Question about Paradyne 6211 ADSL2+ Router (6211I1200)
Router is connected but no internet
Sir
I have a paradyne router and i can access the router remotely but internet is not working at my home . once or twise it came and went off in 10 minutes . what could be the problem
  • marlon john madrid
    marlon john madrid May 11, 2010
    does this happen everytime or just when you're accessing your router remotely?
    who's your ISP and the brand of the modem?
    Genius:
  • 1,689 Answers
I will have to pass this, nasar please feel free to post updates on your question
Posted on Jul 30, 2008
Have you checked the phone jack that the router plugs in to? This or the wires or cables could be faulty. Had similar problem recently.
Posted on Jul 19, 2008
Paradyne 6218
The router must provide new internal IP's. Make sure it is set to DHCP. IPs are never shared.
Mar 29, 2013 | Paradyne (6218-A1-200) Wireless Router...
I'm trying to connect a remote desktop equipped with Linksys network adapter to internet via a home LAN. Though the network shows that it is connected to the home LAN, when i attempt to connect to...
The setup disc for the router only needs to be run once when setting up the router to work with your internet provider and modem/router. You can try putting the disc in your desktop computer and reconfiguring the router.
Feb 28, 2011 | Cisco Linksys WirelessG Broadband Router...
How to reset Paradyne (1740A1400) Router ?
Hi Samsungvt!
You will have to access the Web Interface of the Paradyne Router to reset it to Factory Defaults.
First, connect your PC to the Paradyne Router. Check your IP address is in the range 192.168.1.xx (xx = any number from 1-254). Open your web browser, type 192.168.1.1 then press enter. Enter the default username and password (shown below) to access the router's web interface. On the left pane, click Erase and Reboot; this will reset the router to factory default.
Default IP address is 192.168.1.1
Default Username and Password: root
Let me know if there's anything else...
Anthony
Jun 21, 2010 | Paradyne (1740A1400) Router
HOW TO CONFIGURE MODEM OF PARADYNE(ADSL 2+)
Basically if your Internet service is DSL or cable it's just a plug and play. Just plug the computer to the modem once the Internet access has been activated by your ISP and your computer should automatically get connection from the modem.
Aug 16, 2009 | Paradyne (6211-A2-200) Router
My pc can't access the internet
Do one thing when you want to connect internet do obtain ip automatical
after do this thing i hope its work fine
Thanx
Chetan
Nov 22, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
Port forwarding
try to use another port number aside from 8080, like 3000 or 5000. make sure that the ip address set on the router is the ip address of your camera (note: it should be set to static).
hope this'll help you
ciao
Oct 22, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
Router administration access
Hi Neomonkey,
It seems like you have a very big problem. If you are successfully connnected to the wireless router, you can check the the ip address of the router by doing an ipconfig in command prompt, check the default gateway and try to access using IE browser. The next problem is accessing the router when you are prompted to enter the username and password, the default is username: admin password: admin, depending on the model, if it is customized, you will have to reset the router to access it and configure the mac filtering or enable wireless security to deny the person who is taking up your bandwidth. You dont have to access the Paradyne modem to configure everything, if you want to find out if it is running DHCP, you can connect a PC wired(straight UTP cable) with all the network settings at default and check if you can get an ip using ipconfig with the command prompt. The main thing here is to reset your wireless routers to factory defaults(use the button at the back) to re-organize your connection and setup a security for unwanted users.
Inform me if there are other questions or clarifications you need regarding the problem.
Thanks,
Mrvin
Oct 21, 2008 | Linksys Wireless-G WRT54G Router
Using both USB and Ethernet to connect to the internet
Does your router suports usb ports, normally routers do not support usb ports, please check if your router first suports usb ports
Jul 22, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
Using both USB and Ethernet port to connect to the Internet
Hi; I have used it with both ethernet and usb connections at the same time. I have never used the bridge, but I use it at home.
Try this ( I have XP SP3): Right-click on the monitors where the clock is (lower right corner), select "Open Network Connections". Go to the LAN connection and r-click "Properties". On the "general" tab select "Internet Protocol (TCP/IP)". There you select "Obtain IP address automatically" and "Obtain DNS server automatically" then click "Ok" until exit. Either Shut Down or Restart the PC. Check if this work.
Jul 19, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
Paradyne 6218-12-200 won't connect all computers
A public IP address is usually assigned to the WAN port (outside/public side), which is how your router is conected to your Internet provider service.
A private IP is always assigned to the private network side (LAN = Inside). Unless you are hard coding your IP addressing on each of your devices, you will need to have DHCP enabled in your router with enough user IPs for your devices (more than 1).
Apr 11, 2008 | Paradyne (6218-A1-200) Wireless Router...
Paradyne 6211 ADSL2+ Router (6211I1200) Logo
69 people viewed this question
Top Paradyne Computers & Internet Experts
CKsystems
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
