Question about Soyo Dragon P4I845PE Barebone
No sound My computer worked fine till last Lost the sound.I cheked into control panel and into dxdiag.exe All I can find is sound not working no sound device & no mixer I tried to load drivers from cd that came with board. Now it wil not load them I know it had ac97 audio there but I can pull only mup401 installed what evey that is Thanks Lenny
  • 85 Answers
The problem lies withn windows. I would reccomend performing a system restore to a date when it was working. While you wont lose your documents, emails etc, it will uninstall any apps you have installed since that date.
Posted on Jun 21, 2008
How to download sound device
It all depends on the make of the sound device, to find this out run dxdiag.exe Which can be found by searching for 'run' then typing 'dxdiag.exe' into it to run that program.
You should be able to find the make of the sound device under the sound tab, as well as the provider.
a quick search should give you the website of the provider to find drivers relevant to the product.
Mar 01, 2011 | Cycling
No audio
heare is full solution of sound and sound card....
First, test your speakers by connecting them to another sound device like CD/DVD player or a similar device. If you can hear sounds from the speakers, they are fine. Next, connect the speakers back to the computer. Make sure that you plug them into the right colored jack at the back. The speaker pin should be plugged into the green jack at the back of the computer.
Now, if you can't see the speaker icon in the system tray, you may need to enable it from the Control Panel. From the Control Panel, double-click "Sound and Audio Devices" and check the box that says "Place volume icon in the taskbar.
Next, run the following command from the Start -> Run box and then press Enter: dxdiag
Click on the Sound tab and you can see the details of your sound card. You can also test your sound card from this tab. Note the name of the sound card driver, on paper. If you can't even see the sound driver name, the driver is not installed or not installed properly.
The easiest thing that you can do now is to do a system restore, using the System Restore utility.
Here's a link about how to use the system restore utility on Windows XP:
http://www.microsoft.com/windowsxp/using...
Here's a link about how to use system restore from Windows Vista:
http://www.howtogeek.com/howto/windows-v...
If System Restore didn't make the sound work, do the following:
Start the Device Manager (Right-click My Computer -> Properties -> Hardware -> Device Manager) In Device Manager, Click the + sign next to "Sound, video and game controllers". See that the sound driver that you noted above, is listed.
Now, double click the item in that list that has the same name as you saw in dxdiag's sound tab. Does Device Manager say that the device is working properly? If Device Manager says that the audio device is not working properly, or if there is a yellow exclamation mark next to the device, or if it says that the drivers are not installed for this device, install the drivers from the CDs or from the computer manufacturer's website. However, there's an easier way to do this, as given below.
Here's the easy way to get or update your sound drivers:
You could try to use this driver scanning tool, which scans the computer for needed drivers and has an option to automatically retrieve them for you.
You can download this free tool from here: http://xpdrivers.com/index.cfm
or directly from this link: http://xpdrivers.com/download/download.c...
After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers.
It's also possible that the drivers are there but the sound card was displaced a bit from it's slot (in case you have a separate sound card on your motherboard, and not a built-in one).
If you suspect this, you should open up the computer and pull out the card. Then, re-insert it firmly into the slot or try another slot if you have another one free. Make sure to tighten the screw to fix the card to the case, and put one there, if it's missing.
If none of the above methods worked, pull out your sound card and test it in another computer. You can also try re-installing Windows and lastly try another sound card, if it still fails to work.OR at last go to near computer shop.
Hope that helps,
Regards,
Pankaj
Feb 12, 2011 | Computers & Internet
I got no sound on computer and i wanna listen to music.
Hello hosamali ,
As you say you have no sound on computer.
here is full solution of sound and sound card....
Now, if you can't see the speaker icon in the system tray, you may need to enable it from the Control Panel. From the Control Panel, double-click "Sound and Audio Devices" and check the box that says "Place volume icon in the task bar.
http://downloadnew.org/software/realtek-gigabit-lan-driver-v686/
or simply type your motherboard name on Google search and download
Now, double click the item in that list that has the same name as you saw in dxdiag's sound tab. Does Device Manager say that the device is working properly? If Device Manager says that the audio device is not working properly, or if there is a yellow exclamation mark next to the device, or if it says that the drivers are not installed for this device, install the drivers from the CD or from the computer manufacturer's website. However, there's an easier way to do this, as given below.
If you suspect this, you should open up the computer and pull out the card. Then, re-insert it firmly into the slot or try another slot if you have another one free. Make sure to tighten the screw to fix the card to the case, and put one there, if it's missing. Here's a you tube video about how to install a sound card:
http://www.youtube.com/watch?v=wp4TDe814...
If none of the above methods worked, pull out your sound card and test it in another computer. You can also try re-installing Windows and lastly try another sound card, if it still fails to work.Than at last go to near computer shop.
Hope that helps,
Regards,
Pankaj
Dec 22, 2010 | Abit 64/64FX AMD SOCKET 939 ATHLON NVIDIA...
No sound heard
Hello dnagodh
If you suspect this, you should open up the computer and pull out the card. Then, re-insert it firmly into the slot or try another slot if you have another one free. Make sure to tighten the screw to fix the card to the case, and put one there, if it's missing. Here's a youtube video about how to install a sound card:
Hope that helps,
Regards,
Pankaj
Dec 21, 2010 | Computers & Internet
No sound
Hope that helps,
Regards,
Pankaj
Sep 25, 2010 | Computers & Internet
Sound card problem
hi
http://www.microsoft.com/windowsxp/using…
http://www.howtogeek.com/howto/windows-v…
or directly from this link: http://xpdrivers.com/download/download.c…
http://www.youtube.com/watch?v=wp4TDe814…
Jul 21, 2010 | Toshiba P000223420 - SOUND BOARD, FVRSD5
Asus M2V Audio problem
in the bios because you set HD audio to audio it may be that you need to download the HD Audio driver from microsoft
Apr 14, 2009 | ASUS SiS Chipset TUSI-M Motherboard
put your hand on chip of your sound card on board if its hot so sure you need to disable and buy sound card or replace this chip also check audio jumper on board and try to install windows again and install the driver if u see on task bar sound volume icon check by tested headphone if there is out sound or no i wish i helped u
Jan 02, 2009 | ASUS M2V Motherboard
Microphine not working with Microsoft UAA Function for High Defin
I bet you have to uninstall the sound card from device manager first and the restart the computer. Then try to install the sound driver again. If that does not work you may have to force install the driver from the add new hardware wizard in control panel.
I am curious, do you have a dedicated graphics card installed from ATI / AMD?
Newer ones have a built-in high-def audio also.
Dec 18, 2008 | ASUS M2NPV-VM Motherboard
Graphics card
Hello.
If want to see your installed devices go to:
Start - Control Panel - Double click in - System icon - Hardware - Device Manager.
You will find the graphics card under:
Display Adapters, just click on +.
Or click on - Start - click on RUN, type DXDIAG , click ok - if is your first time running dxdiag click ok till you get to the dxdiax window then click Display, there you can see almost evething in your system.
Hope this help.
Jul 09, 2008 | Nvidia Computers & Internet
Soyo Dragon P4I845PE Barebone Logo
73 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
