Question about Refrigerators
My Bosch Logixx Freezer appears to be working but, refuses to maintain the freezer temperature lower than -11 degrees C. What is the likely reason? Can it be economically rectified?
    President:
  • 1,462 Answers
A common cause is the fan not working so freezer relies on convection only. remove cover round fan and check it is free to rotate. often ice builds up round the fan and jams it. can you hear fan running?
Posted on Jun 21, 2008
I have a freezer bosch log/xx model dc125e12raw5r600 tempretureis only -5 is this normal
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The ideal temperature range for a freezer is -2/+2 degrees F. This temperature range can very depending how full the freezer is. If your freezer is jam packed -5 degrees is good. If it is half full, +2 degrees F. is a good setting.
Too high of a setting such as -20 degree F. will cause freezer burn (bone dry your food).
Your compressor will kick in and cycle until it reaches the temperature setting. You can save on your electrical bills based on your evaluation of the necessary temperature setting.
Oct 19, 2014 | Bosch Freezers
Hi, I have a Bosch Logixx Fridge/Freezer (frost free), works fine apart from large build up of ice on floor of freezer which I constantly have to remove. Any ideas? Many thanks Peter
Hello
check that it defrost elements (heater elements) are working if they working then check if the sensor is working and if the door is sealing when its closed or if the drain is open.
Thanks
Jun 04, 2011 | Freezers
What is the proper temperature for a refrigerator be and what is the proper temperature for the freezer?
A refrigerator should maintain temperatures at or below 40 degrees F. The freezer temperature should be 0 degrees F or lower
May 13, 2011 | Amana Refrigerators
Hi there, we recently purchased a Bosch Platinum side by side fridge and freezer model number KAN56V40AU. The problem we are experiencing is that the fridge section is not cold enough and the temperature...
you will be able to get a technician out under warranty to properly diagnose the fault
you do not have to return it as they will come out for the job
call the service agent listed on the warranty booklet
don't touch it your self as that will void the warranty
Jul 14, 2017 | Bosch Refrigerators
Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
Bosch Refrigerator ice forming in vegetable drawer
Emptied drawers and cleared the drain hole. Drawers were then refilled BUT MADE SURE THAT THEY WERE NOT OVERLOADED
Jul 28, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Freezer not staying cold
thermistor has worned out so please change the thernistor then you ll find the temperature gets maintained in 0 degrees......
Sep 10, 2008 | GE PTS25LHP Top Freezer Refrigerator
Freezer cycling on and off rapidly
If it still maintaining temperature but is short cycling your control for the temperature is wearing out causing the short cycling. This is a replaceable part that can be obtained through a dealer or appliance parts supplier. By lower setting do you mean lower number on the control, or lower temperature setting? Normally the higher the number the colder the temperature.
May 14, 2008 | Freezers
Refrigerators Logo
153 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
