Small pin hole in lcd monitor - Computers & Internet
    Guru:
  • 859 Answers
Does this look like a pin hole or is it leaking fluid?
Regards,
Worldvet
Posted on Jun 21, 2008
MHC-RG270 cd draw won't open
cd drawers often jam.
In the cd/dvd drawer you will see a small hole. Use a blunt pin or a straightened-out paper clip, insert it into the small hole and gently press. The drawer should then click open.
Try cleaning the plastic drive teeth/mechanism with a light drop of oil. Press the drawer button and it should then close. Press it again to see if the drawer opens as per normal.
If your cd drive plays a dvd as per normal but doesn't open when the button is pressed, continue using a blunt pin/paperclip. If the plastic open-close mechanism is worn or damaged there's very little you can do about it expect replace the entire drive.
Feb 01, 2014 | BenQ FP91G+ 19" LCD Monitor
Is any displayport have in Intel D865GBF Motherboard
Yes
It has a VGA port for a VGA monitor. The port is BLUE in color, NOT PURPLE.
This is an example of a VGA Cable, and a VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
Note the number of socket holes, and the arrangement of the socket holes.
There are 5 socket holes across the Top row.
There are 5 socket holes across the Middle row.
There are 5 socket holes across the Bottom row.
The Purple connector with 5 socket holes across the Top row, and 4 socket holes across the Bottom row, is NOT it.
Not the VGA connector.
You can connect a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor, IF it has a VGA cable.
[ There is also an adapter that you can plug a flat LCD screen monitor into, and the other side of the adapter plugs into the VGA port, on the back of your computer.
This is if the flat LCD screen monitor has a DVI cable,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
DVI to VGA adapter,
1) http://www.directron.com/dvitovga.html
2) http://www.directron.com/dviadapter.html
Look at the pins on the adapters. Now look at your monitor cable, and the VGA port on the computer. Make sure which adapter you need ]
For additional question please post in a Comment.
Regards,
joecoolvette
Jun 18, 2012 | Intel D865GBF Motherboard
Emachine disk door want open
I'm assuming the CD drive door is stuck and won't open. You will see a small hole in front of the drive. Take a pin and insert it in the hole and push it. The drive should open up.
May 05, 2011 | E-Machines e15t 15" Flat Panel LCD Monitor
Can i hook my 47inch tv to the monitor
You can't hook you TV to the monitor itself, rather the computer.
If your PC has a wide white connector (DVI) that is supplying signal to the monitor, you could use a DVI to HDMI adapter cable to connect your PC to your TV. This is also possible if your PC uses a small blue connector with 15 pin holes (VGA) by using a VGA cable to connect your PC to your TV.
Mar 17, 2011 | Acer AL1916W 19" LCD Monitor
NO LEADS, CAN I USE MY LEADS THAT FITFROM OTHER PC/MONITOR?
Hi.
Yes, you can use the monitor leads from other monitors, just make sure that the pins are the same.
Some monitors have a 9 pin connector, and others have a 15 pin connection.
The jacks will look the same, but the 9 pin version will have the other pin holes filled in.
As a rule though, most modern monitor cables should work for you.
I hope this helps, and good luck.
Mar 14, 2011 | Hansol H550 15" LCD Monitor
A disk that the cable rep put into the system to log into the internet will not eject.
On the CD drive's front panel, if you look closely, you will see a very small hole big enough for a pin to go through. This is the force eject. Take a paper clip and bend it so that it will be long enough to go through the hole. Push the paper clip's end into the force eject hole and the cd tray should pop out. Hope that helps.
Oct 27, 2009 | Gateway FPD1975W 19" LCD Monitor
Where do you plug in the power?????
It is powered with a 12v DC adapter:
The small round hole with the pin in the middle..
Hope this helps
Happy New Year!
Chris (ziraffa)
Dec 31, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Connecting a FLat Panel TV to me PC
Check your owners manual.
You need either a 15 pin VGA cable or a DVI (Digital Video In) cable.
Look at the back. If you have a small D-Type connector with 3 rows of 5 holes you need the VGA cable.
Of you have a rectangular connector with rows of angular holes and two slotted holes on one side then you need a DVI connector.
If you're current monitor cable is removable from your monitor you can likely use it.
Nov 04, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Computers & Internet Logo
David Payne
David Payne
