Dyson DC08 Cylinder Bagless Canister Cyclonic Vacuum Logo
Anonymous Posted on Jun 21, 2008
Dyson DC07 - broken 'Contact Head' release clip
My Dyson DC07 has a broken release clip (spring loaded) that fastens the Contact Head to the wand. I have a spare rotating brush nozzle, that I never use, and would like to swap the clips over. As I don't want to break the head in the process, what is the method of disassembly to gain access to the clips?
Anonymous
Level 2:
Novelist:
  • Expert 167 Answers
  • Posted on Jul 16, 2008
Anonymous
Expert
Level 2:
Novelist:
Answers
167
Questions
0
Helped
155804
Points
338
Hi Wombat64
We noticed you are having difficulties with your Dyson vacuum cleaner. We think we can help, simply call our Customer service team for free on 0800 298 0298 between 7am - 10pm, 7 days a week.
We look forward to hearing from you.
Darran
Dyson Customer Service
2answers
Dyson DC25 -wand extension lost a spring and becomes disconnected during use. I don't know where spring should be?
The button you push to release the wand has a spring to allow it to spring back after the button has been released. If that spring is missing the wand will not stay attached.
The clip inside the hose for holding the tube (small yellow spring clip) is broken or needs anew one
I'm sorry to hear you're having difficulties with your DC07. If the wand release button on the hose cuff has broken, the hose assembly will require replacement. If you wish to order a new hose assembly, you can do so by visiting www.dyson.com and clicking on 'Spares'. Alternatively, if you'd like to order by phone, you can get in touch with us directly by calling free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
I have a Dyson Animal vacuum. My wife removed the handle to use some of the attachments for cleaning. When placing the handle back to the vacuum, she attached the top part of the handle back to the...
Sorry to hear you're having difficulties with your DC07 Animal. From what you've described, it sounds as if the wand has been replaced on the cleaner without the hose being retracted. To remove the wand from the machine, hold the cleaner securely in place by placing one foot on the cleaner head, then pull the wand up forcefully whilst holding the purple quick-draw hose release (located above the on/off switch) down. Make sure you are not leaning over the top of the wand as you do this.
Once you've freed the wand from the cleaner, make sure you retract the wand before replacing it on the cleaner again. Hold down the hose release button on the hose cuff as you retract the wand inside the hose.
You might find it useful to refer to the user guide supplied with the cleaner - in case you don't have this to hand, you can download a copy here:
http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
If you have any further queries about using or maintaining your Dyson cleaner, please call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide the assistance you need. Alternatively, you can resolve many issues without picking up the phone by visiting www.dyson.com and clicking 'Support'.
Kind regards,
Jack
This is embarassing, but I have just looked at the Dyson DC07 manual and at my Dyson for about 20 minutes, and I can't for the life of me find the wand release button on my actual Dyson.....the manual...
Hi the wand release button is located directly above the the Cylinder release button. The wand release button looks like the picture below. In order to releease the wand you must firstly make sure the Electrical cable is not wrapped up for storage. So unwrap the electrical cable. then find the item as in the picture. Press this button in and at the same time lift the wand. This will realease the wand from the spine of the Dyson. dumfriesdon.jpg
1helpful
THE HOSE ON OUR DYSON ANIMAL UPRIGHT HAS LOST SUCTION-HOW DO WE CLEAN IT OUT ?
Hi its Darran at Dyson.
You would need to release the wand/hose assembly from the machine then slide the hose right to the bottom of the wand and press the release catch to disconnect from the wand. Then at the base of the hose you shoudl be able to un-clip the hose to remove it completely from the machine.
Full details on how to check your amchine for blockages, can be found in the Support section on our website at www.dyson.com.
Kind regards
Darran
4helpful
Dyson DC-07 Hose Wand Spring Came Out. How to put back in?
You'll see that there is a round piece with a cross shape on the inside of the button wand release button - place the end of the spring over the cross - you'll see the same cross on the collar of the machine...it'll take some doing, but line the other end of the spring up with the cross and pop the button back into place - be sure to click it onto those two gray circular/oval shaped divets at the bottom where the release button connects to so that the button stays in place.
2answers
Dyson DC07 Cleaner head not pivoting freely.
the spring might be disattachd because of the fall check inside the cleaner head if you can attach it thank you
2answers
Dyson DC 11 Broken Wand Clip
Contact the manufacturer, thay should be able to assist.
Jan 05, 2009 • Vacuums
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
