Question about SanDisk Sansa c150 MP3 Player
Sansa C150 No Space for DB. Please free more than 4.0 MB
No Space for DB. Please free more than 4.0 MB appears when I start my Sansa C150 mp3 playe. Formatting it says Format complete but the free space is still shows zero bytes free.
Tried Firmware update utility, but no use.
Please assist
  • 2 more comments
  • sharyl25 Mar 12, 2009
    when i turn my sansadisk on it says not enough space for music DB please free 30MB
  • indydang Apr 14, 2009
    My problem is the same as tikkam's. I receive the same massage every time I turn it on. I also can't access the music files from my computer. I don't want to reformat the device before I recover my music files. anyone knows how to recover a flash drive?
  • tejashbhagat Apr 22, 2009
    my sansac150 are not connect so solve them
  • Anonymous Mar 21, 2014
    i need to create 100 mb of free space
  • 85 Answers
Are you able to format the player while in msc mode?
right-click on it while in my computer and select the format option, make sure your selecting your mp3 as this will delete all the files off the device. It if says failed to format, try doing it thorugh disk management. To get there you can right-click on my computer and select manage from the drop down menu. From here you will see disk management on the left hand side. Then a larger rectangular box with the drive letter that represents your player, you can right click on this and select format.
Or just try a different computer, if its the same everywhere then youll probably have to end up emailing sandisk, stating everything you tried. They will probably ask you to do a couple more things, but if you keep at it, youll end up with an RMA*.
*RMA = Return Merchandice Authorization
Posted on Jun 21, 2008
MTP Format Mismatch DB. Delete 4 MB error. I downloaded firmware and could not fix it.
fomatted without software know i cannot updae with new songs .display showing icons without any information
Jan 01, 2011 | SanDisk Sansa c150 MP3 Player
My sansa sandisk c150 doesnt work
Just follow these steps below:
To format the mp3 player.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format it with fat files system or the file system you are accustomed with.
hope this help you
Regards
uttam
Jan 12, 2010 | SanDisk Sansa c150 MP3 Player
MP3 not switching on.
I don't know exactly what's wrong but i'm on a hitch just connect the sansa to the computer delete 40 mb and it should work good luck
Jan 10, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
"MTP DB Mismatch Format?"
The Insignia NS-DA2G needs to be placed in File & Folder mode, and you'll need to have your mac show you all files on the device. Macs will create a smaller file that starts with "._" that contain very little information, but can cause problems with Windows based or Windows preferred devices. These files are not ignored by the PC or certain Windows optomized devices. You should erase these files for the unit to perform normally.
If you are unable to delete these files, you can re-format the device to FAT-32 and that will erase all information on the device. You shouls also hit the reset button (located next to the "HOLD" switch) for about 5-10 seconds to clear the internal settings.
Jan 10, 2008 | Insignia NS-DA2G MP3 Player
Music DB??? clear 6 MB???
Have you tried re-formatting the device?  This will "wipe" memory, getting rid of corrupted files, etc. and should restore use.
Oct 24, 2007 | SanDisk Sansa e250 MP3 Player
Mismatch Format
I have formatted it. No songs available when opened the playlist. But when I start the unit it shows "NoSpaceForDB Please Please Delete More Than4.0M.B". The property shows the "0 Memory is free".
Aug 30, 2007 | SanDisk Sansa c150 MP3 Player
MTP DB Mismatch Format? Please Delete More Than 4.0 MB
most reliable way to clear the device is to use the firmware update utility.
version 1.005a can be downloaded here
Aug 21, 2007 | SanDisk Sansa c150 MP3 Player
"formatting problem"
I had a similar problem, I could upload songs, but they wouldn't play and I couldn't delete them. turned out it was cause I didn't have WMP10 installed on my PC, had an older version. the user manual states it only works with WMP10, and after I installed it (just search for windows media player 10 on the microsoft website) I was able to use the synch function in WMP10 and all the songs are playable (I'm listening to an album as I type :D)
Dec 04, 2006 | SanDisk Sansa c150 MP3 Player
Error message: Not enough space for music DB. Please free 4MB.
Hi I have just bought a Sandisk Sansa M250, we loaded som music on it and it lasted 2 hours, then it the message came "Not enough space for music DB please free 8 MB". I couldnt even go in to the menu. I contakted Sandisk.com and 24 hours after they came up with an answer. If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it. Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player. If not already done, please also update the firmware from this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1368 The 20 seconds on the power button didnt work, but the formation did. Hope this helps. //Cadmann Please bear with my english
Aug 20, 2006 | SanDisk Sansa m240 MP3 Player
Open Questions:
SanDisk Sansa c150 MP3 Player Logo
385 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
