engineers menu.
(Start with the TV switched off)
Use the direction keys, down to RESET,
then the right direction key performs the reset, the TV switches off.
On power again, the setup sequence runs for both TV and DTV.
I had exactly the same problem as p111upr and this fixed it.
Posted on Dec 22, 2007
davebies
  • 43 Answers
SOURCE: Sony LCD Digital Color TV Model KDL26M300
If you only have basic cable with no cable box this may be normal. You may need to upgrade your service or get a cable box.
Posted on Jan 05, 2008
mewms_14904
  • 1027 Answers
SOURCE: I LOST MY BOOK ON MY 3300 ONE FOR ALL BIG EASY I NEED 4 DIGIT CODES FOR ORION VCR AND PHILIPS TV THANK YOU.
http://www.hifi-remote.com/manuals/ is for the manuals for one for all.
For most remotes check out this
http://www.remotecodelist.com/remotes/
Posted on Mar 04, 2008
Shuttle83
  • 1139 Answers
SOURCE: Analog / Digital stations
Hello mikekahan,
OK you are not going to like this but here we go any way. First of all I need to explain how your channels are created.
When the RF signals come into the headend of the Down converters they are separated into pre channelized designations DC (Down Converter) 4 Stream 1 (DC 4-1, DC 4-2...) now once this is done the down converter signal is fed into a channel processor which takes the incoming signal from the Down Converter remodulates it and puts it on an assigned channel 4-1 could become channel 4, 4-2 could become channel 5 and so on. Once this is done you end up with your regular channel line up for analog channels, now for digital its a little different you have IRDs (Integrated Receiver Decoders) which take the off air or satellite Digital RF signals and convert them into MPEG Streams which is the fed into what is called a SEM (Motorola Architecture) Stream Encryption Module which assigns numeric designations to the MPEG streams and then converts the MPEG streams back into RF. Now at this point we have analog and digital signals what then has to happen is the the analog signals must be turned into MPEG streams to go through the system so what happens is from the channel processor the analog signal is put into a SE (Stream encryptor) Like the SE1010. This takes the analog stream and turns it into am MPEG stream and feeds it into the SEM also and the SEM assigns a numeric designation just like the digital signal and this can sometime follow the same numeric designations as was obtained from the Down Converter, So what you end up with is analog and digital signals having the 4-1, 4-2, 5-1, 5-2, ..... format. This is where other equipment comes into play These designations are then kept in a database and are matched to their proper channels by use of the DAC and RADD along with an IPG server. These allow the SEM to assign true channel designations to the converted channels, now the SEM DAC, and RADD talks to your STB, this is way the channels are correct because the SEM and the DAC/RADD are matching what is on the IPG (Interactive Program Guide). When you remove your cable box the tuner in your TV does not know how to deal with the DAC, RADD and IPG signals so it only displays the RF information which is the 4-1, 4-2, 5-1, 5-2 data.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Feb 27, 2009
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
Conia home page
Try this link.
http://www.alibaba.com/
Jan 22, 2014 | Televison & Video
Factory reset press
Channel guard and V-Chip settings are protected by a four-digit lock code. Your TV comes preset
with a lock code of 0000 You may change the code to any four-digit number you wish. To
change the lock code, follow the steps below.
Press the MENU button
To "Initial Setup"
To enter
To "Set Lock Code"
To operate (Password input screen will appear)
Enter the password by using the 10 button
keypad
The Set Lock Code screen will appear
To set the password, use the 10 button keypad
Press the OK button to finish your lock code is now set
Oct 15, 2013 | JVC LT-32E488 32 in. LCD Television
Lost pass code for v-chip
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
If you wish to know more, check this link.
Jan 17, 2013 | JVC AV-32F485 32" TV
Password for jvc tv v-chip
Jan 17, 2013 | Televison & Video
Lost ITV channels and C4
I think you need to get Sky because it will give you 100% coverage of all terrestrial channels. You may need to retune the television otherwise just get sky
Dec 31, 2008 | LG 32LX1D 32 in. LCD Television
I've got exaclty the same problem :-/
HELP!
Oct 06, 2008 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
I have the same problem, can anybody help?
Jun 15, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Conia tv remote codes
I have a Conia LCD TV and the remote died, I purchsed a universal remote and without the codes even on search modes could not get it to find the t.v. I found theat DJ Electronics sell replacement Conia TV remotes online. So if you just need areplcement remote, know your TV model number and you can just replce your old remote.
Jan 21, 2008 | Televison & Video
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
