Question about Maytag SAV2655A Top Load Washer
Waher wont spin
It will wash and the water will drain but it will not spin when its on the spin cycle
    Sniper:
  • 114 Answers
First, if it's under warranty, have them service it, if not then....
the maytags work mainly on belts with a forward and reverse on the motor. forward washes, reverse drains and starts spin cycle. if the motor does reverse and drains the water, then it's probably the transmission of the washer. these washers have 10 years parts on the transmission, so I would have a service repairman come out and fix it. you'd only pay for the labor and the transmission would be free.
Posted on Jun 21, 2008
Washer wont spin
If your waher drains but won't go into the spin cycle, then it is most likely the transmission. BUT make sure that you check it in all the different wash modes, since if it works in one of them then it would change the diagnosis.
Jul 30, 2011 | Kenmore Washing Machines
Water coming out of the botton during spin cycle
Take the bottom panel off the waher, put water in the machine, and watch to see where it is leaking. If you don't see a leak during the regular cycle, put the machine in drain and spin mode, and watch for leaks there. You should find your leak during one of these cycles so you will know what part you need.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Waher will not start
IF YOU DONT HAVE THE RIGHT TOOLS TO BREAK IT APART AND PUT IT BACK TOGETHER AND THE EXPERIENCE IS CHEPEAR FOR YOU TO CALL A TECHNICIAN OR BUY A NEW ONE!!!
TO FIX THIS PROBLEM IS A LITTLE TO HARD!!! NEEDS TO HAVE EXPERIENCE!!! SORRY!!
Oct 05, 2009 | LG WM0642H Front Load
Washer won't spin out the water
This is a drainage issue. the spin cycle works in conjunction with the draining pump. they both work at the same time during the spin. if the drainage hoses or pump are clogged with debris, it will prevent the water from being drained properly.
Check the following to address the faulty drainage issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
May 31, 2009 | Maytag Washing Machines
Waher won't spin
Either a bad lid switch or a bad direct drive coupling or a bad timer.
Fill the machine with water. In the wash mode observe the agitator. Is it moving back and forth? If no, replace the direct drive coupling.
If yes, it does move back and forth, with the lid closed, advance the timer to the spin cycle. If it does not spin, raise the lid then close the lid. Does it spin? If yes, replace the timer.If no, replace the lid switch..
Apr 08, 2009 | Kenmore Washing Machines
Washing machine will not spin
If this is a Whirlpool washer, you have a broken motor coupler
Jan 23, 2009 | Washing Machines
Spin problem
you probably have a partial clog in your pump not allowing all the water to drain out the first time.id check the pump first
Jan 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Waher not working
does it make a humming noise if so there might be something in your pump
Dec 19, 2008 | Whirlpool Washing Machines
Kenmore Waher Top Load
It is normal to have some water in the wash tub when the spin cycle starts. It will gradually drain down as the tub begins to spin faster. However, if you STILL have an abnormal amount of water in the tub as it begins the high speed final spin, you may have a slow drain problem with your plumbing, or something restricting the water in your drain pump. If you've never had drain problems before, I would suspect you might need to check your pump. I'm posting the following link that explains how to replace the pump, because it explains how to access and remove it:
http://www.fixya.com/support/r397092-replacing_water_pump
These pumps are NOT serviceable and are sealed. Do not attempt to disassemble it. You can, however look inside the pump to see if anything is lodged in it. Underwire bra hoops, socks and underwear are common items that are found. Another thing to inpsect is the back of the pump where it mounts to the Drive Motor shaft. The hole in the pump should have two flat sides. Sometimes, this hole rounds out and the pump begins to free spin on the motor shaft. Let me know if you require additional assistance. I hope this information helps you.
NOTE: If you require a replacement pump, they can be ordered ar searspartdirect.com or replairclinic.com. Make sure you have your COMPLETE model number handy.
Aug 30, 2008 | Kenmore 24042 Top Load Washer
Maytag SAV2655A Top Load Washer Logo
206 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
