Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Diagram for a denso diesel injector pump off an 85 2.4lt hilux
Have a look at www.toyodiy.com
Posted on Dec 29, 2008
I have a Toyota Hilux 2.8 diesel 3l engine injector pump has great pressure on only 3 cylinders but number 4 is lacking pressure enough to make it miss , what can corse this problem
You didn't say but presumably the engine uses a DPA type or distributor type injection pump.
In this case the injector line pressure is governed by the condition and setting of each injector. If the break-off pressure of an injector is set to 80 atmospheres that pump element will produce a pressure of 80 atmospheres.
If one injector becomes "soft" and worn so the break-off pressure has fallen to 20 atmospheres for instance, or if the injector sticks open, the pressure generated by the pump will be either 20 atmospheres or virtually nothing.
When a conventional diesel engine develops a misfire, best practice is to ensure valve clearances and suchlike are in order, the compression pressure is good and then independently test the injector (and heater plug).
If everything is in order the pump should be removed for testing, repair and recalibration.
Jun 07, 2017 | Toyota Cars & Trucks
How do i remove the injector pump from my toyota 2kd hilux
diesel pump
follow the pipes from injector that will lead you to fuel pump.
you will have to take fuel line off from injector so it make it easy to remove them from pump...
4 bolts and pump is out
May 22, 2016 | Toyota Cars & Trucks
How to connect a toyota hilux d4d denso alternator with a 4 pin plug
how to connect a toyota hilux d4d denso alternaton with a 4 pin plug
Feb 22, 2013 | Dodge Grand Caravan Cars & Trucks
My hilux wont start i replaced a seal on the pump now wont start got fuel to the pump dose not seam to be getting to the injectors
if this is a diesel L or L2 engine chances are you've got trapped air in the steel lines from the injection pump to the injectors loosen- but do not remove- the fitting holding the fuel lines to the injector start/crank the engine until fuel spurts out the loose fittings. tighten fittings. start the engine. this will have the engine running if the problem is trapped air.
Jul 19, 2011 | 1983 Toyota Pickup
2.8 ltr hilux leaking diesel at rear of injector pump
The gasket must have gone and could be resulting in the leak when the pressure build up. Check if there is any chance to tighten the injection pump , if there is a possible looseness in the fitment.
If not the pump must be removed off, the gasket replaced to stop the leak.
Nov 12, 2010 | Toyota Pickup Cars & Trucks
Toyota Surf Diesel starting problem
Injectors could be blocked but i would go with an injector pump or fuel pump.
Jan 20, 2009 | 1995 Toyota 4Runner
Surf 1KZ-TE Diesel wont fire
I have the same problem. it just wont start one morning. can you please help me in case you have solved your problem already.
Need a diagram for 94 3l diesel hilux timing belt replacment pls.
Hello Paul
I hope this help you
6a737ed.jpg Regards Paul
www.limotec.co.uk
If you need more please contact me
Jan 13, 2009 | 1994 Toyota 4Runner
Toyota hilux no fuel to injectors
im not sure on that particular vehicle but most trucks have a fuel pump shut off if the vehicle gets hit or is jarred real hard look in your book for the fuel pump reset button it is a inertia switch
Dec 11, 2008 | 1995 Toyota Pickup
Toyota hilux surf problem
hi there, i had exactly the same problem with mine. all i did was to turn up the diesel pump a little. cheers d
Sep 09, 2008 | 1995 Toyota 4Runner
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
1,276 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
