Question about Microsoft Wireless Notebook Optical Mouse VSBX300001
Microsoft Wireless Notebook Optical Mouse 1023 Need Driver
Need driver for Microsoft Wireless Notebook Optical Mouse 1023
  • 12 more comments
  • expand Jun 21, 2008
    RI!P OFF
  • bicentenial Jul 06, 2008
    need a driver, mouse works but USB doesn't light up.
  • Prap Aug 02, 2008
    i wanna know about Microsoft Wireless Notebook Mouse model 1023, is there any driver software need to that mouse, please tell me sir
  • ksprints Aug 15, 2008
    I'm running a vista desktop and in need of the driver to download.
    chris
  • Anonymous Aug 22, 2008
    drivers
  • personnne Aug 28, 2008
    I just have a new computer with vista.
    I have some problems with my mouse, it's like if the computer didn't recognize the mouse
    Is it because of vista ?
    Thank you
    (sorry for my english if it's incorrect, i'm french)
  • Anonymous Sep 12, 2008
    im having the same problem.. it isnt my usb ports.. they all work fine. its something to do with the mouse.. :( sucks i use it got gaming.. someone please help!
  • jb10 Oct 24, 2008
    same problem. i am unable to locate a fix for this.
    any one have any luck finding a resolution?
  • Anonymous Dec 03, 2008
    wase
    xsx
    sx
    s
    x
    s
    rfxcfzgy2552534526tutxhxvhgstxbmsn xxsxjsjx
    xhsxjnsjhxs
    xñs
  • Scamper91367 Dec 11, 2008
    The receiver light was intermittent, but now it's off all the time. I've only had it for one year. I believe an internal wire broke.
  • lukman_elhas Jan 31, 2009
    i cann't find the drive
  • Anonymous Apr 14, 2009
    none of these solutions resolves my issue, this is my 2nd MS mouse that has failed and the 1023 did it in less then a year. Any way to fix the USB jack where I think the problem is?
  • Anonymous May 03, 2009
  • Anonymous Mar 13, 2014
    just need thye driveri need the driver optical 0-tical mouse #1023
I wanna know about Microsoft Wireless Notebook Mouse model 1023, is there any driver software need to that mouse, please tell me sir
Posted on Sep 03, 2008
This is the driver installation program. Just run it and select which mouse you have (which should be wireless notebook optical mouse, according to your post). And then restart your computer and VOILA! Your mouse should work! Good Luck.
http://www.mediafire.com/?sharekey=9144041283e5344bd2db6fb9a8902bda
Ivylinn
Posted on Sep 19, 2008
I had the same problem, and I fixed it by opening up the mouse and cleaning off the circuit board using rosin solder flux solvent. Apparently something, possibly fluid from a leaking battery, had gotten on parts of the circuit board. When I reassembled the mouse, it now worked perfectly.
WARNING: do this only if you feel comfortable disassembling small electronic devices and only as a last resort as you risk ruining the mouse. To disassemble the mouse, peel off the four glued-on rubber feet on the bottom and then remove the four Phillips head screws underneath the feet. Then carefully disassemble the top half from the bottom. You can then lift the circuit board out. Here's a link to a breakdown and images of a similar Microsoft wireless mouse:
http://techrepublic.com.com/2346-10877_11-88648.html
After I opened the mouse I used the brush in the solvent to wipe off any suspicious-looking areas. A magnifying glass or low-power microscope can help find contaminated areas. The solvent I used was m-line rosin solvent which is 50% isopropanol and 50% toluene. You probably could use either of these solvents by themselves as well. Be careful with anything containing toluene, since it could disolve rubber and possibly some plastics, remove paint, etc. so don't get it on the mouse body.
When you reassemble the mouse, make sure to properly replace the little plastic disc that has a nub poking through the "Connect" hole on the bottom of the mouse. Once you reassemble the mouse, hopefully it will now start working again.
Posted on Dec 19, 2008
Driver notengo el disco
Posted on Nov 15, 2008
If it was working and it started to fail and now won't work at all, don't bother with the drivers. I found that if you wedge something between the USB receiver and anything below it, so the receiver is angled upwards, you can get connectivity and it will work fine.
Example: I have 2 USB ports vertically aligned. I stuck a nail in between the the two so the mouse receiver (on top) was angled upwards and the connect button illuminated.
It will sometimes turn off if you bump it. Also, if this solution works and it is disconnected and you try plugging it in and it wont work, restart the computer and try again - this has worked for me. Hope this solves your issues. If not, try pricewatch.com or newegg. You can find a wireless mouse for $5-10 USD.
-Travis
Posted on Dec 18, 2008
Software need
Microsoft uses Intellipoint for all its supported mice. You can download it off Microsoft's website.
Aug 02, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft wireless notebook optical mouse 1023 - not working!
If you know that the battery is good then try this next. There is a VERY tiny shark-fin shaped spring-loaded button on the bottom of the mouse that is pressed in, when you insert the receiver, while the mouse is not in use, that turns off the mouse to save the batteries. If you haven't used the mouse in a while, it can get stuck in the in position, so that when you pull out the receiver, it doesn't spring out and turn the mouse on (indicated by the red light on the bottom). If you notice that the light isn't coming on. Just try manually pushing in the little shark-fin thing a couple times to make it spring back out. After a couple times, you should be able to get it unstuck and the red light should come on.
Feb 24, 2009 | Microsoft Wireless Notebook Optical Mouse...
I need a driver to instal my device
You can find the drivers here: http://www.microsoft.com/hardware/download/download.aspx?category=MK
Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Model 1023
windows should come with drivers for it, but microsoft.com has a full suite of intellipoint drivers available for all its mice which adds functionality windows drivers don't give it. If it is not working at all the problem is most likely not driver related.
Aug 02, 2008 | Microsoft Wireless Notebook Optical Mouse...
Wireless optical mouse model 1023
thr mighty b a problem in light which emit out from ur mouse
May 30, 2008 | Microsoft Wireless Notebook Optical Mouse...
MICROSOFT WIRELESS MOUSE NOT WORKING LIGHTS ON CURSOR NOT RESPONDING
I have the same problem with the 1023 MS wireless mouse. I called MS and they said that for a charge of $120 (the price of 1 yr service for my computer) they can fix the problem. I think it's cheaper to buy another (but different mfg) mouse. My computer operates quite well and don't believe I need this service.
Thanx...CPT
Mar 14, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse VSBX300001 Logo
20,988 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
